Sounds like the thermostat. But if you change the thermostat and it keeps over heating it may be the temperature sensor. Also if the spark plugs are not correctly gapped, it will tend to make the car overheat. I suggest pulling the spark plugs out and re-gapping them also.
__________________
Wooooooshhhhhhhhhhhhhhhhh
SARD 660cc injectors, SARD 255cc fuel pump, Buddy Club Cams 264/272, HKS Gears, 3'' Turbo Back Exhaust, Dyno Tuned at 23 psi, EVO 9 BOV, K&N Drop in filter, HKS Down Pipe.
