Oct 2, 2009, 07:55 AM
Personal Sales Rating: ( 3)
Drives: 2003 TB EVO VIII
How to identify a TRUE IX turbo
Hey guys,
I tried a quick search and couldn't find anything too useful.
Ive got a stock IX turbo being shipped to me on Monday. When it gets hear I would like to verify that it is in fact a IX turbo and that it is in fine condition.
What markings or serial number could I look for? What should i check besides if the shaft has any play on it and grinding etc?
Any suggestions would help!
Thanks
-Ethan
Offline
Oct 2, 2009, 08:18 AM
Personal Sales Rating: ( 4)
2003 Mitsubishi Lancer Evolution
Drives: 03 Mitsubishi Evolution
google search evo 8 turbo and evo 9 turbo. The differences are obvious in its size. Also on the 8 turbo it will say TD05HR-16G6C-9.8 and the 9 turbo will say TD05HR-16G6C-10.5
Pretty much the main differences is the compressor housing and turbine housing on the 9 turbo is bigger. Also 8 turbo's have 2 wastegate flaps whereas the 9 turbo only has 1.
__________________
FPRed - 880cc injectors - Walbro 255 - Comp 280's - Prostreet Adj. cam gears - Shep trans and t-case - ACT 6 puck - EPM o2 dump - Ebay downpipe - HKS catback - ETS short route piping - Ebay fmic - 3" mafless intake - Tien S-tech's - ARP headstuds - AEM Tru Boost - AEM UEGO
Stock block - Stock head - Speed Density
TTR tuned 435 hp & 355 tq - 93 octane
494 hp & 415 tq - Q-16
Offline
Oct 2, 2009, 08:21 AM
This is exactly what I was looking for! Thanks
What about making sure the turbo is in fine condition? I'm assuming it may be obvious. Looking for shaft play cracks bent compressor fins etc?
-Ethan
Offline
Oct 2, 2009, 08:24 AM
Personal Sales Rating: ( 18)
Drives: 2003 Evolution
Yeah, it's the same as any turbo. Check for shaft play, damaged fins, spin freely, etc.. But, if you are buying it and it's being shipped to you, it sounds like it will be too late at the time of getting it to do anything about it if it is damaged :P
__________________
?? @ ?? mph , ?? 60' - 2006 Evo RS "Lana"
11.010 @ 124.55 mph , 1.480 60' - 2003 Evo, stock turbo - sold
STM Tuned
Offline
Oct 2, 2009, 08:26 AM
Personal Sales Rating: ( 6)
Drives: '03 Evo 8
-Ethan
Yeah, shaft play and of course obvious damage to the compressor/turbine wheel is what you are looking for. The IX turbo has a bigger compressor housing. Also, some VIII turbos have a 10.5 hotside.
__________________
Evo Green/BR Stage 4+/Comp Cams 280/Exedy Twin Disk/ECUFlash
DCEVOCLUB.COM
Offline
Oct 2, 2009, 08:31 AM
Quote:
Great! Yeah Im aware that I may not be able to do anything at that time. Its just for me to asses the seller to help other people decide his legitimacy and decide if im going to install it or not. Just want to know what Im looking at. I mean ill obviously be able to tell if its
A. a trubo
B. larger than my VIII 9.8 etc.
I just wanted to make sure it wasn't something else.
Thanks for the help guys!
-Ethan
Offline
Oct 2, 2009, 10:39 AM
Personal Sales Rating: ( 34)
Drives: 06 IX MR
Yes, but it still has double flappers I'm pretty sure.
Offline
Oct 2, 2009, 10:41 AM
Personal Sales Rating: ( 22)
Drives: Evo V///, DSM, GSXR 1000, KDX 80
Quote:
Evo 8 10.5 is a single flapper.
Offline
Oct 2, 2009, 10:46 AM
best way to tell is the size of the compressor housing and the stamped info on it unless it's been ground off
__________________
Offline
Oct 2, 2009, 01:28 PM
Personal Sales Rating: ( 0)
and you dont want a turbo wit the numbers ground off.....
__________________
WTB: EVO8 or 9.
Offline
Tags
105, 1x, 200, evo, evo9, hotside, identify, ix, number, play, serial, shaft, size, stage, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
