Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 7, 2009, 10:52 AM   #31
Personal Sales Rating: (2)
Drives: 2003 evo8 gsr
Ny 1 ?
__________________
jam stage 4 2.3l short block ,jam stage 3 cilender head ,
full race turbo kit wid t4z88hta ,bf272 cams ,fidenza cam gears ,greddy type s bov ,injen hard pipe kit ,ets 4" fmic ,apexi power fc d jetro ,aem 3.5bar map sensor,apexi avcr,greddy evo2 exaust system,1200 injecters ,full blown double pumper,ams vsr,
quarter master twin disc ,apexi turbo timer ,defi gauges complete set ,hks fan temp controller hks 4"intake,spark tech cdi cop ....
Offline
Old Nov 7, 2009, 03:34 PM   #32
Personal Sales Rating: (1)
RapedApe's Avatar
Drives: 04 BBY SSL - 2.3L
Quote:
Originally Posted by haseeb View Post
i just poured a tea spoon of oil in that cilender but there is no increase in the compression ,
its the same
now tell wat is cud be ?
its smoking as it was ..
Problem is in your head then. Most likely valve guides.
Offline
Old Nov 7, 2009, 10:39 PM   #33
How wud I get to know where the problem is once ill lift the head ? Is the problem gone be visibaly seen ?
Wat wud be the syptoms of bad valve seals ,rings or valve guide ?
__________________
Offline
Old Nov 7, 2009, 11:00 PM   #34
Personal Sales Rating: (12)
Drives: 03 evo ,02 ws6 trans am
Send a message via AIM to 06ravenmr
bad seals will most likely have smoke during startup or when u let off the gas.. i doubt the valve guides or seals would cuz ur drop in pressure on ur number one cylender but it is possible since u are seeing smoke when u let up off the gas. just seams a lil odd thats its only #1. if ur pressure didnt i ncrease during wet test and there are no signs of blowby then ur rings are still good.. when u take that head off check the head gasket around that bad cylender and put a straigt edge across the head and check to make sure there is no more then 3 thousands of a gap between the head and ur straight edge. use a feeler gauge for tha
__________________
03 evo 8
turbo trix 50 trim turbo kit
1mm oversized valves
hks 272/272
aem ems
aem wideband
b&m short throw
soon to be kelford 280's with the new pte 5857..
Offline
Old Nov 7, 2009, 11:03 PM   #35
u can also bring ur motor to tdc and apply air via the compression tester hose(dont forget to take out the stem) to the number one cylender and listen for where the air is escaping.. have something holding the motor from turning over.. i prybar works good or just someone under the car with a wrench.
__________________
03 evo 8
hks 272/272
aem ems
aem wideband
b&m short throw
Offline
Old Nov 8, 2009, 12:45 AM   #36
Thanx ,I'm taking of the head now ,will let u know where I see the problem ..
__________________
Offline
Old Nov 8, 2009, 12:50 AM   #37
Personal Sales Rating: (4)
xRoguex's Avatar
Drives: 2005 Evo SSL
Send a message via AIM to xRoguex
Quote:
Are you kidding me?
Wow -- the problem is either - the wet test was done wrong - Reading something and performing it properly are two different things.
Or - Your valves are not sealing properly - due to carbon buildup, or just a piss poor assembly job.
Or your HG is toast. Unlikely tho - as you would be pushing coolant.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
FP 80mm Red, BR Race FMIC, BR 65mm TB, MAP Intake mani, BR 3" Exhaust, Megan O2, MAP Exhaust mani, Kelford 272's, Supertech Springs, Spoolin COP, HKS intake, HKS BOV, ECU controlled boost, Innovate WB, Defi Guages, Exedy Twin HD, ShepTrans and Xcase.
Sponsored by the USMC and US Army.
ROM - 96530006
Tuned by Asmodeus
Offline
Old Nov 8, 2009, 01:47 AM   #38
I've been running this stage 3 engine since 1.5 years with zero problems ,I stored the car for 3 months ,d now I'm seing smoke
Will let u guyz know once the head ios off ..
Thanx
__________________
Offline
Old Nov 8, 2009, 01:50 AM   #39
Drives: Evolution Baby
do the wet test. Pour little bit of oil in the cylinder, and do compression test, if the psi go up, that mean it's your ring, if it doesn't do anything it's your head.
__________________
2nd:RTA BUTTON WILLOW UNLIMITED CLASS 12/03/06
2nd:RTA BUTTON WILLOW MODIFIED CLASS 4/29/07
1st: RTA BUTTON WILLOW MODIFIED CLASS CHAMPION 3/30/08
1st: RTA GATEWAY INTERNATIONAL RACEWAY MODIFIED CLASS CHAMPION 4/20/08
1st: RTA CALIFORNIA SPEEDWAY MODIFIED CLASS CHAMPION 7/20/08
3rd: SUPERLAP FINAL BUTTON WILLOW LIMITED CLASS 11/12/2008
C-Spec Tuning : Robispec : Driven Innovation : Toyo Tires : Milspec : Motul : MAPerformance : Extreme Turbo Systems : Boomba Racing : ARK Performance
Offline
Old Nov 8, 2009, 02:24 AM   #40
I've done it ,and the compression stay the same ..
__________________
Offline
Old Nov 8, 2009, 01:55 PM   #41
Lifted the head today ,rings r gone ...
Now plz tell me that I can see some scratches on the rod bearings also ,shud I change them also
Or let them stay as it is ?
Wat about the main bearings ,shud I check them also ..
__________________
Offline
Old Nov 8, 2009, 01:59 PM   #42
xRoguex's Avatar
Rings are gone? How do you know?
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Old Nov 8, 2009, 02:11 PM   #43
That's wat the mecenic told me ,he has checked it prety well ..
Now wat shud I do withe rod bearings ,shud I change them as well ?
__________________
Offline
Old Nov 8, 2009, 02:39 PM   #44
Personal Sales Rating: (0)
JC evo1's Avatar
Drives: EVO1
if i were you id pull the whole motor and check it over, strip it, rehone, new bearings and rings etc...
__________________
built 2L - GSCS2 - Hypertune intake - GT3582.....
490whp pump gas 27psi dynamics 1.0CF
Offline
Old Nov 8, 2009, 02:41 PM   #45
definatly replace bearing while u have it out... ur this far u might as well do what jc evo1 said
__________________
03 evo 8
hks 272/272
aem ems
aem wideband
b&m short throw
Offline
Tags
apexi, avcr, compression, forged, map, pistons, r6, test
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
