Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 21, 2009, 10:30 AM   #1
PPM
Personal Sales Rating: (1)
PPM's Avatar
Drives: 2003 Mitsubishi Evo VIII Yellow 12.9@112, 2003 Mitsubishi Evo Black, 1997 Eagle Talon TSI AWD 10.6@136
Send a message via AIM to PPM
Angry Please Read Timing Belt Came through cover
Okay,
I was on my way to work yesterday stopped to fill up with Shell 93 and noticed some smoke coming through hood vent, popped hood smelled a little oil (possibly I have a cold hard to tell). Shut car off checked oil (it was clean and perfect just changed 1200 miles ago) turned boost down just to be on safe side 25psi - 20psi. Started driving to work about 4 miles into trip heard something come off car, thought maybe I hit something in road and hadn't seen it, standard unsprung clutch chatter makes it difficult to hear anything else. Stop car on side of road, slight ticking coming from motor, I decided to head home instead of in to work. Got about a mile and car felt like it lost power, more noise and smoke out of hood. I pulled over and cut car off cuz oil light just came on. Car was trying to stall as well. I started car one time and it cut off, I didn't rev or anything just idled out. I towed it home and noticed that my timing belt was showing, burned a hole in the timing belt cover and put several gouges in the serpantine belt was chewed up and oil spray not sure where it was coming from was all over the bottom of the motor. I am going to put everything back together and see what happens unless anyone else has seen this happen, i figure put together check oil pressure / oil pump reset timing belt, compression check, visually check valves / springs and go from there. Any ideas? Anyone have or hear of anything similar happening? I did change my timing belt about 20k miles ago, been to the track and had dyno'ed since then. I can't really afford a new motor or to miss work for that matter. So if I need a new motor, I am going to buy a beater car and put a whole build project on hold until tax money time. Thanks in advance.
Offline
Old Oct 21, 2009, 11:02 AM   #2
Personal Sales Rating: (29)
gfng's Avatar
Drives: evo VII evo VII
any pics ??
Offline
Old Oct 21, 2009, 11:08 AM   #3
Personal Sales Rating: (21)
05blue8's Avatar
Drives: 2005 VIII
Send a message via AIM to 05blue8 Send a message via MSN to 05blue8
Well if you got an oil leak in there it's possible the belt got all slippery and could have shredded off teeth or just little by little come apart. The noises might have been the belt coming apart but until you take it apart there is no telling. Is the timing belt still in one piece? Did you do the FULL 60k maintenance, including tensioners or did you reuse the old hydraulic tensioner?
__________________
2005 EB VIII with everything except injectors and a bigger turbo!
Thanks to Evolution Dynamics for the great work!
Offline
Old Oct 21, 2009, 06:33 PM   #4
PPM
PPM's Avatar
Here are some pics for everyone. I did the full service all parts, tensioner, pulleys, etc. Gates Timing Belt.
Offline
Old Oct 21, 2009, 08:45 PM   #5
Personal Sales Rating: (0)
heavens turbo's Avatar
Drives: 2005 evolution VIII
that sucks. buy a beater, motor is toast. good luck.
__________________
I BLAME THE BAD ECONOMY FOR ME BEING STOCK!
Offline
Old Oct 22, 2009, 08:23 AM   #6
05blue8's Avatar
Drives: 2005 VIII
The motor COULD definitely be toast but your best bet is to find the source of the oil leak, then get the timing back together and check the compression and go from there.
__________________
Offline
Old Oct 22, 2009, 08:29 AM   #7
PPM
PPM's Avatar
Thanks 05 Blue8. My plan is to order the part that failed in the timing belt assembly, it is the bottom right gear obviously from the pictures, the timing belt itself seems fine I will know more this weekend or maybe even later today if I get lucky my son is very sick so I don't have much free time right now. Put it back together as much as necessary and check compression. Even if my compression is bad, I could have potentially bent some valves but there was no metal in the oil so I think that is a good sign and I didn't keep trying to start or drive it cuz I am not that dumb.... Thanks everyone more to follow I will keep taking picks.
Offline
Old Oct 22, 2009, 08:30 AM   #8
Personal Sales Rating: (6)
TeStUdO's Avatar
Drives: '03 Evo 8
Send a message via AIM to TeStUdO
You have an interference engine, meaning that since your timing belt came off, your valves most likely made contact with your pistons. Who did your service? It looks like a hydraulic tensioner failure to me.
__________________
Evo Green/BR Stage 4+/Comp Cams 280/Exedy Twin Disk/ECUFlash
DCEVOCLUB.COM
Offline
Old Oct 22, 2009, 08:38 AM   #9
Personal Sales Rating: (27)
tweakdsm's Avatar
Drives: 05 WW EVO RS
Send a message via AIM to tweakdsm
PPM: seems like tensioner went bad or it wasnt tight , how many miles on the car? if i were you i would check compresion, best way to do? buy a beater, pull the engine out.
