Oct 27, 2009, 07:10 PM
Personal Sales Rating: ( 25)
Drives: tb ix gsr ssl
great thread!
OP, can you also include in ur post that people should also present the following points:
1) How many miles have been put on the block since the red was added?
2) what fuel was used?
3) How much boost is being run?
Awsome thread man. been wanted to do this for a while and u beat me to it..lol
cheers
Offline
Oct 27, 2009, 07:29 PM
Personal Sales Rating: ( 2)
Drives: 06 Evo MR
470WHP & 401WTQ at 29.5 PSI on E-85 @ 6000+ foot elevation
AEM Tru-Boost Boost Controller
AEM Tru-Time Cam Gear
ARP Head Studs
Buschur 65mm TB
Buschur Ported Intake Manifold
Buschur Turbo Back Exhaust
Evo Power Mod 02 Dump
Exedy Twin Disc HD Clutch and Flywheel
Forced Performance High Pressure Actuator
Forced Performance Red Turbo
Forge RS Blow Off Valve
Full Race Exhaust Manifold
Injen Intercooler Pipes & Intake
Kelford 272 Cams
FIC 1350cc Bluemax Injectors
Shepard Transmissions Built Transfer Case
SuperTech Springs and Retainers
Turbo XS Intercooler
Welbro 255 Fuel Pump
Offline
Oct 27, 2009, 08:16 PM
Personal Sales Rating: ( 1)
Drives: 2004 RS
Quote:
Originally Posted by RyuEvoIX
590whp 576wtq 40psi on 110oct+meth injection. Recently found out I am making enough torque to rip teeth off the differential in my tranny and final drive. Motor's holding strong though.
Ryu: Did you do drop-in pistons and rods, or are you on a totally stock bottom end? Rod bolts, even???
__________________
Vishnu XEDE & camgears-Greddy 720's-ported Green-HKS 280/272-Forge WGA-AMS LICP-DC DP-Magnaflow Ti-Ralliart TS-Tomei Thermokiller - SSAC O2 - BR8ES-Nissei IC--SS clutch line-Endless(f) /Hawk(r) - WALBRO 255-ITG filter-Motul-KOYO radiator-SAMCO intake hose-UEGO-Autometer-Kartboys-Authority SS-MR DV.
DLL: 389WHP/25PSI on 93( non-corrected@3300' altitude). (No dynos in the jungle! Fortunately, there are carnivorous toads that feed on bats).
Offline
Oct 27, 2009, 08:18 PM
Drives: 06 Evo IX
Quote:
100% from the factory bottom end. The head and oil pan have never been removed from the car. Headstuds were installed 1x1 method.
__________________
2006 Mitsubishi Lancer Evolution IX
Stock Turbo/Stock Cams 11.388@119.92 Best MPH 120.38
10.805@125.97mph 1.574 60ft Stock turbo
Quickest Stock Turbo/Stock Block/Stock ECU
Worlds Quickest Stock Block Evo IX
FP Red/Stock Block 10.301@132 1.56 60ft
Stock Turbo 442WHP 482WTQ tuned by TTP
FP Red 590WHP 576WTQ tuned by TTP
Sponsored by
TTP Engineering
Judge Racing
Offline
Oct 27, 2009, 08:24 PM
Drives: 2004 RS
Quote:
Originally Posted by BLKCarbonEVO
Well i feel your pain on the 6speed. I blew mine twice and then decided to go 5speed. (This was just last week)    Nice informative post...Mikey
Mikey: Are you running a ported TB? Are you on the stock unported head? Nice numbers
__________________
Offline
Personal Sales Rating: ( 33)
Drives: 04 RS and 08 GSR
I was at about 460 whp (DLL) on the stock block and decided that it wasn't worth the risk to continue to push that power level on the stock block, especially road racing. I did a drop-in build at Buschur and am now making 460 whp (on BR's dyno) with peace of mind. I would have felt really stupid if I had blown the stock motor and cost myself an extra $4000-6000 on the rebuild just to say I was making X whp on the stock block.
