Heater not working after radiator flush
Old Apr 11, 2013, 11:41 AM
raymie919's Avatar
Originally Posted by mmmmbst
^+1, you have to rev the engine a little but to get the water pump spinning fast enough to burp out the water.
Thanks that worked!
Old Apr 11, 2013, 12:22 PM
TommiM's Avatar
Holy necropost....After 4 years i sure hope he was able to burp the air pocket in his coolant system.
Old Apr 11, 2013, 06:49 PM
sidewaez's Avatar
we may never know!
Old Oct 4, 2013, 02:23 PM
AKMinja's Avatar
So i just purchased a 03 Evo 8, and i'm have function in the blower but the cold to hot knob tightens only when i'm close to max heat, but still no heat, i've read about a gear function that may go out somewhere in the foot well area by the gas pedal. where/what exactly am i looking for and will i be able to see it? and with the t-stats, if i do replace that should i do a coolant flush and place new coolant to water combo ? if so what should i do 40/60? 30/70? i do live in alaska. and winter is coming.
Old Oct 4, 2013, 08:57 PM
barneyb's Avatar
As for the antifreeze mix you need - buy a jug of antifreeze and look on the side of the jug for the coldest temperature you expect to ever experience this winter and use the mixture they recommend.
Old Oct 5, 2013, 02:02 AM
AKMinja's Avatar
Originally Posted by barneyb
Video Link: http://www.youtube.com/watch?v=vcG20LmRZFU As for the antifreeze mix you need - buy a jug of antifreeze and look on the side of the jug for the coldest temperature you expect to ever experience this winter and use the mixture they recommend.
Thanks barneyb
Turns out i was low on coolant and replenishing it did it to get the heater back into working status appreciate the feedback along with the vid link ;-)
Old Nov 4, 2014, 08:52 PM
jasonn's Avatar
Originally Posted by sidewaez
we may never know!
to update, my door gear went bad and it was burped the entire time!
Blue91lx
Dec 16, 2016 01:50 PM
Modz
Oct 31, 2015 07:35 AM
JayDM Evo VIII
Jan 27, 2015 04:28 PM
Astro_Train
10
May 30, 2013 02:33 PM
sgtr275
Apr 9, 2011 03:47 AM
Quick Reply: Heater not working after radiator flush
