FP Red Supporting Mod. bottlenecks...
I have just ordered an FP Red for my IX MR. I have the below listed power mods. How much of a bottleneck is the HFC, stock intake manifold, stock head (and springs) and stock ignition? For now, I'm just getting tuned for 93 oct. Later, I will add alcohol injection...
Ported and coated O2 housing and exhaust manifold
Buschur TBE w/HFC
Perrin Intake
Cosworth Cams
Exedy Twin
PTE 1000cc Injectors
AMS IC & Pipes
Thanks to all in advance.
Buschur TBE w/HFC
Perrin Intake
Cosworth Cams
Exedy Twin
AMS IC & Pipes
sounds like a great mod list, but to get the most out of the turbo,
valvetrain to rev with the powerband
test pipe
02 housing wastegate dump
port match the intake mani and throttle body
with all that on meth tuned, your looking at an easy high 400whp, and depending on the tuner and dyno you may even hit low 500's with an aggressive tune
test pipe
I've got a ported and coated exhaust manifold. I'm considering a MILSPEC HFC and MAPerformance ported stock intake manifold (rev2 or 3)... Later, with the Aquamist setup, I might add a Shearer exhaust manifold. You know how it is, you're never quite finished...
Buschur TBE w/HFC
Perrin Intake
Cosworth Cams
Exedy Twin
AMS IC & Pipes
Buschur TBE w/HFC
Perrin Intake
Cosworth Cams
Exedy Twin
AMS IC & Pipes
Thanks. I recently had my 60,000 mile service done along with my clutch and was talked into the Red. I really wasn't planning on touching the car until next Spring, but a conversation with the guys at the shop about the relative merits of the BBK Full and FP Red twisted my arm (and thus I twisted my wife's arm, figuratively)... Now I'm just trying to make sure I'm not half stepping...
i know thats a couple $100 list but. that would top off what your trying to do.
GL!!
When I got the 60,000 mile service, my belts were changed along with my head gasket, so I'm good to go on those fronts. Also, I forgot to mention I already have ARP headstuds and a Whinebro...
Are you on the stock FMIC??? If so, you'll need to upgrade that for sure with the Red if you plan on running a decent amount of boost (and you want to make power). The stock FMIC is fine for the stock turbo on relatively low boost, but can get heat soaked fairly quickly.
Good luck
Good luck
i would recommend springs and retainers as well. might as well if you want to get the most out of the high powerband and the cams. better safe now. nice mod list you will love the new found power with the red
