Sep 19, 2009, 01:26 AM
Personal Sales Rating: ( 8)
Drives: JDM Evo VII
Idle Problem?help
I need to change my rpm to bump it up.
With AC on and pulling up to a stop light, I take it out of gear and rpm drops too low, sometimes it shut down.....I cleaned the TB and everything and same thing..I Messed with the screw on the TB and it seemed to help a lil but now when coming to a stp the RPM stays on the 1400-1600 range for a bit then comes down..I know that this screw is for setting the TB closed position, I want to set it to the stock position again,Should I turn in Counter or Clock? how far? are ur cars idle controlled by the ecu?
where should the idle should be? the adjustment must be done with the AC?
What could be the cause of this Stalling?
thanks
__________________
JDM VII GSR
3' Kakimoto Exhaust,FP WGA-Custom Intake-HKS Grounding-D-Jetro Power Fc-LICP-ACT Clutch-Manifold-Downpipe-o2 Housing
Hks 272/272 Walbro 255
368 Awhp @ 24Psi Tuned By C-Works Performance
Offline
Sep 19, 2009, 03:46 AM
Silver Sponsor
Personal Sales Rating: ( 10)
Drives: 04 SSL
What BOV? Are you venting to atmosphere? Is your Idle Speed Controller plugged in? Did you properly adjust the Throttle Position Sensor if you removed it?
As far as the idle screw, every car is set differently. For now a setting of about 800-900 with car warm is fine. Clockwise lowers idle, counter raises.
__________________
-Matt
http://www.SpoolinUp.com
Check out the New DIY section.
Affordable COP Kits - Used Coils in stock!
"Performance without the Price Tag"
Offline
Sep 19, 2009, 09:23 AM
Drives: JDM Evo VII
Yep everything is plugged in, I got a hks recirculating,this happens out of boost,any other suggestions? What about the udle controlled by the ecu?
__________________
JDM VII GSR
Offline
Sep 19, 2009, 09:43 AM
Personal Sales Rating: ( 0)
2003 Mitsubishi Lancer Evolution
Drives: ford f350/ 2003 evo 8
my car goes into low idle due to cams and BOV dumping to the atmosphere but it never shuts off, I think it could just be the idle screw
Offline
Sep 20, 2009, 12:19 AM
Personal Sales Rating: ( 1)
Drives: WW Evo 9, 07 4Runner SE
mine does the exact same thing ever since it was tuned last. What could it be?
__________________
FP Green cornfed:Reese Tuned!!
Offline
Sep 20, 2009, 01:58 AM
Personal Sales Rating: ( 2)
Drives: 2006 Evolution IX MR, 1998 Honda Prelude
To the OP are you running cams?
__________________
06 Apex Silver MR
80MM FP Green - Ported 73HTA
HKS 272 Cams
Precision 1200cc Injectors
Walbro 255 lph
Hallman Pro RX MBC @30 psi
ARP Headstuds / Conrod bolts
Injen UICP/LICP
Injen Ram Intake - K&N Cone
APS TV BOV
Greddy Spec-V FMIC
Greddy Turbo Headers
ARC Titanium Catback Exhaust
Megan Radiator
Megan O2 Housing - Ported
DC Sports downpipe/catdelete
Okada Projects Plasma Coils
Excedy Twin HD/ Fly
ROBISPEC/// KW3 Custom Clubsports
E-85 Ethanol
Offline
Sep 20, 2009, 11:31 PM
Drives: JDM Evo VII
nope n cams
__________________
JDM VII GSR
Offline
Tags
1998, 2006, evo, evolution, honda, idle, idling, issues, lancer, mitsubishi, prelude, problem, problems, screw, warm  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
