Official Boomba 75mm Big Bore Throttle Body Review and Dynotesting by TTP!
Old Aug 28, 2009, 10:15 AM
TTP Engineering's Avatar
With the many changes and tests we have run on the 2005 Evo VIII thus far, we reached the point in our build where we believed the next bottleneck in the system would be the stock throttle body.
With the last segment of our reviews being the addition of the Magnus Motorsports V5 Cast Intake Manifold, the next smallest orifice in the system seemed to be the throttle body. About this time Boomba had their CNC machine cranking out all kinds of billet parts for many different vehicles.
Kris @ Boomba asked us to take a close look at their new Boomba 75mm Throttle Body for the Evo 7-8-9 pictured here:
Upon opening up the box, we were impressed with the packaging, finish and attention to detail put into this unit.
Taking an inventory of the items included with the purchase, we had an interchangeable stock manifold spacer, two sets of bolts for use with or without the stock spacer, and an inlet adapter for the full 3.125" inlet or the factory 65mm inlet. A 75mm composite gasket was also included for the manifold side.
An optional Boomba intake manifold spacer for the Mustang throttle body bolt pattern was also included in order to mate up to the enormous Magnus V5 Intake Manifold.
One of the excellent designs of the Boomba throttle body is the high pressure O-Ring on the back of the throttle body to adapter plate connection. This insures an airtight seal at ridiculously high boost pressures.
If you are using the larger 3.125" inlet flange, all you have to do is remove the four small allen head screws to release the O-Ring sealed flange on the intake pipe side. It is a very well engineered unit, easy to work with.
One issue we did initially run into was that the adapter plate for the Magnus Manifold fit the Boomba holes perfectly however.....
The the Magnus V5 Intake Manifold throttle body flange and phenolic spacer gasket was 5"x 5" and the Boomba Adapter Plate was 4" x 4".
After snapping a few pictures off and emailing them to Kris@Boomba, he had the newly cut adapter plate reworked and overnighted to us at TTP, so that we could resume our testing.
As you can see above in the picture, the Boomba orifice is much larger than the stock unit.
Here is a picture of the Boomba 75mm Throttle Body installed. Only red was available at the time, but it has a unique look to it.
Here is a close-up of the 3.25" to 2.5" reducing 90* coupler we used to retain the INJEN intake and intercooler pipes kit. We opted to use the 75mm throttle body flange on the Boomba 75mm Throttle Body.
From a different angle.
Anyhow, what most of the members of this site are looking for are the hard data numbers of how this Boomba 75MM Throttle Body actually performs so here goes...
The baseline run was made on the stock throttle body with 2.75 outlet to stock inlet size and below is the run shown:
The after test was done on the Boomba 75mm Throttle Body with 3.125" flange and 3.25" to 2.5" 90* reducing coupler. With no tuning changes, there were notable gains of 17whp or so and about the same in tq in given rpm ranges.
In the end, the Boomba 75mm Throttle Body is a superbly crafted piece, fits well, is designed well, holds insane amounts of boost, has a nice base idle adjustment screw and added about +17whp and the same in torque to our own test car.
With all of that said, the biggest benefit we have seen in day to day driving is throttle response! The Evo is faster responding now with the larger throttle body. It is a pleasure to drive with less lag time for the car to react on throttle position changes.
All in all, we like the Boomba 75mm Throttle Body and recommend it to anyone wanting to get the most out of their Evo.
TTP
TTP Engineering is offline
Old Aug 28, 2009, 10:26 AM
Import Junky's Avatar
Too big for stock framed turbos?
Import Junky is offline
Old Aug 28, 2009, 10:39 AM
We don't think so. There was another test on a stock Evo which reportedly gained 12whp.
Old Aug 29, 2009, 11:53 AM
TrackAttack78's Avatar
good stuff thanks for a great review
TrackAttack78 is offline
Old Aug 29, 2009, 12:05 PM
NsinEvo8's Avatar
I love that TB
NsinEvo8 is offline
Old Aug 29, 2009, 12:19 PM
MOREPSiTEHBETT4's Avatar
beautiful cnc piece, looks trick in red on the ttp evo. Sick gains for a throttle body = cheap horsepower that get's you that extra tenth you need
MOREPSiTEHBETT4 is offline
Old Aug 29, 2009, 12:26 PM
chaotichoax's Avatar
you have this same thread posted in the dyno tuning and review section
closed...
chaotichoax is offline
Boomba Racing
EvoX 'For Sale' External Engine / Power
104
Nov 24, 2015 11:32 AM
TTP Engineering
Evo X Dyno Results
31
Oct 26, 2009 02:27 PM
TTP Engineering
Evo X Dyno Results
15
Aug 4, 2009 09:59 AM
TTP Engineering
16
Mar 6, 2008 07:37 PM
Quick Reply: Official Boomba 75mm Big Bore Throttle Body Review and Dynotesting by TTP!
