Oct 18, 2009, 01:52 PM
#76
Silver Sponsor
Personal Sales Rating: ( 17)
Drives: 06 Rally Red MR
Quote:
Originally Posted by Taimur
The point people are missing is that does upgrading cams on IX seem to give a lot of power?
From what I've been reading that it is not a big gain...maybe ~20whp on a stock or red turbo.
To me that is not a big enough gain for the money being spent. I'll be upgrading to a PTE 5857 turbo and running it on a stock motor. The turbo will have plenty of power that the stock motor can handle.
Really depends on the turbo. We did a stock cam 3582HTA that made 430whp on stock cams at 26psi. By comparison I have had cars with S2s make high 400s (they were both SD) at the same boost level with the same turbo. On a Red the cams are worth 40-50whp. On the stock turbo they are typically worth about 30whp.
Offline
Oct 18, 2009, 03:05 PM
#77
Personal Sales Rating: ( 8)
Drives: 2006 WW Evolution IX, 87 Buick Grand National
if you can find a decent deal on a set of used cames in the 300 to 400 dollar ranger then that is a big enough gain for the money. If I could get 20whp for every 400 i spent on my car, I would be at 600whp by now.
__________________
2006 Wicked White EVO IXAMS Intercooler
AMS LICP
AMS MBC
Samco IC Hoses
GSC S1 Cams
Perrin Intake
Works Cast O2 Housing
Works Downpipe
Works Exhale Exhaust
Walbro GSS342 Fuel Pump
Okada Plasma Coils
Coming Soon:
FP Green 73HTA Turbo (Buschur Ported)
Buschur Ported Intake, Milspec 65mm TB, & Full Race Exhaust Manifold
Tuned with: KUNiiiZZZEEE Dial-IN!
WILL DO CAM AND OTHER INSTALLS IN EXCHANGE FOR PARTS. :D
Offline
Oct 18, 2009, 09:46 PM
#78
Personal Sales Rating: ( 3)
Drives: Evo 9 SSL
stock turbo, will s2 lose low end power compared to stock cams?
__________________
Sponsored by: APEX...Specializing in custom exhausts.
Powered by: KUNiiiZZZEEE Dial-IN!
Stock to Stud
Offline
Oct 22, 2009, 10:44 PM
#79
Personal Sales Rating: ( 7)
Drives: Evo 9 GSR
John bradley what sort of lag would we see in your opinion going from some S2 to kelford 280.
this is an a TS40r with 2.3,
I have the Kelfords and i am wondering if it worth it, as the car is now it not laggy at all with this turbo, and would rather not scarifice any more bottom end.
but if it only 100-150rpm then it worth it as the Kelfords 280's will make big top end.
Offline
Oct 23, 2009, 12:12 AM
#80
Personal Sales Rating: ( 1)
Drives: 2006 EVO IXMR
Quote:
You will lose a bit but not that noticeable. With the MIVEC you can get a good map that optimizes the cam's lowend
Aaron may have a different opionion on this topic but if you are going S2s to Kelford 280s you will lose a couple hundred but the kelfords still tend to produce good midrange surprisingly. You will feel the car come to life with that 280 and especially 7.5k+ over the S2. I say go big or go home! Look at your powerband! If you race someone your not going to be really worried about lowend. No one races someone from 3k... IMO the larger cam would be good for you. You also need to compare the lift between the two cams. I don't know the Kelford 280s lift off the top of my head but the 280 duration is basically moving the powerband to the right compared to the S2s. Let me know what you decide to due! This would be a good before and after dyno
Mikey
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Oct 23, 2009, 07:52 PM
#81
Personal Sales Rating: ( 21)
Drives: TB EVO IX MR, 2001 Integra Type-R, Porsche 1974 914 1.8 liter
Cams for me only smoothed out the curve for me. I didn't gain any peak at all. Gained 5-10 in a few spots, but not worth 1000+
__________________
331 WHP & 300 WTQ FPgreen w/ stock cams with a 100 Cell HFC on a Mustang Dyno on 91 octane
CBRD BBK installed and waiting for some Bryan@GST magic :P
t00ned by Bryan@GST Motorsports
Proud supporter of SPEEDELEMENT
Offline
Tags
5857, cams, evo, explain, ix, mbc, mivec, power, produce, turbo, upgraded  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
