Sep 22, 2009, 12:47 AM
Personal Sales Rating: ( 0)
Drives: IX MR
I had this exact thing happen on a 924 porsche turbo, I know, rat car of the Porsche world. Friends car, but the cat didn't rattle. The honey comb material inside still got plugged. What I did was use the test port ahead of the cat as a port to measure pressure with a gauge. Set that up on there, start the car, rev it up to 4k, no load. I got 8 pounds pressure, and that was enough to make me check into that further. Put a test pipe in, problem solved. I guess you could drive the car and I'm sure when under load you'd get a much higher # then if the cat is plugged.
Offline
Sep 22, 2009, 12:53 AM
Personal Sales Rating: ( 4)
Drives: 1987 RX-7 sold, 1993 RX-7 sold, 1996 cobra sold, 1999 F350 sold, 2006 Evilution IX
He didn't change the plugs to long ago did he?
Offline
Sep 22, 2009, 01:11 AM
Personal Sales Rating: ( 8)
Drives: EVO VIII w/ SSL
we changed the plugs at the last oil change...BPR7ES...and we are going to change them again this oil change that we're goin to do this weekend...
__________________
MAPerformance o2 Dump
Megan Racing Downpipe
RacingSports Testpipe
ExoticSpeed Catback
Walbro 255 Fuel Pump
Cusco Twin Disk
Buschur Racing Shifter Bushings
Buschur Racing SS Clutchline
Forge UNOS MBC
OBX-R FMIC
AMS LICP
JDM IX BOV
CajunPower T-Bolt Clamps
Spectre SS Filter w/ Adapter
Beatrush Engine Roll Stopper
K U N i i i Z Z Z E E E Dial-In
Offline
Sep 22, 2009, 04:30 AM
bump before i FINALLY get some sleep...lol
__________________
ExoticSpeed Catback
Cusco Twin Disk
Forge UNOS MBC
OBX-R FMIC
AMS LICP
JDM IX BOV
Offline
Sep 22, 2009, 06:41 AM
If you didn't gap them right that would make it drive like that at WOT. I wouldn't gap higher then .24. My little brother tried to gap his at .26 and at WOT, It wouldn't run right. But driving normal there was no problem. Hope this maybe helps  Good luck
Offline
Sep 22, 2009, 04:30 PM
i got that on lock already...its something other than that...i hope it is just a clogged cat...
bump for other thoughts!!!
__________________
ExoticSpeed Catback
Cusco Twin Disk
Forge UNOS MBC
OBX-R FMIC
AMS LICP
JDM IX BOV
Offline
Sep 24, 2009, 10:17 AM
any more thoughts?
__________________
ExoticSpeed Catback
Cusco Twin Disk
Forge UNOS MBC
OBX-R FMIC
AMS LICP
JDM IX BOV
Offline
Sep 24, 2009, 10:28 AM
Drives: VIII RS
Check your IC pipes and couplings for a boost leak. I had the same thing happen to me. I bought T-clamps and never happened again.
__________________
HKS 280/280, HKS UICP, HKS RS intake
Vishnu xede/ AMS TUNED
Perrin TBE/test pipe
ACT HD 355hp/318awtq
Offline
Sep 24, 2009, 11:00 AM
Personal Sales Rating: ( 2)
Drives: EB IX
Another vote here for clogged cat. Sounds like the exact same symptoms ive seen a few times related to clogged cat. It might not even rattle.
__________________
'06 EB IX - Perrin/Hallman/ECS Tuned: 300WHP
Thanks to the USPS for purchasing my mods by hitting me with your truck!
Offline
Tags
20, asap, barely, car, evo, exoticspeed, fuel, gear, green, moves, obx, past, prelude, psi, pump, racing, sputters, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
