Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 17, 2009, 11:50 AM   #16
Gold Sponsor
Personal Sales Rating: (228)
Chris@nolimitmotors's Avatar
Drives: 04 evo(sold) 06 evo(sold), 06 gsxr600, 95 R33 GTR, 08 G37S, 05 AP2 08 X GSR E46 M3
Send a message via AIM to Chris@nolimitmotors
Synapse
__________________
NLM
1139 station road unit 1&8
Medford, NY 11763
Toll Free Ordering 1-866-381-4618
chris@nolimitmotorsport.com
AIM-Chrisnolimit
AWD Dyno Dynamics in house
Dyno tuning, installs and engines builds available
http://www.facebook.com/pages/No-Lim...rt/43752292114
Offline
Old Sep 17, 2009, 01:15 PM   #17
Personal Sales Rating: (0)
ronitlancer's Avatar
Send a message via AIM to ronitlancer
the Synapse looks universal, is it a breeze to install? Hows the driveability, I most likely will stick with the Forge or APS
__________________
ETS Black 3.5" FMIC, Nisei IC Piping, Walbro Pump, Perrin Intake, Buschur TBE, Swift Springs -- UNTUNED
Offline
Old Sep 17, 2009, 06:39 PM   #18
Personal Sales Rating: (2)
Drives: 2005 EVO VIII
I run the Synapse at 30 psi, stock turbo. Runs great...in my opinion the best DV out there.
Offline
Old Sep 17, 2009, 07:42 PM   #19
Personal Sales Rating: (8)
Drives: A paid off evo
Have the stock VIII valve and it holds whatever the compressor has to offer (has seen 32+ psi). I had to severely modify the part though. I drilled a hole so the port feels air below the diaghram and placed a 3 way, 2 pos solenoid in-line. The solenoid is driven by the existing IC spray relay and I set the flash tables to energize just below WOT and de-energize at half throttle. This basically makes the valve slam shut and lock out when needed and still maintains drivability with normal driving. It won't boost over 20 psi when I have the IC spray switch off allowing one more feature - a failsafe that de-energizes the solenoid with knock sensor activity (tephra patch)
Offline
Old Sep 17, 2009, 11:22 PM   #20
Personal Sales Rating: (1)
Weezy03's Avatar
Drives: 03 Evo
Send a message via AIM to Weezy03 Send a message via MSN to Weezy03
greddy RS over 28 psi here on a t67
__________________
95 TA - DD
03 Evo mods - 9sec9 Tuned Enough said..
Offline
Old Sep 18, 2009, 02:29 PM   #21
Personal Sales Rating: (33)
mrfred's Avatar
Drives: Evo IX MR
I've seen lots of good reviews (holds boost, no flutter) on the APS, but many people say it requires periodic disassembly and lubrication. I've seen many good reviews on the Synapse as well. No mention of needing maintenance, but it is a physically large unit and is somewhat of a challenge to fit in the stock BOV location (in recirc mode).
__________________
Amsoil cone filter :: cardboard cold air box :: AMS LICP :: MIL.SPEC TB seals :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: Wilson fuel rail :: FIC Bosch 1100s :: E85 :: GM BCS :: SpoolinUp COP :: self-tuned :: VDR 5.71, 340wtq/380whp MD mode, 375wtq/418 whp DJ mode, 40°F
Donations always appreciated. Use "wassana at toloczko dot com".
Offline
Old Sep 18, 2009, 06:53 PM   #22
Personal Sales Rating: (3)
whtrice's Avatar
Drives: 06 EVO WW RS
I recently installed the Synapse unit and have been impressed with the way it holds boost. Previously used a crushed Tomei BOV. I need to put it on the dyno again and have it checked...Bryan?
Offline
Old Sep 18, 2009, 07:02 PM   #23
Personal Sales Rating: (21)
warp9's Avatar
Drives: AWD Machines
Im on an OLD SCHOOL 1G DSM BOV! Held 28 PSI no problem. Recirc as well
__________________
2004 Evo RS Street Car
FP Red/Stock Motor/Stock ECU/Stock Maf
11.03 @ 123
11.34 @ 121 (93 Oct.)
FP Black in 2010
WARP9 Tuned
Offline
Old Sep 18, 2009, 07:04 PM   #24
Personal Sales Rating: (26)
evo@24psi's Avatar
Drives: 03 Evo 8
Forge @32 psi on a Green here. Everyday driven.
__________________
11.97@ 114.83 Stock Turbo, Stock Head, Stock Block, Stock Manifolds, Full Interior Pump Gas (93).
11.39@ 125.5 Evo Green, Stock Head (HKS 272 Cams), Stock Block, SMC Meth Kit @30psi Full Interior, Street Tires.
Waiting for Tires!!!
Offline
Old Sep 18, 2009, 07:06 PM   #25
Personal Sales Rating: (34)
2005 Mitsubishi Lancer Evolution
tweakdsm's Avatar
Drives: WW EVO RS
Send a message via AIM to tweakdsm
Go APS, expensive, hard to find used. but worth it every penny. from my experience.
__________________
EVO RS, - Powered by BR HTA35R-86 kit, 2.0 build by : APM RACiNG -
Offline
Old Sep 19, 2009, 05:04 AM   #26
Personal Sales Rating: (5)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
I've never seen any brand of BOV work as well as the Synapse unit. Why? Because the Synapse unit is completely transparent. It creates no drivability issues, is so fast that it is virtually inaudible, and cannot and does not leak under pressure. I've seen leaks and glitches with many others. With the Synapse piece, I just installed it and forgot it was even there. I can't ask for better than that.
__________________
Ted B. Spec JAM LR 2.0L - Headway Perf CNC Head - DI Int Man - 75mm Hypertune TB - HTA3582 TS 1.06 A/R T4 - 12mm lift Billet Cams - MPFab TS T4 Manifold, TBE, UICP, LICP - MPFab FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Super Twin P-Trim Clutch
Offline
Old Sep 19, 2009, 07:32 AM   #27
mrfred's Avatar
Drives: Evo IX MR
Quote:
I've been watching the BOV market for quite some time and reading reviews, and the Synapse is the one I would get too. Seems like it has excellent all around performance and at a great price.
__________________
Offline
Old Sep 19, 2009, 07:45 AM   #28
McLaren F1 2003's Avatar
Drives: GG IX SE
Send a message via AIM to McLaren F1 2003
whats the install like on the synapse unit? other than it being large, is there any other special things to do or buy to make it work?
__________________
AEM / ACT / Defi / GReddy / MIL.SPEC / Perrin / Speed Element / Swain Tech Coatings / Walbro
eD NINe.2X powering 2 X 13 Ov.2 ~ 600w
12.98 @ 106.58 with a 1.883 60'
Tuned by 20psiMR
Offline
Old Sep 19, 2009, 11:21 AM   #29
whtrice's Avatar
Depends on what application you use it in. Are you basically a stock setup or do you have a hardpipe for a UICP? For basically stock set ups you will require a recirc 1.25 inch adaptor piece to plumb it into your UICP hose. I tye wrap all the hoses and a "T" fitting is required to plumb into the boost signal line from your turbo outlet pipe. This is the one that goes to my boost control solenoid.
Quote:
Offline
Old Sep 19, 2009, 12:12 PM   #30
Drives: V///
I have a evo specific Samco recirculated bov, come with three spring's the meduim spring held my 32psi tune on a fp red just fine.
Offline
Tags
30, adjustments, bov, bpv, evo, forge, forum, hose, perrin, psi, race, recirc, recirculating, rs, synapse
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
