Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 19, 2009, 08:50 PM   #1
Personal Sales Rating: (38)
BluEVOIX's Avatar
Drives: 06 Blue EVO IX
Injectors leaking boost
Ok, did a boost leak with throttle body side capped and the intercooler pipes where all nice and tight.
Then I did a boost leak check with the whole system connected and found that the injectors, mainly the 3rd injector was leaking pressure. It actually starts leaking really bad after 14 psi. I removed the injector and the rubber ring looked ok visually but I guess I need to replace it.
Any one else have issues with their injectors not holding pressure at the manifold seal?
Any recommendations on where/which injector rubber o-rings to get? The ones that connect to the bottom to the manifold.
Also could the injectors be leaking due to the 2 black spacers that are between fuel rail mounting points being too thick?
__________________
2006 Blue EVO IX
Buschur Magnaflow TBE w/hfc
TTP Swain o2 housing & Vibrant Cone filter
CCI Stage 3 clutch
Blox Motor Mount
ShepTrans [Evo8 (3-5) gears]
Online
Old Aug 19, 2009, 08:55 PM   #2
BluEVOIX's Avatar
Found some at streettunedmotorsports
http://www.streettunedmotorsports.co...ator_rings.htm
But I'll check tomorrow if AMS has some in stock so I wont have to wait for shipping.
Man this was probably one of the last places I would have expected to find a leak. Sucks!
__________________
2006 Blue EVO IX
CCI Stage 3 clutch
Blox Motor Mount
Online
Old Aug 20, 2009, 03:37 AM   #3
Personal Sales Rating: (1)
sparky's Avatar
Drives: 2004 RS
blueEVOIX: Tell me again that your car''s intake tract is somehow interconnected with your fuel rail
__________________
Vishnu XEDE & camgears-Greddy 720's-ported Green-HKS 280/272-Forge WGA-AMS LICP-DC DP-Magnaflow Ti-Ralliart TS-Tomei Thermokiller - SSAC O2 - BR8ES-Nissei IC--SS clutch line-Endless(f) /Hawk(r) - WALBRO 255-ITG filter-Motul-KOYO radiator-SAMCO intake hose-UEGO-Autometer-Kartboys-Authority SS-MR DV.
DLL: 389WHP/25PSI on 93( non-corrected@3300' altitude). (No dynos in the jungle! Fortunately, there are carnivorous toads that feed on bats).
Offline
Old Aug 20, 2009, 05:35 AM   #4
Personal Sales Rating: (6)
AWD_Terror's Avatar
Drives: 05 EB evo
Quote:
Your injectors sit in your manifold. Your manifold sees boost/vac
He is talking about the manifold seals that the injectors sit in.
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
345WHP/322TQ on 23PSi on the "HeartBreaker" Mustang Dyno (old numbers)
Offline
Old Aug 20, 2009, 05:43 AM   #5
sparky's Avatar
Drives: 2004 RS
I guess that I'd better go out to the garage and pop the hood to take a look-see more often. I just can't visualize things anymore. But, you are absolutely right. Thanks for the heads-up!.....and, Duh!
__________________
Offline
Old Aug 20, 2009, 06:04 AM   #6
BluEVOIX's Avatar
Yes I was referring to the seals that sit between the injector and the intake manifold. They look to be in good condition visually, but do not hold pressure more than 13-14 psi and start leaking a pretty good amount after that.
I just ordered new seals and hopefully they hold up. If not I might shave the spacers found between the fuel rail to manifold connection to squeeze the injectors down to the manifold tighter.
So anyways, if you guys havent already done so, make sure you boost leak check with the throttle body and intake manifold connected. You might find some leaks there too.
__________________
2006 Blue EVO IX
CCI Stage 3 clutch
Blox Motor Mount
Online
Old Aug 20, 2009, 06:16 AM   #7
AWD_Terror's Avatar
Drives: 05 EB evo
deff good to do boost leaks every few months. I never realized I had a boost leak and had an enormous one at that
to your orig question, FIC makes these really good tight seals made from some space aged materials. lol.
Id check those out.
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
Offline
Old Aug 20, 2009, 08:20 AM   #8
BluEVOIX's Avatar
Id check those out.
At the moment I just ordered the stock seals from STM, but I will be getting FIC injectors when its time to upgrade my stockers.
