Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory TSB & Recalls
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old Sep 17, 2009, 08:48 PM   #1
Personal Sales Rating: (62)
2003 Mitsubishi Lancer Evolution
jid2's Avatar
Drives: 03 EVO VIII White
Copper Spray on Headgasket - Yay or Nay
Looking for thoughts on using copper spray when installing a new OEM head gasket...
Related to this thread.
The Correct Way to Install a Head Gasket?
__________________
jid2 Designed/Built/Tuned: Build Thread
POWERS: 2.3L - ETS GT3076R, Kelford 272's, BC springs, 1mm+ valves, FIC 1450's, Full-Blown dual Bros, BR IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 496hp/455 ft-lb, E85...
GRIPPING: Binary Lowered Recaro Seats, Girodisc 2-Piece, ST43's, SS lines, ATE fluid, KW V3's 10K/11K, jid2 flat-bottom, adjustable splitter, diffuser, GT wing, brake ducting, 18x9.5 +40 NT03's, 265/18/35 R888
BLOG: jid2 blog
Offline
Old Sep 17, 2009, 08:59 PM   #2
Personal Sales Rating: (74)
Garage is empty, add now
Drives: evo VII evo VII
keep it simple , mitsubishi makes a great gasket , install , make sure u torque correctly
Offline
Old Sep 17, 2009, 09:01 PM   #3
Personal Sales Rating: (18)
Drives: 03' Evo8, SL65 AMG, E55 AMG, 93' RX-7, 95' TSI, 92'TSI, 91'TSI x2, 92'GSX, 08' GSX-R, etc
I've done it before. I don't think it makes a difference and have had good results with and without a coat of copper spray. I think it is mostly preference.
Aaron
Offline
Old Sep 17, 2009, 09:15 PM   #4
Personal Sales Rating: (1)
hks-gst's Avatar
Drives: 98 Eclipse gsx 03 Evo VIII
Yes use it especially if your using a metal HG, Just try not to get any on the oil passages.
Offline
Old Sep 17, 2009, 09:17 PM   #5
EvoM Moderator
Personal Sales Rating: (10)
scheides's Avatar
Drives: BeaterX
Don't do it! Clean both surfaces, install headstuds (wait a bit then re-tighten them, get the fluid out from underneath them!), install gasket, head, and torque to spec. I have done a HG twice on my car, first time I used copper spray. Here's the problem (I think it may have been TTP that pointed this out to me): when I took the head off the second time, about 6-months later, most of the copper was gone. Where did it go? Into my coolant and oil, that's where.
Also, think twice about re-using arp head studs. I re-did mine because I had lifted the head the first time and one of the bolts stretched. Everyone says to re-use arps but turns out everyone is wrong, you should not under these circumstances. I ended up doing AMS/TMS L19's to eliminate this as a potential issue. I know this second part is OT but I feel its valuable info I've learned.
Offline
Old Sep 18, 2009, 06:28 AM   #6
Personal Sales Rating: (465)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
Correct. Do not use copper spray. It ends up clogging up your heater core and can cause a coolant leak in the interior of the car near the pedals
Offline
Old Sep 18, 2009, 06:34 AM   #7
Drives: Blue 2004 Evo,
Works on old school american iron--no, it isnt going to work on aluminum head Iron block apps.
Offline
Old Sep 18, 2009, 08:12 AM   #8
jid2's Avatar
Good input.
I'm using L19's this time around.
__________________
BLOG: jid2 blog
Offline
Old Sep 18, 2009, 08:19 AM   #9
Personal Sales Rating: (91)
DynoFlash's Avatar
Drives: 9.50 @ 148 (no nos)
Quote:
Aaron
Agreed
Offline
Old Sep 19, 2009, 03:36 PM   #10
Personal Sales Rating: (8)
03whitegsr's Avatar
Drives: EVO 8
I'll be doing a HG and studs in the next week or two when I put my ported head on. I will be going without copper. But I am lapping the head surface.
Since it was mentioned, I've always considered ARPs to be a 1 time use item. I also over torque them though as other wise, they offer very little benefits over the stock hardware. That's my motivation for replacing them. L19s on the other hand you can get tight enough without stretching them past 75% of the way to yield.
Offline
Old Sep 19, 2009, 05:52 PM   #11
Personal Sales Rating: (15)
2005 Mitsubishi Lancer Evolution
xRoguex's Avatar
Drives: 2005 Evo SSL
Send a message via AIM to xRoguex
Quote:
only if you glob it on like a retard. wow.
I have used it on all of my builds. I think the result is - a long lasting seal. The copper spray really resists oil and coolant from penetrating the gap over extended time.
__________________
05' Evo 8 SSL
: : Serenity : :
Buschur Powered
BR 2.4 - #001
Jan 2010
433/444 - 93pump w/FP Red - BR Mustang Dyno
Retune 10/2010
J&S Mustang Dyno
481/444 - 93 pump - FP Black
Retune - Speed Density
Tscompusa
490/457 93 - FP Black
Offline
Old Sep 19, 2009, 06:24 PM   #12
Copper spray a gasket is not designed to stay in place while coolant and oil flows through it at high temperature. It WILL ALWAYS come loose and end up in other places in your coolant and oiling systems.
We have learned from experience and will never again use copper spray. At best it is a band aid for heads that are not flat and should be decked in the first place for proper seal.
Offline
Old Sep 19, 2009, 07:02 PM   #13
Personal Sales Rating: (21)
Drives: '06 Evo MR, '13 Accord V6, '13 CBR500r
Quote:
Any experience
I've used it for years on my VW, but that is also because I stacked OEM gaskets....
I wouldn't use it on a regular application for your EVO, there is no point in my opinion.
Offline
Old Sep 20, 2009, 02:30 PM   #14
xRoguex's Avatar
Well - I wouldnt buy one of your motors anyways.
And the company I would purchase from - said it was quite fine.
__________________
05' Evo 8 SSL
: : Serenity : :
Buschur Powered
BR 2.4 - #001
Jan 2010
Retune 10/2010
J&S Mustang Dyno
Tscompusa
Offline
Old Sep 20, 2009, 02:55 PM   #15
We do not sell built longblocks. A properly built shortblock and a flat head does not require spray to get it to seal.
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
coat, cooper, copper, evolutionm, gasket, head, headgasket, headgaskets, install, installing, intake, kw, metal, seal, sealant, spray
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
