Oct 10, 2009, 06:50 AM
#31
Personal Sales Rating: ( 33)
Drives: 04 RS and 08 GSR
I mentioned the issues that I had with the Swain coating flaking to Chad B and they have seem the same thing with the coating flaking on cast manifolds with cars that see heavy track use. Again, it was fine on my car for a couple of years of street driving. It was the track that made it flake down to the gray undercoating, on both the manifold and my turbine housing. For those who mainly drive on the street/drag strip or just do a light track day here and there, it's not going to be an issue.
__________________
RichJ
2004 RS - FP Red, stock ECU w/SD, 464 whp on 93 oct (BR dyno)
Redline TA Summit Point track record - Street Class
Many thanks to Buschur Racing, tephra, jcsbanks, mrfred, l2r99gst and my wife!
Offline
Oct 10, 2009, 08:56 AM
#32
Personal Sales Rating: ( 22)
Drives: a Black 3wd Beast
Why not just go this route? So far no flaking/etc for me. Excellent price as well from MAP.
MAPerformance's coated megan 02
__________________
ROBISPEC///
Buschur Racing
E85
Offline
Oct 10, 2009, 05:10 PM
#33
Silver VendorEvoM Guru
Personal Sales Rating: ( 65)
Drives: Old Man with a 03' EVO VIII, 05' Subaru 2.5GT Limited, 06' Kawa Z1000, 02' Kawa ZR-7s, 07' GSXR 1000 (babysitting lil' brother's ride while he's in the sand box), 00' Integra Type R SOLD
Wonder if there is any thremal shock merit to the raining in the hood vent theory. I have no experience with this particular coating and a car with a vented hood, nor directly exposed to the elements.
HOWEVER, any of you guys contact them after the stuff flaked? I've had the same happen on another coating mentioned here, but just chalked it up the the manifold being removed a couple times, and a no touch automated car wash or two.
Again, any coating from one of our reputable vendors here should suffice for Average Joe's purposes.
__________________
Contact me for parts -n- installs!
Best deals on All Megan products!! Megan Evo X turbobacks and O2 housings!!! OE TYPE replacement rotors-n-pads DEAL. I'm only available 8am-12pm Central Tues-Sat, available all day Sun/Mon. Currently only accepting PayPal, all sales final, customer warranty claims processed directly through the original manufacturer. All shipping quoted for the contiguous 48 states.
Offline
Oct 12, 2009, 11:52 AM
#34
Personal Sales Rating: ( 18)
Drives: A Black Mamba in kill mode all day 'eh day as when I hit the gas she goes fast!
Quote:
I like how this sounds as I've been looking at the Buschur jet coating option. I'm not fond of sending the manifold to Ohio and would prefer to keep things as local as possible. I might have to check out TCC in San Antonio as I'm stationed at Fort Hood.
__________________
--- Black Mamba tuned by the NTEC mad scientist with a bunch of "go fast" parts while diggin' in some V8 ass spittin' E85 venom! ---
Offline
Oct 12, 2009, 03:44 PM
#35
Probably a good option for you then... xRoguex seems to have had good results thus far.
I really mis-spoke when I said "any coating". There are really very few actual "coatings" being used for the most part (SwainTech a side). Just lots of different people using them. This tells me that prep and application are really what set them a part. So what you want to look for is people with a good track record on their "work".
__________________
Offline
Oct 12, 2009, 04:00 PM
#36
Personal Sales Rating: ( 0)
Drives: N/A
That is correct, how you prep the part and application are 2 major factors in a ceramic coating that "works" and one that doesn't. If you have your car painted with an expensive paint but the prep is not done properly, your paint will flake and have other issues no matter how expensive it is.
Look around and see what works and what doesn't.
Just as with anything else, you get what you pay for.
One thing to keep in mind is that the "chrome" ceramic is only good up to 1,200 deg F. This is something I see companies offering for turbocharged engines when temperatures will be in the 1,700 degree range. This chrome looks nice and pretty at the beginning, but will slowly turn colors and lose it's shine.
___
Carlos Tirado
Tirado Custom Coatings
Offline
Oct 12, 2009, 06:19 PM
#37
Drives: E92 335, E65 750
A lot of the things we see at my work don't apply to your average tuner car so I'm not sure this would either but, we have actually had issues with some coatings that are really effective at containing heat in a part causing the combustion chamber to heat up enough to negatively effect the tune vs a non coated header.
Just a little food for thought.
__________________
Born to lose and destined to fail
Offline
Oct 12, 2009, 06:46 PM
#38
Personal Sales Rating: ( 2)
Drives: '06 WW IX MR
___
Carlos Tirado
Carlos,
As a consumer that's wanting to get a part coated, what can we do on our side, before sending it over, to prep the item being coated. I know that the company coating the part should absolutely prep the item, but I'm sure there are people like me whom are anal, and want to be certain we at least do our part.
Thanks.
-Jalal
__________________
TeamXXXRacing|Northeast Motorsports Club|Online Store
TriStateEvo|http://forums.tristateevo.com/index.php
XBOX Live Gamer Tag: MJ23FE
THE WANT LIST
POWER
Full Re-Tune
BRAKES
SmikeEvo Pad Combo
Performance Friction 2-piece Front Rotors
SUSPENSION/CHASSIS
Whiteline Sway Bar Set - 26mm Fixed Front/24mm Adjustable Rear
Perrin Stout Mounts
Perrin Positive Steering Response System
Offline
Oct 12, 2009, 11:14 PM
#39
Drives: N/A
Quote:
Originally Posted by MJ23FE
Carlos,
Thanks.
-Jalal
Honestly,
There is really nothing a customer should have to do before sending in their part to be coated.
This is the same even if the part being sent in is used (carbon buildup). This will differ with companies though, as some will charge you more for used parts, or parts that have old coatings etc.
The way I see it, why charge somebody more for something that has to be done regardless if it's used or not
___
Carlos Tirado
Offline
Tags
ceramic, coat, coating, coatingf, cost, difference, headers, manifold, nj, noticeable, stm, swain, swaine, swaintech, tech  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