__________________
2006 Blue EVO IX
CCI Stage 3 clutch
Blox Motor Mount
Online
Old Aug 20, 2009, 08:43 AM   #9
Silver Sponsor
Personal Sales Rating: (51)
EmeryatSTM's Avatar
Drives: 2005 evo
Those are in stock and will go out to you today. This is a very common place to find boost leaks.
-Em
__________________
STM TUNED.COM -- $2 SHIPPING ON EVERYTHING!
10.04 / 142: Fastest and Quickest Stock-Block Evo VIII ...in the GALAXY! Built at STM.
...STILL holding the record after a year and a half. How much can your tune handle?
Now add in a Buschur Motor, 9.6@156 and counting down!
- In House AWD Mustang Dyno
- Official Buschur Racing and AMS Dealer
- Need to pack some serious air into your turbo? STM Forward Facing Turbo Manifold
- Want pictures and videos? Click here!
- STM's You Tube Channel
Offline
Old Aug 20, 2009, 09:42 AM   #10
JKD
Personal Sales Rating: (10)
JKD's Avatar
Drives: 2002 Corvette ZO6
Those seals should take care of it.
__________________
2002 Electron Blue Corvette ZO6
www.fquick.com/jkdz28
Offline
Old Aug 20, 2009, 06:53 PM   #11
Personal Sales Rating: (3)
bbyevo8u's Avatar
Drives: *9 MR SE* ivey tuned.........sold: k7 gixxer 600, 03 350z stock, 04 evo8 cbe, 05 evo8 cbe, 06 sti cobb stg2 300whp
how hard is it to change out the seals?
__________________
PERRIN TBE W/TEST >< BUSCHUR CONE FILTER >< ETS INTERCOOLER KIT >< HALLMAN PRO MBC >< WALBRO 255 PUMP >< KELFORD 272's >< BEEHIVE SPRINGS >< INVIDIA EXHAUST MANIFOLD >< INVIDIA 02 HOUSING >< HDSS W/ACT STREETLITE FLYWHEEL >< FLUIDAMPR CRANK PULLEY >< ARP HEAD STUDS >< STIFF SHIFTER BUSHINGS >< SS CLUTCH LINE >< DUNLOP TIRES >< AEM WIDEBAND >< AUTOMETER BOOST GAUGE >< KOYO RAD >< KEVLAR BELTS >< ///IVEY TUNED - 350whp 352whq///
Offline
Old Aug 20, 2009, 08:38 PM   #12
Personal Sales Rating: (23)
EVO8emUp's Avatar
Drives: '05 MR
unbolt the fuel rail, and lift it out.
__________________
Tuned by Mellon
EVOLUTION VIII MR
Offline
Old Aug 20, 2009, 08:50 PM   #13
Personal Sales Rating: (8)
NsinEvo8's Avatar
Drives: EVO\\\, 4g64 Mighty max, Gmc Acadia, Yota Tundra
Definately fix that, you dont want to start a fire somehow..
__________________
380whp/340wtq Mustang dyno
Stock 8 turbo @25psi
E85 clean air vehicle (:
GST Motorsports tune
Offline
Old Aug 20, 2009, 09:57 PM   #14
BluEVOIX's Avatar
Quote:
Its not hard to do at all. There are 2 bolts that hold the fuel rail down to the manifold, and in turn the fuel rail squeezes the injectors against the manifold. All you have to do is remove that bolts, but be care full because there are spacers between the rail and manifold. Then you just lift the fuel rail and it should pull the injectors off the manifold.
You don't even have to disconnect the injectors from the harness. Just replace the seals and pop everything back together.
But one thing I noticed and didnt really like is the fuel rail doesnt seem to apply enough pressure to hold the injectors down. Maybe my seals are very worn thats why, but after replacing them and I find that the injectors are not tightly secured I might shave the spacers slightly to allow more torquing on the rail.
__________________
2006 Blue EVO IX
CCI Stage 3 clutch
Blox Motor Mount
Online
Old Aug 21, 2009, 06:09 AM   #15
SPECJUNK's Avatar
Drives: many
How big does a boost leak have to be before it concerns you, if the car makes boost like it should, but there is a 1/16" vacuum leak.................is that really a big concern?
if you look at the manifold vacuum and it is stilll making 17" at idle...what all the alarm for
Offline
Tags
boost, change, common, evo, fuel, injector, injectore, leak, leaking, mr, oring, places, racing, seals, vp, wheeling, wv
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
