Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 19, 2009, 01:17 PM   #31
Personal Sales Rating: (4)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
With the Synapse, there are no spring changes, no adjustments, nothing. You just put it in and go. We put 40psi to mine and it is dead silent - no leaks.
__________________
Ted B. Spec JAM Long Rod 2.0L - Headway Performance CNC Head & Valvetrain - DI Intake Manifold - 75mm Hypertune TB - HTA3582R Twin Scroll T4 - Machined 12mm lift Billet Cams - MPFab twinscroll T4 Manifold, TBE, UICP, LICP - MPFab Race FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Graphite Dual Disc
Offline
Old Sep 19, 2009, 01:21 PM   #32
Personal Sales Rating: (0)
Drives: V///
The synapse is great, but if you live in a emission nazi state like california seeing the synapse is a trip to the smog ref and heavy fee's the samco bov in black or forge in black. Are good if your going for stealth since the synapse is somewhat chunky.
Offline
Old Sep 19, 2009, 01:25 PM   #33
Personal Sales Rating: (6)
Drives: GG IX SE
Send a message via AIM to McLaren F1 2003
Quote:
Originally Posted by whtrice View Post
Depends on what application you use it in. Are you basically a stock setup or do you have a hardpipe for a UICP? For basically stock set ups you will require a recirc 1.25 inch adaptor piece to plumb it into your UICP hose. I tye wrap all the hoses and a "T" fitting is required to plumb into the boost signal line from your turbo outlet pipe. This is the one that goes to my boost control solenoid.
yes, im still using the stock uicp and bpv
Quote:
luckily we dont have to worry about that here haha
i will look into the synapse when i switch to e85 and start running more boost
__________________
AEM / ACT / Defi / GReddy / MIL.SPEC / Perrin / Speed Element / Swain Tech Coatings / Walbro
eD NINe.2X powering 2 X 13 Ov.2 ~ 600w
www.myspace.com/mclarenf12003
4wstuned! 320/313 DLL
Offline
Old Sep 19, 2009, 06:06 PM   #34
ronitlancer's Avatar
Send a message via AIM to ronitlancer
I am thinking of going with Forge simply cause it is black and stealth, but all these "Gurus" talking about the Synapse is making me wonder. Although my engine bay is pretty stock looking.
__________________
ETS Black 3.5" FMIC, Nisei IC Piping, Walbro Pump, Perrin Intake, Buschur TBE, Swift Springs -- UNTUNED
Offline
Old Sep 19, 2009, 08:46 PM   #35
Personal Sales Rating: (33)
mrfred's Avatar
Drives: Evo IX MR
Quote:
Read up on the Forge. It holds boost fine, but it often causes bad flutter.
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Online
Old Sep 20, 2009, 02:34 AM   #36
the Synapse honestly confuses me
__________________
Offline
Old Sep 20, 2009, 03:14 AM   #37
I did some more research on it, seems like it has flutter/jumpy issues just like any of the BOVs. half of the people responded with 100% no problems, and the other half said they get some surge, a lot of flutter on the highway, and a lot of bucking in part-throttle situations.
So what makes the Synapse better?
__________________
Offline
Old Sep 20, 2009, 03:32 AM   #38
Silver Sponsor
Personal Sales Rating: (10)
Drives: 04 SSL
What PSI are you running? Hows the driveability, what made you choose the Perrin?
Oops I mis spoke. I am running the Samco. Only about 25 psi, but the drivability is a bit better and I hate the sound of BOV's (its as quiet as stock and fits like stock). It is known to hold higher psi well. Running medium spring. If you have an aftermarket ignition there is no cruise flutter as well!
As far as thje Forge, I suspect that it only gets terrible reviews because the normal owner is too lazy to scroll through the million possible settings to get it tuned properly. It would only flutter a tad during cruise on the girlfriends car.
__________________
-Matt
http://www.SpoolinUp.com
Check out the New DIY section.
