Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
New! Use your Facebook to securely log into this site, click logo to login
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 27, 2009, 10:04 PM   #1
Personal Sales Rating: (17)
2003 Mitsubishi Lancer Evolution
project_skyline's Avatar
Drives: 03 EVO8, 05 R6
Send a message via MSN to project_skyline
Spark plugs on e85
So a while ago I was reading on NASIOC and one of the big time subaru tuners was talking about how colder plugs on e85 can make less power.
He explained how e85 already runs cooler EGT's and running colder plugs just make it harder to ignite things off.
I know we are talking about completely two different engines so I thought I would see if this had the same affect with 4G63's.
Does colder plugs affect power at all with e85?
Whats the best heat range for EVO 8's and EVO 9's?
Offline
Old Sep 28, 2009, 07:08 AM   #2
Personal Sales Rating: (59)
CO_VR4's Avatar
Drives: 2003 Evo VIII
When using E85, most of the guys I know have found that you need to move to at least one range "hotter" plugs than you would if you were using gas. Here in Colorado, Lucas Gaines mentioned that to me last week, and so did Jake L., who was tuning my car at Lucas's Superflow dyno, and who has been running E85 on a 750+ HP 4g63 2G road race car for quite some time...
Offline
Old Sep 28, 2009, 08:55 AM   #3
Personal Sales Rating: (1)
I have been having a ton of misfire issues on e85 at 25ish psi even with a Dyna ARC2 and I use BR8ES plugs. I might switch back to stockies and see how that works.
Offline
Old Sep 28, 2009, 08:59 AM   #4
Personal Sales Rating: (2)
Drives: 2005 EVO VIII
I'm running stock plugs (actually 37,000 miles on the stock plugs) on E-85 30 psi (stock turbo, stock ignition) with no issues.
Offline
Old Sep 28, 2009, 09:08 AM   #5
Quote:
Well I hate you I have been having soo many ignition problems it isnt funny. What is the gap on your plugs?
Offline
Old Sep 28, 2009, 09:23 AM   #6
Stock gap (never measured...whatever the stock iridiums come gapped as). I took them out once to check them and they looked fine.
I do plan to change them out for another set of stockers due to the mileage, but everything seems to be working fine.
Offline
Old Sep 28, 2009, 09:41 AM   #7
Personal Sales Rating: (4)
97TSiAWD's Avatar
Drives: '06 MR
Send a message via AIM to 97TSiAWD
Quote:
Interesting; I had never thought of that or read that anywhere. I just recently switched to the Denso IKH24 plugs (one step colder than stock) after running the stock iridium plugs for 21K miles. So far I haven't noticed any ill effects running 32psi on an FP Red, but this will have to be something to keep in mind.
__________________
-Jon
'06 Lancer Evolution IX MR
'04 Honda S2000
Offline
Old Sep 28, 2009, 05:52 PM   #8
Personal Sales Rating: (10)
KenMasters's Avatar
Drives: 03 VIII, 04 Grand Cherokee, 72 Cheyenne
Stock plugs on e85 here, no problems for three years.
__________________
e85 FPgreen S1 405/396 www.macautosport.com
Offline
Old Sep 28, 2009, 06:01 PM   #9
Personal Sales Rating: (0)
TO BE CONTINUED's Avatar
Drives: EVO 9
We tested the 1 step colder plus on E85 30psi on a stock block 35r and found that it would constently missfire at the top end switched the car back to the stock plugs and problem solved
__________________
EIP Racing
Built/Tuned By: Paul Wang Piloted by Chris N.
[size=3]]
13.2 / 12.2 / 11.7 / 11.5 / 11.2 The Countdown Continues
Offline
Old Sep 28, 2009, 06:14 PM   #10
Silver Sponsor
Personal Sales Rating: (22)
JohnBradley's Avatar
Drives: 06 Rally Red MR
7s at .020 work for misfire free operation at 45psi on a 4202.
__________________
SparkTech The ignition of EnglishRacing
Extreme Turbo Systems
EnglishRacing contact us-sales@englishracing.net
1118whp 2.0l gasoline record
New Build
2.4 numbers- 623/477 @ 25.7psi 92oct. -- 794/561 @ 38psi E85 All on the STOCK ECU
AMR Engineering Coilovers
MAGNUS Motorsport Cast Manifolds
We only choose GSC cams
FIC Master Distributor
OmniPower Dealer
Offline
Old Sep 28, 2009, 07:00 PM   #11
Personal Sales Rating: (38)
recompile's Avatar
Drives: '06 RR Evo IX SSL
Send a message via AIM to recompile
Quote:
Good to know... so stock IX plugs are fine, yes?
__________________
RR 06 Evo IX SSL | 9:1 2.0L | PT6262 | AGP FMIC | ETS ICP | FP 4R | HFS-1 | QTP ECO | 550whp (DynoJet)
RR 00 Camaro Z28 | SSRA | Lid | SLP UD | P TB & ME | LS6 IM | MS3 | PS LT | LPP TD | ???whp
I will never buy an ACT product again. Find out why, read this.
Training Videos: How to tune an Evo with EcuFlash
Offline
Old Sep 28, 2009, 07:01 PM   #12
Silver Sponsor
All we use
The IX plug is still a heatrange 7 and the gap is the same as the VIII and 1G that we run the BPR7EIX at, that was what I was referring to. The ILR7H is the same except that it is 1/4" longer or so than the BPR7.
__________________
New Build
OmniPower Dealer
Offline
Old Sep 28, 2009, 07:50 PM   #13
Good stuff to know!
Offline
Old Oct 1, 2009, 09:29 PM   #14
Drives: 03 Evo VIII
i was told to go with the NGK bp8
Offline
Tags
4g63, 750hp, e85, plugs, reading, running, spark
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
