Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 3, 2009, 12:42 PM   #46
Personal Sales Rating: (7)
malonejr2000's Avatar
Drives: 05 EVO 8, 97EAGLE TALON TSI, 64 FORD F100 WITH 863 BWHP,2004 GSXR 600
cam sensor isnt it!!!!!! they still dont know what it is but.....The fronts tires are 225/45/17s and the rears are 235/45/17s that might be it maybe.....that may be why it starts bucking after it warms up ?????
Offline
Old Nov 3, 2009, 12:49 PM   #47
Personal Sales Rating: (15)
Kracka's Avatar
Drives: Wicked White Evo IX GSR
Send a message via AIM to Kracka
My guess is you did some damage to the center differential with the mismatched tires. I just moved to TX from MN so do whatever you can to get down here since it owns the midwest in every aspect
__________________
*formerly S2kracka*
Online
Old Nov 3, 2009, 01:25 PM   #48
Personal Sales Rating: (5)
2008 Subaru Impreza
My Garage
UT_Evo's Avatar
Drives: a big giant station wagon that's kinda fast
Quote:
And the dealership doesn't even have a guess as to what is wrong? Check your diffs and TC and get 235s all around of the same make and model at least, DO NOT mismatch tires ever again on an AWD vehicle. If you want to do that go by a RWD or FWD car. (Or an AWD car that can compensate for it, like the C4)
To test the tire theory though (since it only happens when the car is warmed up). Let the car sit and warm up just parked and see if it still does it when you drive it right away, or if it still takes awhile (IE for the tires to warm up)
__________________
UtahEvos
2003 Apex Silver Evo 8... Gone, but not forgotten
1999 White Carrera 4... Gone, fun while it lasted
2008 Obsidian Black STi, the best of both worlds!
Offline
Old Nov 3, 2009, 02:31 PM   #49
they put it on the lift and couldnt get the problem to happen so it only happens when the tires hit the road for like 10-20 miles of highway driving....Well yeah duh i feel like a dumb ass for sure man that i did the tires this way....never again will i be this stupid...i just hope the TC and diff isnt jacked up....Hope i can put on the rite tires and bam its fixed....It drives fine until it gets warm...has to be this in my mind....If the diffs or the tc were jacked up it would show imeadetly rite???instead of after it gets warm????
Offline
Old Nov 3, 2009, 02:39 PM   #50
2008 Subaru Impreza
My Garage
UT_Evo's Avatar
It might just be the tires. And if they put it on the lift and it doesn't do it even warm, that's another further test to show that. Are the tires at least the same tread pattern and brand etc etc?
Like I said, you may want to try warming it up by just letting it idle outside, and then take it for a quick drive and see if it does it or not. It might be that when the tires get hot and the rears have more grip than the fronts they push forward and the fronts lose traction and skip or something... Just throwing out ideas though. So if it doesn't do it with the tires on the road but when they've just been sitting and the car is hot, that could be it... Check tire pressures too for sure. You could always see if someone local has wheels/tires they'd be willing to swap with you to try.
__________________
UtahEvos
Offline
Old Nov 3, 2009, 02:51 PM   #51
yeah they let it sit and run for over 10 minutes then drove it and it still takes 10-20 miles and when on the lift it doesnt do it....the presure is rite in the fronts and backs and no the tires are not the same brand or pattern...the fronts are BF goodrich Gforce and the rears are Kumho ecstas (wrong spelling i know)...i just hope the diffs and TC are ok
Offline
Old Nov 3, 2009, 03:04 PM   #52
2008 Subaru Impreza
My Garage
UT_Evo's Avatar
Check the fluids in the diffs and tc for metal shavings, they may be fine still... But yeah, mismatched tires that horribly mismatched may definitely be your problem. Only thing you could do worse is to have ones with a larger sidewall.
Kumho Ecsta is how you spell it too At least both are summer tires though right?
__________________
UtahEvos
Offline
Old Nov 3, 2009, 03:13 PM   #53
[quote=UT_Evo;7680683]Check the fluids in the diffs and tc for metal shavings, they may be fine still... But yeah, mismatched tires that horribly mismatched may definitely be your problem. Only thing you could do worse is to have ones with a larger sidewall.
Kumho Ecsta is how you spell it too At least both are summer tires though right?[/QUOTE]
Yeah....summer-ish lol....the fronts are zr rated and the rears are just r rated...they are both summers for sure...Thanks UT EVO for the help man and advice....Its making me feel alot better for sure...
Offline
Old Nov 3, 2009, 05:43 PM   #54
Personal Sales Rating: (1)
Drives: 06 EVO IX SE
Send a message via AIM to dhammans
This doesn't sound like a super smart dealership. That is one of the first things they should have checked. Get the right tires on there and see if the center diff is drivable. Doing this testing on the lift wouldn't show a problem like this because all 4 wheels are not locked together, they are spinning freely and are free to spin at different speeds. When you put the car on the ground however they all have to spin at the same speed, hence your problem.
__________________
Dan Hammans
We Need More Power - www.wnmp.net
1999 Eclipse GSX - 10.66 @ 131 in 2004.
2006 Evolution IX SE - FP BlackŪ Powered.
BNIB Magnus V5 intake for sale, PM for info.
Offline
Old Nov 3, 2009, 10:23 PM   #55
also if there is a whine coming from the front right what is that???is it and axle TC or Center diff??? Im going to have them check for shavings...hope they dont find any...
Offline
Old Nov 4, 2009, 10:42 AM   #56
1d10t's Avatar
Drives: 2005 RR Rs, 2008 BMW X3, 2000 VW Jetta
I will be surprised if this issue was caused by that tire difference.
I mean, maybe we shouldve got a full size spare?
30 minutes of driving may be worth 3-5 psi max.
Not good to have mismatched tires, but, I'd think that your acd clutches would slip
__________________
Billet
Online
Old Nov 5, 2009, 10:53 AM   #57
tires tires tires tires tires tires well you get the point....It was the tires is what they are saying....they cant get the car to do the same bucking or anything....Man i feel stupid....Being dumb has gotten very expensive....Well i gues you learn what not to do before you learn what to do....i will search the forums from now on looking for somebody that might have the same isues and try to help them lol...Ill know after they take it on a 40 mile run today and if it doesnt happen again then im good...No shavings were found in the diffs or the TC...
Offline
Old Nov 5, 2009, 11:11 AM   #58
2008 Subaru Impreza
My Garage
UT_Evo's Avatar
Burn on 1d10t... What a good name though. If you need more explanation as to why hotter tires become stickier (pressure wouldn't matter much here) or why the spare is to only be used for a short while and at low speeds... Feel free to ask!
Did you get even tires all the way around then? Let us know if that fixes it! And congrats for solving the problem and not having anything broken or expensive. Replacing tires is way better than replacing TC or diffs. We all make mistakes in our early days, even if we don't like to admit it.
__________________
UtahEvos
Offline
Old Nov 5, 2009, 11:14 AM   #59
Kracka's Avatar
You obviously have quite a bit of learning to do still. Appropriate user name though May I recommend you read up on the usage of our spare tire and on how the ACD functions?
__________________
*formerly S2kracka*
Online
Old Nov 5, 2009, 12:07 PM   #60
Quote:
I have to say Paul aka 1d10t is my good friend and also a skilled mechanic so we all make mistakes and stuff like this whole thread is hail to me for being king retard lol...I want to say thanks though for all the input and advice from every body on here and thanks UT_EVO you made me feel better and had some real good advice man...Cant wait to get in my car and drive again cause my ole ladys 99 sebring and my gsxr 600 in the cold are getting so freaking old to drive...
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