__________________
05 RS....Powered by Big Turbo, 2.0 build in progress /// APM RACiNG
Offline
Old Oct 22, 2009, 10:44 AM   #10
PPM
PPM's Avatar
i did the service. I have owned several evo's and 2 talon's, 5th time doing it no trouble at all with install. New tensioner installed with Gates timing belt kit all of the parts are new. Really bummed out right now. I am going to get the beater and hope for the best when I get some extra money I will rebuild the motor. I am going to put together and check compression just for ****s and giggles. I new this was in interferance motor just hoped that I got lucky....
Offline
Old Oct 22, 2009, 01:21 PM   #11
Personal Sales Rating: (52)
red evo8's Avatar
Drives: RR IX
oem tensior when you did the install?
__________________
RR EVO IX GSR/SSL-Greddy Ti/Hallman/A Spec/Defi/Walbro/DC/Apexi/Zaklee/Titan Motorsports/ETS/EPM 02/selftuned
UT law start 2011
Go big or go home
Myspace.com/Importxpresions
Jdm Amber tail light vinyl
NTEC
Offline
Old Oct 22, 2009, 02:05 PM   #12
Silver Sponsor
Personal Sales Rating: (40)
2003 Mitsubishi Lancer Evolution
My Garage
KevinD's Avatar
Drives: '04 evo8 daily driver, '03 evo8 time attack car, 08 outlander
Send a message via AIM to KevinD
oil pump pulley came off?
__________________
EVOLUTION DYNAMICS LLC
Tuning, Custom Fabrication, and installs in the DFW area.
www.evodynamics.com
email: evokevin@gmail.com
Phone + Text messages: 817-776-2170
Kelford, mil.spec, ACT, Aquamist, FIC, ShepTrans, Zeitronix, + many others
Evo Dynamics Unlimited Time Attack Build
3-Port PnP Boost controllers for Evo 8/9/X and RA
Join us on FaceBook!
Offline
Old Oct 22, 2009, 02:13 PM   #13
Silver Sponsor
Personal Sales Rating: (17)
JohnBradley's Avatar
Drives: 06 Rally Red MR
Its done.
I am thinking you will find a bad oil pump, galled cam journals, bearing issues, possibly slammed valves. If it was powering down like that it was seizing up.
aaron
__________________
SparkTech The ignition of EnglishRacing
Extreme Turbo Systems Parts to go fast with
EnglishRacing contact us-sales@englishracing.net
Home of the 522whp stock turbo/no nitrous and 1117whp 2.0L turbo record.
My car- 574whp@29psi stock block, pumpgas, ETS and FP3586...for now.
Retailer of AMR Engineering Coilovers
MAGNUS Motorsport Cast Manifolds in stock, $1000 with ETS Magnus pipe, dual rail available also.
Proud retailer of GSC cams
FIC Master distributor
OmniPower USA Dealer
Offline
Old Oct 22, 2009, 03:43 PM   #14
2005 Mitsubishi Lancer Evolution
Fast_Freddie's Avatar
Drives: '05 Tarmac Black SSL VIII
Christ... this is why I do not do this type of service myself... I am petrified that I could mess something up...
__________________
FP Red*Greddy ProfecB Spec II*HKS TT*Nesei Short Route IC Piping*Synapse BOV*COMP 272s*Injen Intercooler*AFE Power Dry Filter*R/TErnie Intake*R/TErnie FULL 3" O2 housing with V-band*R/TErnie Modified DCsports 3" Down/Test/Flexpipe with V-Band*Greddy Ti-C Exhaust*255lph*Tein S-Techs*18" Volk LE-28s*Progress 25mm Rear Sway*Project Mu pads*JDM Tails*Cusco Heat Shield*Mishimoto Radiator hoses/Cap*ARC shift knob*Injector Dynamics 1000cc...
Offline
Old Oct 22, 2009, 06:51 PM   #15
barneyb's Avatar
Drives: '03 Evo 8, '04 WRX
Quote:
The best mechanic on earth couldn't have know the engine was going to toss that gear. As it is you are going to need an overhaul. The car was losing power and then the oil light comes on - isn't that sweet. Why didn't Mitsubishi save some more money and just leave the light off of the car?
DSM's used to throw the nut on the oil pump sprocket once in a while. It was common practice, although I never did do it, to loc-tight the threads and retorque the nut at belt time. Maybe that is a practice that needs to return.
Offline
Tags
belt, belting, changed, closed, compression, dsm, eagle, evo, facebook, loosing, magnus, oil, rebuild, talon, timing, totally, valves
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
