Oct 26, 2009, 03:32 PM
Personal Sales Rating: ( 0)
Drives: '06 GG Evo IX
2nd Gear clunk?? (yes, i searched)
searched around nd couldn't find anything.
i have a gg evo IX with 17,800 miles on it. bought it a few days ago. nd i've noticed going into 2nd the gearbox kinda like clunkss. not so much a grind but it doesn't go in as smoothly as the other gears..
does anyone experience this? its not that bad like if im banging through the gears u don't feel it, but when driving slow nd shifting very slowly its noticeable.. is this normal? i was thinking maybe changing the tranny fluid nd see how it feels.'
any suggestions?
__________________
**BRAND NEW MITSUBISHI OEM CATALYTIC CONVERTER FOR SALE. **PM ME.**
Offline
Oct 26, 2009, 09:19 PM
no one??
__________________
Offline
Oct 26, 2009, 09:25 PM
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
what kind of clunk? do you feel it going into the gear, or when you are letting out the clutch and engaging it? WOT or gentle driving, or inbetween?
Offline
Oct 26, 2009, 09:43 PM
Quote:
gentle driving. i feel it go into gear but before it clicks into gear u can feel another little like rough spot but it doesn't do this for any other gears. wtf could it be? i keep telling myself its not a synchro lol.. the tranny fluids never been changed. i think this weekend im gunna take a little time nd change it. see if it does any good.
__________________
Offline
Oct 26, 2009, 11:16 PM
Personal Sales Rating: ( 12)
Drives: 06 WW MR
I would say its normal my car has done this since day one. After putting in some ams underhood shifter bushings it def made going into second smoother with a better feel and changing your fluid will help slightly too. (amsoil ftw)
Offline
Oct 27, 2009, 04:58 PM
Quote:
thanks man sure makes me feel better. lol i was kinda worried a little. but yeah im gunna hop on that, changing the tranny fluid. and yeah a buddy of mine told me the exact same thing, get some shift bushings and he even said a short throw would slightly help
__________________
Offline
Oct 27, 2009, 05:00 PM
also which amsoil do u use? somebody told me the best bet is just go with the oem diaqueen from mitsubishi
__________________
Offline
Oct 27, 2009, 05:36 PM
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
do you have a 6 speed or 5 speed?
5 speed amsoil is MTG - https://www.amsoil.com/storefront/mtg.aspx . I have also heard amazing things about it which is why it is going in my trans this week.
Offline
Oct 27, 2009, 07:13 PM
Quote:
Originally Posted by MR Turco
i have the 5 speed. sweet im gunna order some of that soon, i need an oil change anyway so thats convienent. was goin with amsoil motor oil too..
how many quarts does the five speed take? 3?
__________________
Offline
Oct 27, 2009, 07:28 PM
i think 2.8, owners manual should give specific amount. but yes you will need 3 quarts
Good luck!
Offline
Oct 27, 2009, 07:30 PM
Personal Sales Rating: ( 5)
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Drives: 05 Apex Silver Version 8, 2001 GSX-R 1000
You also might want to adjust the clutch as well.
__________________
Stock Block and Head
FP Red 80mm
Kelford 272's
Beehive Springs
Precision 1k injectors
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
PPI Extreme Ported Hotside, Exhaust Mani, Intake Mani, and TB
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
322.7 whp 320tq 21.5 psi on 93 oct
355.8 whp 430tq 25 psi on c16
Offline
Oct 27, 2009, 07:35 PM
Quote:
the clutch feels great its just the gear itself going in
__________________
Offline
Oct 27, 2009, 07:39 PM
after time the clutch needs to be adjusted for disengagement
__________________
FP Red 80mm
Kelford 272's
Beehive Springs
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
Offline
Oct 27, 2009, 08:34 PM
Drives: 2006 JDM Evo IX
to the OP or anyone really.
similar problem in 2nd gear, when i try to shift it feels like i am fighting something, even when the car is not moving. WEIRD! the gear is notchy when cold but gets worse when warm.
i change fluid regularly and i hardly doubt its my g-box - i never launched and i only drive the sucker hard once a month (only 20,000kms).
i have a feeling its my shifter base bushings or underhood bushings.
Offline
Oct 27, 2009, 09:41 PM
yeah i don't experience the problem when the cars parked only when moving and shifting at low rpm's at WOT its not even noticable
__________________
Offline
Tags
2nd, car, change, clunk, cold, evo, evo ix, gear, grind, grinds, hard, mr, rough, sentra, shifting, slightly, synchro  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