__________________
RichJ
2004 RS - FP Red, stock ECU w/SD, 464 whp on 93 oct (BR dyno)
Redline TA Summit Point track record - Street Class
Many thanks to Buschur Racing, tephra, jcsbanks, mrfred, l2r99gst and my wife!
Offline
Oct 27, 2009, 08:37 PM
Drives: 2006 EVO IXMR
Sparky, I'm running a stock tb, minus shaft seals. I might upgrade to a MilSpec 65mm in the future but it looks like I'm not in a need of one right now
Yes I'm also on a completely stock head. No port work, stock valvespring and retainers too. The only thing that has been done to my head are my HKS cams which are pretty conservative compared to a pair of S2s or Kelfords.
I'm also running a stock/unported 64mm Red. The turbo came from FP and went straight on the car without being touched.
There will be some changes being made over the next few weeks and we will find out how far this Red will go...or wont....
Mikey
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Oct 27, 2009, 08:51 PM
Drives: 2004 RS
Mikey: I plan on getting my old-style Green reconfigured by FP to 64mm Red specs as soon as I get back paid by some tardy customers. Ditto, I'll also get a set of the 880 RC injectors on my next trip up to L.A. I want to pretty much upgrade to something similar to your current setup. I think that I'll do an ETS 6.00 inch IC and some Kelfords(or S2's) eventually, as well.
__________________
Offline
Oct 27, 2009, 08:52 PM
Drives: 06 Evo IX
Mikey
When do you plan on going to the track and seeing trap speeds to put the dyno numbers into better prospective?
__________________
Sponsored by
TTP Engineering
Judge Racing
Offline
Oct 27, 2009, 08:57 PM
Well you will have to use meth if you go 880s because the 880s on pump will die by 500. I would personally get a Red. The Red is a great all around turbo IMO. A ETS 6in FMIC is way to large! WTF. You going water cooled 6in? Not very streetable.
__________________
Offline
Oct 27, 2009, 09:03 PM
Drives: 2004 RS
Quote:
Originally Posted by EVO8LTW
I was at about 460 whp (DLL) on the stock block and decided that it wasn't worth the risk to continue to push that power level on the stock block, especially road racing. I did a drop-in build at Buschur and am now making 460 whp (on BR's dyno) with peace of mind....
EVO8LTW: When you road race what is your maximum boost level? I assume that you road race on 93 octane pump gas, or do you run race gas at the track?
__________________
Offline
When my balls drop and pockets get deep enough to fix my Transfer case or Rear dif that I'll prob blow sky high. I have the worse luck with drivetrain in my car. I have only launched my car once and the tranny decided it was going to stay behind...
As far as dyno numbers, I'm not on a MD so my numbers are legit, if that's what you are trying to imply; but I will be at the track next year shooting for stock block 9s on my Red
Mikey
__________________
Offline
Oct 27, 2009, 09:08 PM
Drives: 2004 RS
If 880's are too dinky then I'll do the FIC Blue Max 1250's. Naw, I think that ETS does 6" cored air-t-air IC. Never enough intercooler. To make room, I'll just grind away on the inner surface of my front bumper. The 6" core oughta help me run 28 PSI on 91 with my VIII through the Red.
__________________
Offline
Drives: 06 Evo IX
Mikey
I'm implying all dyno's read differently and the only way you or anyone else would ever know your actual power is to see what the car traps. That is the true and only accurate universal dyno.
__________________
Sponsored by
TTP Engineering
Judge Racing
Offline
Oct 27, 2009, 09:13 PM
Personal Sales Rating: ( 0)
Drives: WWevo9rs
I have a dyno, its 1320 feet long.
Fathouse
__________________
2006 Evo9 RS
Stock Engine/head/ecu/maf
Magnus v5, Shep racing, QM clutch, FP cams, Fatfab 35r turbo kit, BFF Racing, Snake Tunning, and CORN Fed
Best times to date.
6.757/10.362
108.55/136.94
http://www.youtube.com/watch?v=0qh0DPNNlJw
Offline
Tags
4g63, 93, act, disk, evolutionm, forced performance, fp, fp red, oct, red, stock motor, street, swaybar, turbo, whiteline  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
