Aug 17, 2009, 10:47 PM
Personal Sales Rating: ( 0)
Drives: '06 GG Evo IX
good ideas
Offline
Aug 17, 2009, 11:29 PM
Personal Sales Rating: ( 4)
Drives: 2005 Evo SSL
I have yet to see a ported stock manifold that even remotely competes with the work MAP did to mine. And I usually deal with Buschur - But comparing port work isnt even remotely possible.
I also struggled with the OP decision. F*ck megan. I have one -- I will GIVE to you - if you pay to ship it.. Oh.. and then you need to get it rewelded cuz it cracked 2342 times.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
FP 80mm Red, BR Race FMIC, BR 65mm TB, MAP Intake mani, BR 3" Exhaust, Megan O2, MAP Exhaust mani, Kelford 272's, Supertech Springs, Spoolin COP, HKS intake, HKS BOV, ECU controlled boost, Innovate WB, Defi Guages, Exedy Twin HD, ShepTrans and Xcase.
Sponsored by the USMC and US Army.
ROM - 96530006
Tuned by Asmodeus
Offline
Aug 17, 2009, 11:41 PM
Personal Sales Rating: ( 7)
Drives: 2003 Evolution VIII
The MAP exhaust manifold is by far the best port work I have seen on one of these manifolds.
Offline
Aug 18, 2009, 04:37 PM
Drives: N/A
MAP Ported Exhaust manifold hands down.
Offline
Aug 19, 2009, 04:08 PM
and where do i get one of those
Offline
Aug 19, 2009, 04:09 PM
one of those whats? lol
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Aug 19, 2009, 04:10 PM
that ported manifold. ?
Offline
Aug 19, 2009, 04:12 PM
its a stock manifold - that MAP ports -- and then I had sent to http://www.tiradocustomcoatings.com/
ANd now you have a very well flowing - ceramic coated/heat barrier manifold that looks sick and performs veryy well.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Aug 19, 2009, 04:13 PM
Drives: Evolution IX GSR EDM
BUSHUR POWER! (I'd go bushur if I were you)
Offline
Aug 19, 2009, 04:19 PM
i gotcha i just ment like what the hell is MAP? how do i send my mani to them?
Offline
Aug 19, 2009, 04:22 PM
Drives: N/A
Offline
Aug 19, 2009, 04:36 PM
Quote:
Typically I use them... Their port work is below par compared to MAP - Modern Automotive performance.
BR ported my FP red - and while they did ok... MAP's work is FAR superior - in both effort and quality.
My turbos outlet was rough and still had sharper angles then I would have liked to see.
My MAP manifold is polished smooth and the flow looks to be well thought out - and shaped.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Aug 19, 2009, 04:43 PM
Personal Sales Rating: ( 12)
Drives: 04 BBY Evo VIII
I just got mine done at Buschur and it's nowhere near as good as the MAP porting above.
__________________
Schreinerized
Shep trans, Exedy Twin Disk clutch, ETS intake, Walbro 255 fuel pump, TurboXS MBC, Buschur SCCA Magnaflow catback, Mil.Spec 100cell HFC, Megan downpipe, Buschur ported manifold, O2 housing, Innovate LC-1 wideband, Ohlins DFV coilovers, Hawk pads, JDM headlights and taillights
No longer modifying my car according to the SCCA's rulebook.
Offline
Aug 19, 2009, 05:38 PM
Quote:
MAP's work prior to my coating.
__________________
05' Evo 8 SSL
: : Serenity : :
Heavily Modified
ROM - 96530006
Tuned by Asmodeus
Offline
Aug 19, 2009, 06:24 PM
Drives: 03 evo 8 bby
im runnin the milspec ported exhaust manifold n i noticed good spool up improvement over stock....27psi on 91 octane fp red by 4200 rpms.... that give any help to what u should use....
__________________
espelir catback dc sports cat delete downpipe titek 3" 02 housing hks 272 cams xs engin fmic and piping 880 injectors 255 pump dejon tool greddy type rs bov tein lowering springs built 2.0 block je pistons eagle rods acl race bearings arp main head rod studs brian crower valvesprings and retainers stock valves fp red turbo balance shaft eliminator kit aem wideband gauge milspec exhaust manifold high pressure throttle body seals aem intake optima battery relocated to trunk
Offline
Tags
coat, evo, exhaust, forum, manifold, megan, polish, polishing, port, ports, stock  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
