Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 11, 2009, 07:29 AM   #1
Personal Sales Rating: (0)
loCo eVo VIII's Avatar
Drives: 2003 Lancer Evolution VIII
Synapse BOV + HKS EVC Problem???
ok so i have a 03 VIII gsr...i was running a stock 8 turbo @ 24psi with a Synapse bov and a hks evc V as my boost controller....now the bov i had connected the "regular" way with port b going to a getting vacuum and port c boost only....the car ran pretty decent with almost consistant psi but never really quite the same...i jus blamed it on the EVC...i had some flutter partial throttle on the highway but it wasnt too bad so i didnt mind haha.........i do a lotta highway 5th gear cruising and stuff so flutter was kinda a issue....but last week my turbo took a **** and i upgraded to a stock IX turbo..on the first pull after the swap i hit 28.5psi now remember theres are the same settings that the stock 8 turbo would jussss make 24psi so after some tuning we were able to get it at 24 psi making good power but the thing is i would occasionaly spike higher like mid 25s/26psi and i have my warning set at 25psi so if it passes that it cuts the boost to 23.5 psi....but heres when the "problems" came in...THERES A LOT OF FLUTTER!!!! drivin around i c that this turbo is spooling pretty quick at 2500rpms and where as my 8 would start round 3k and on highways its killin me cause partial throttle it flutters alot!! so i did sum reasearch here and found a "Better" way to set up the bov...they said to jus put vacuum to port b and leave port a VTA so i did that and to be honest there is a lil less flutter but.....i would spike at like 26/27 psi!!! and this is with out changing settins on the EVC....now i turned the boost down and down kept doin pulls and i would get a couple of pulls at somewhat consistant(but lower like 21-22 psi and than bam another 26 or 27 wtf!! idk whats goin on idk if theres sumthing wrong with the bov or its not set up right or if sumthings wrong wit the evc or thats not set up right....this evc is a PITA and idk where to start to try and figure this out....but all i kno is i dont wanna do damage to my turbo or motor so i wanna get this figured out!!! is there anyone here thats running the synapse valve with a EBC??? any help/suggestion/comments would be great!!! thanks!!
Offline
Old Sep 11, 2009, 08:03 AM   #2
Personal Sales Rating: (101)
2005 Mitsubishi Lancer Evolution
jmelocik's Avatar
Location: Dusty, Hot plains of Afghanistan. See ya'll in a year
Drives: 05 Evo VIII, 02 Dodge Stratus, 73 VW Karmann Ghia
Hey! I'm running the Synapse DV with a Blitz SBC iD (EBC), I had some minor issues but found that most of them were from trying to "t" the line from the boost source to use it for both the Synapse and the boost controller.
You will need two seperate boost/ vacuum sources for the Synapse and the EBC. Once I disabled my EGR/FPR/Evap stuff I had plenty of sources for this and then the car ran great. Zero flutter. Shortly after doing this I switched to a larger frame turbo so obviously it was no longer even a concern.
Josh
__________________
Quote:
Originally Posted by Appauldd View Post
Think of your injectors as hand grenades.....if they are close...they're still effective.
Offline
Old Sep 11, 2009, 08:26 AM   #3
hey josh thats what i was thinking was a part of the issue my car has vacuum lines and Ts all over the place ive been wanting to clean it up but honestly im worried that ill mess it up haha
Offline
Old Sep 18, 2009, 06:38 AM   #4
Josh
you wouldnt happen to have pix on how u have it set up im lookin to fix mine up this weekend but dont really kno where else i can find boost only sources and stuff
Offline
Old Oct 2, 2009, 02:42 AM   #5
jmelocik's Avatar
Sorry it took me so long to reply, I'm in Afghanistan (U.S. Army) and don't get to check this everyday. I don't have many pics of the engine compartment or specific pics of the vacuum hose setup, when I get home in the spring/summer of 2010 I can see about documenting the setup.
Josh
__________________
Offline
Old Oct 2, 2009, 04:51 AM   #6
Personal Sales Rating: (27)
Fast_Freddie's Avatar
Drives: '05 Tarmac Black SSL VIII
Here is how I have mine set up with my Greddy Profec B Spec II (same solenoid)
Port B only back to the intake manifold
Port A vented
Port C T'd off the J-pipe nipple before the boost control solenoid
__________________
FP Red*Greddy ProfecB Spec II*HKS TT*Nesei Short Route IC Piping*Synapse BOV*COMP 272s*Injen Intercooler*AFE Power Dry Filter*R/TErnie Intake*R/TErnie FULL 3" O2 housing with V-band*R/TErnie Modified DCsports 3" Down/Test/Flexpipe with V-Band*Greddy Ti-C Exhaust*255lph*Tein S-Techs*18" Volk LE-28s*Progress 25mm Rear Sway*Project Mu pads*JDM Tails*Cusco Heat Shield*Mishimoto Radiator hoses/Cap*ARC shift knob*Injector Dynamics 1000cc...
Offline
Old Oct 20, 2009, 02:02 PM   #7
what j nipple? sry im dumb when it comes to all this haha
Offline
Tags
blow, boost, bov, evc, evcs, evo, flutter, hks, pipe, problems, source, synapse, synapsebov, turbo, valve
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
