Throwout bearing removal
I just want to clarify in case I actually didn't remove the TOB. When you pry the TOB away, should the clutch fork easily engage from position A to B? Before this, I had to use force to slide the clutch fork over, so think i did it right. It started getting dark when I did it and using the flashlight, it "looks" seperated. Thanks.
It's a pain in the a$$ the first time doing it, but once you get a better understanding how it all comes apart/goes together it becomes easier. Going to a twin/triple with a HRB makes that part of the job a whole lot easier
kyoo
23
Oct 29, 2017 09:32 AM
SQ2Evo
12
Feb 16, 2013 08:43 AM
