Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 28, 2009, 02:24 PM   #16
Personal Sales Rating: (2)
Drives: 2003 evo8 gsr
Hmm ,is it ok to drive the car as its still runing like a champ ?and the smopke is barable also ,but io really dun wana hurt the car and make is worst
__________________
jam stage 4 2.3l short block ,jam stage 3 cilender head ,
full race turbo kit wid t4z88hta ,bf272 cams ,fidenza cam gears ,greddy type s bov ,injen hard pipe kit ,ets 4" fmic ,apexi power fc d jetro ,aem 3.5bar map sensor,apexi avcr,greddy evo2 exaust system,1200 injecters ,full blown double pumper,ams vsr,
quarter master twin disc ,apexi turbo timer ,defi gauges complete set ,hks fan temp controller hks 4"intake,spark tech cdi cop ....
Offline
Old Oct 28, 2009, 02:34 PM   #17
Personal Sales Rating: (0)
Murf's Avatar
Drives: 03 evo 8/ 06 R6
you are taking a chance of having a bad failure and having to do an expensive rebuild. What I told you was just my problem does not mean that it is your problem. Myself and most others here would find problem and not take the chance. You very well could have bad rings in that piston..do a wet test on that cyl.. warm up car, remove plugs, disconnect cam angle sensor, press gas to floor crank 3 to 4 rotations. see if you get same compression as before. if so pour a little motor oil in cyl. (don't go crazy just a little I used 1/2 of a oil bottle cap full some use 1 cap. do test again. if compression jumps way up its your rings.
I also had that problem.
__________________
The measure of a good car is how well it reacts in all road situations, NOT just how fast it goes straight.
Offline
Old Oct 28, 2009, 02:37 PM   #18
Well that's gr8 ,ill do it tomarow ..
Thanx
__________________
Offline
Old Oct 28, 2009, 02:45 PM   #19
Murf's Avatar
Oh the car will smoke like a M'fer until the oil you poured in the cyl is gone..just a heads up.
question for you on you compression tester...are you using one that screws into head then hose then gage? you are not using an extention are you?..personal exp.. the extentions will give false readings..low false readings.
__________________
Offline
Old Oct 28, 2009, 05:48 PM   #20
Personal Sales Rating: (4)
xRoguex's Avatar
Drives: 2005 Evo SSL
Send a message via AIM to xRoguex
search on how to do a compression test -- do a wet test also - its easier then pulling the head and will tell you if its top or bottom end problems.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
FP 80mm Red, BR Race FMIC, BR 65mm TB, MAP Intake mani, BR 3" Exhaust, Megan O2, MAP Exhaust mani, Kelford 272's, Supertech Springs, Spoolin COP, HKS intake, HKS BOV, ECU controlled boost, Innovate WB, Defi Guages, Exedy Twin HD, ShepTrans and Xcase.
Sponsored by the USMC and US Army.
ROM - 96530006
Tuned by Asmodeus
Offline
Old Oct 28, 2009, 11:45 PM   #21
Personal Sales Rating: (1)
Drives: Evo 6 Powered Mirage
dont forget that dynamic compression and static compression are different. just cause you have 8.6 static compression ratio, doesn't mean you'll get OEM pressures for your compression test. you might have large cams?
i'd say talk to your engine builder, he could point you in the right direction.
Offline
Old Oct 29, 2009, 12:04 AM   #22
yes ur rite ,ive got bf 272 cams ..
and jam stage 3 short block ,
talked to them and they said there is nothing to wory about and they wanted me to do the compression test when the car is cold instead of warm ..
__________________
Offline
Old Oct 29, 2009, 12:25 AM   #23
Drives: 03 evolution
yes it very well could be you have a bad ring on that cylinder ! id take it to a nearest shop and have them put a boreiscope in that cylinder and see if it apperars to be wet due to oil makin its way into the cumbustion chamber! could very well be a valvetrain issue also!
Offline
Old Oct 29, 2009, 01:15 AM   #24
ohk ,but wat will be the best way to find out the problem as i really dint understood to check it with boreiscope ,or there is any other way to check ?now if there is the ring problem in cilender num 1 shud change the rings n all the cilenders or just for the cilender 1 ?
i had a built short block by jam and i dun really want mess it here in my country by opning it all ..
__________________
Offline
Old Oct 29, 2009, 03:57 AM   #25
Wat if we don't disconect the cranck angle sensor ,cause I dint disconected it during the compression test ..
__________________
Offline
Old Oct 29, 2009, 07:31 AM   #26
You should definately do the compression test when the engine is warm especially on a forged piston motor as they expand and contract when hot/cold. Also do each cylinder twice and a tester can stick or act funny so I always do everything twice. Also pressing the accelerator is recommended for #'s but if you are not and they are consistent the # is somewhat irrelevant. Also if you can buy a leak down tester that will tell you if you have a bottom end problem or a top end problem.
Online
Old Oct 29, 2009, 07:33 AM   #27
Drives: volvo 740 turbo
Send a message via AIM to linuxman51
you get fuel in the cylinders if the ecu is seeing rpm. this can alter your numbers somewhat. either unhook power to the injectors as well as the coils, and hold the throttle body open whilst cranking, or disconnect the crank and cam sensors so the ecu doesn't see engine rotation.
__________________
03 TB EvoVIII, ams 35r, fmic, cams, etc. 440whp
90 Volvo 740 16v, t67, blah blah blah 512whp
Offline
Old Oct 29, 2009, 12:29 PM   #28
Drives: EVO VII JDM
Send a message via MSN to zedevo
Sorry Hasseb : I have an Impo Question to ask .
I have the same set up 2.3L with 9.5 comp ratio Pistons ... with BF Cams and it gives me 195Psi On each Cylinder ... Im pretty sure its weird ... Cant go High Boost On Pump gas ... But is it ok ? Or at least how much should me The compression on a Normal 2.3L ?
Offline
Old Oct 29, 2009, 05:43 PM   #29
xRoguex's Avatar
http://my.prostreetonline.com/t405.htm
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Old Nov 7, 2009, 08:23 AM   #30
i just poured a tea spoon of oil in that cilender but there is no increase in the compression ,
its the same
now tell wat is cud be ?
its smoking as it was ..
__________________
Offline
Tags
apexi, avcr, compression, forged, map, pistons, r6, test
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
