Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 29, 2009, 01:19 PM   #1
Personal Sales Rating: (0)
Drives: 06 IX, 97 Mitsubishi Montero
ACD leak, checking for more obvious places for leak before dropping transfer case
Hey all, I have an 06 IX and it isn't keeping ATF in the reservoir. If I fill it up even with the car off, the fluid level will eventually drop down to nothing. I have yet to find any obvious leaks. At one point I put in so much fluid and then ran the pump that fluid started pissin' out of the breather(NOT the bleeder) on the transfer case. I was wondering if there were any more obvious places for me to look before I drop the transfer case and check the seals out... Thanks for any and all help.
Offline
Old Oct 29, 2009, 01:39 PM   #2
EvoM Moderator
Personal Sales Rating: (12)
MR Turco's Avatar
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
I'm lost, where is it "pissin" from?
__________________
-Mike
The Rules - love them
TephraMOD V7 - now serving 25x30 fuel and timing maps and Gear Dependent Boost Control
Quote:
Originally Posted by beavis820 View Post
turco is a damn fine mechanic without me
Offline
Old Oct 29, 2009, 03:11 PM   #3
At first I thought it was pissin from the breather on the transfer case(pic attached to this post), but it isn't. I'll put fluid in the reservoir but won't see any fluid coming out from anywhere obvious.
Offline
Old Nov 3, 2009, 05:43 PM   #4
vjz225's Avatar
Drives: evo 8
leak
Most likely it will be on the banjo bolt on the t-case.
Offline
Old Nov 3, 2009, 08:19 PM   #5
What is the banjo bolt?
Offline
Old Nov 3, 2009, 08:24 PM   #6
Personal Sales Rating: (3)
ak47po's Avatar
Drives: Evo IX MR Apex Silver
Offline
Old Nov 3, 2009, 08:30 PM   #7
JohnDoe1984's Avatar
Drives: '06 Evo IX
This is where it is located on the t-case. You will see a rubber hose attached to the bolt following your rear driveline.
Offline
Tags
acd, fluid, level
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
