Oct 26, 2009, 03:43 PM
Personal Sales Rating: ( 2)
Drives: WHITE EVO IX
HOW TO check for shaft play on turbo
i just bought a used ix turbo, exactly how to i check for shaft play? are you suppose to push and pull the compressor wheel? or turn it back and forth? thanks
Offline
Oct 26, 2009, 03:46 PM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX MR
Pull and push back and forth on the shaft. If it moves its starting to go bad. More it moves the worse off you are.
__________________
Mike
AEM EMS Tuner
All Tuned by me.
-Evo IX GT30R Powered!! (10.9 @ 122) Full weight and Stock motor at 30psi
-98GSX 42R Powered!! (10.1 @ 146)
Offline
Oct 26, 2009, 03:50 PM
there is shaft play when i push and pull the compressor.. damn man the guy that sold me said it had 5k miles with 0 shaft play. **** man
Offline
Oct 26, 2009, 03:55 PM
Personal Sales Rating: ( 23)
Drives: 06 Evo MR
^That is messed up, man. How much did he soak you for?
Offline
Oct 26, 2009, 03:58 PM
450$ **** man i needed a new turbo bad
Offline
Oct 26, 2009, 04:06 PM
damn man.. cant believe this
Offline
Oct 26, 2009, 04:08 PM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
Hold on there buddies. There is an acceptable tolerance for shaft play, and it's not zero. But I don't know the specific tolerance.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Oct 26, 2009, 04:09 PM
Personal Sales Rating: ( 36)
Drives: EVO METH MACHINE
Evo 8/9 turbo's will have a little play, it wont' be stiff. Now if it's drastic play then you have a problem. Get a second opinion at a shop, preferably a machine shop.
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Oct 26, 2009, 04:16 PM
Personal Sales Rating: ( 1)
Drives: 96 plymouth neon
where in ny are you? i can check it for you. i have the book at my house and the above poster is correct there is always a tolerance. it isnt at zero if it were it would be on ballbearings... but mhi turbo's are mostly on bushings and all of evo as far as i kno at least 8/9 are on bushings wich will have shaft play.
further more for a few bucks if it really is that bad you can buy the rebuild parts from forced performance.
if you cant have me check it, and you need to get your car going and your in a jam. heres what you do, take the compressor cover off, verify that the compressor wheel has not made contact with the compressor housing. LOOK CAREFULLY AND CLOSELY it will looked machined if there was any contact. IF THERE IS NO CONTACT YOU CAN PUT IT ON YOUR CAR AND START IT UP, if it smokes ITS DONE. if it doesnt smoke your probably fine.
those go in my area for about 750. 400something is a great price. good luck and my number is on my sig let me know if you need my help.
Eddie Rosado
__________________
sold
Eddie Rosado
203 673 9029
Offline
there is play on this thing but its not too crazy. i dont know if this is normal or what? did i buy a bad turbo??
Offline
Oct 26, 2009, 04:18 PM
Eddie Rosado
im in queens NY. where are you?
Offline
Oct 26, 2009, 04:42 PM
the bronx story ave castle hill area zerega ave
Eddie
__________________
sold
Eddie Rosado
203 673 9029
Offline
Oct 26, 2009, 04:43 PM
Eddie
how far is that from whitestone bridge?
Offline
Oct 26, 2009, 04:50 PM
lol its right there, like 50 seconds? haha
Eddie
__________________
sold
Eddie Rosado
203 673 9029
Offline
Oct 26, 2009, 05:17 PM
Drives: 2006 EVO IXMR
You two should prob just meet up, do dinner, then look at each others shafts
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Tags
bad, camn, check, checking, evo, evolution, garrett, lancer, play, sales, shaft, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
