Oct 7, 2009, 04:23 AM
Personal Sales Rating: ( 0)
2001 Mitsubishi Lancer Evolution
Drives: mazda lantis v6, mitsubishi evo VII
2.3l or 2.2l?
hey guys. i have a blown evo VII engine in my garage im planning a rebuild and stroke. what im nt sure on is wether i should go 2.2 or 2.3 and which brands i should use. i was originally looking at the eagle 2.3l crank with eagle or mahle rods and je pistons. now im considering the 2.2l. il probably stick with the same piston and rod combo but am not sure what branding crank to go for as i dont believe eagle makes a 2.2l crank for the 4g63. is there anybody out there with experience in this subject that can give me advice? also if there are any vendors out there that could possibly give me a good price or anybody that knows any decent shops out there that are reasonably priced could you please contact me via this thread or pm. any help will be appreciated. thanks.
Offline
Oct 7, 2009, 05:59 PM
bump
Offline
Oct 7, 2009, 06:48 PM
Silver Sponsor
Personal Sales Rating: ( 17)
Drives: 06 Rally Red MR
Eagle, K1, and GSC all offer 94mm cranks to make the 2.2 liter. Pistons will be custom for the application whether you keep it 150mm or 156mm. If you go to the 4G64 tall deck block you can run up to 162mm rods (I recommend only using steel rods in this application) and those can be purchased from K1 or Manley.
Offline
Oct 7, 2009, 07:19 PM
Personal Sales Rating: ( 1)
2003 Mitsubishi Lancer Evolution
Drives: JDM EVO VIII GSR
I was going to go this direction, but ended up purchasing a 4G64 crank, Carillo Rods + CP Pistons.
Offline
Oct 7, 2009, 11:03 PM
Drives: 3g Eclipse Turbo, 79 Z28
go with a 2.4l youll spool big turbos faster.
Offline
Oct 7, 2009, 11:13 PM
Quote:
What John said. I personally like a long rod 2.2 setup, great for street and track. The 162mm long rod setup would be cool, but Im not a fan of messing with a 4g64 block.
__________________
Quote:
Originally Posted by dridge11
I would let her mouth-punch me in the junk
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