Affordable COP Kits - Used Coils in stock!
"Performance without the Price Tag"
Offline
Old Sep 20, 2009, 08:16 AM   #39
It doesn't flutter, creates no idle issues, needs no adjustment, and won't leak. There are three possible vacuum port arrangements. Find the one that works best for you (do a search) and you're done.
__________________
Offline
Old Sep 20, 2009, 02:40 PM   #40
Quote:
In the two major Synapse threads I found, there were quite a few people experiencing both flutter and bucking.
__________________
Offline
Old Sep 20, 2009, 03:03 PM   #41
Personal Sales Rating: (36)
Evoryder's Avatar
Drives: EVO METH MACHINE
Forge RS. I have tried MANY and the adjustability makes a huge difference(holds boost great)
I haven't tried the synapse, however, it does sound good.
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Old Sep 20, 2009, 03:17 PM   #42
Personal Sales Rating: (17)
fromWRXtoEVO's Avatar
Drives: 09 MB C63 AMG, 07 VW GLI Turbo(DSG),06 Evo IX SE. 95 Eclipse GSX... Evos gone!
Sort of hard to search for, but I am trying to find info on people running recirc BOVs with 28PSI or higher. How its holding the boost, if any sort of leak-stop/etc was needed. And how their driveability is.
I don't wanna go VTA cause the sound is just too much for me, and generally has worse driveability then Recirc.
Can users with a Recirc running 28+ give me some feedback on the sound/driveability/boost-holding of thier BOV and what type it is. Thanks
Please read, I created this topic a few years ago specifically with the info you are looking for:
stock Evo 9 BOV leaks exactly at 26-27psi
Carlos
__________________
Celebrating my 5th anniversary on this forum. Also 5 years now since I first picked my first Evo (Evo 8 MR), 4 years since I picked my new (second) GG Evo 9 and now 5 years later enjoying my third Evo(Evo IX SE with only 14000 miles) ..again!
Offline
Old Sep 20, 2009, 03:19 PM   #43
There are three possible ways to connect the vacuum ports. Find the best way for you, and it should be perfect. Those with smaller turbos tend to use a different setting than those with larger turbos, etc. I found perfection with A+B to the manifold and C to the UICP.
I had the Forge RS and ditched in favor of the Synpase.
FWIW, I realized two issues with the Forge design. The first that the tightest setting is required for over 30psi boost, and Forge states that ~34psi is the maximum it can hold regardless. The second is I found that setting gave the poorest overall drivability. The Synapse won't leak at 40+ psi and gives absolutely transparent drivability.
__________________
Offline
Old Sep 21, 2009, 02:04 PM   #44
I went ahead and ordered the Synapse in favor of you Gurus
We will see how it works for me.
__________________
Offline
Old Sep 21, 2009, 02:11 PM   #45
Tsurugi-san's Avatar
Drives: like I've got a pair.
I'm recirculating the Synapse BOV with 39 psi on the Red.
Rock solid!
C port to the turbo outlet pipe + A port to the intake mani + B port blocked.
__________________
Current Mods:
BR 2.0, Stage 3 head, FPred @ 39psi, Ptd/ctd Exh. mani, Ported Intake mani, WORKS 76mm DP w/ RTP, Tanabe Touring Medallion, Apexi filter, APS twin-vent, Aperture II TB, Cossie M2's, JAM lifters, BR Double Pumper, PTE 1200's, AMS fuel rail, Sparktech non-CDI, ETS LICP, Perrin FMIC, ETS UICP, Irragi HO Alt, Hallman Pro RX, Beatrush + CROX II, Whiteline kit, Tanabe Pro 5's, WORKS rear strut bar, LC-1, Defi's, JDM rear, UK badge, SE lip, Volk's, 522/473 on E85.
Tuned by Mellon
Offline
Tags
30, adjustments, bov, bpv, evo, forge, forum, hose, perrin, psi, race, recirc, recirculating, rs, synapse
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
