Oct 1, 2009, 12:57 PM
#76
Silver Sponsor
Personal Sales Rating: ( 46)
Drives: LOT's'O'EVO's
Quote:
Originally Posted by DBallz
You have been in my car and I have nothing wrong with my turbo which was tuned for 28psi. I run 27psi just to play on the side of safety. I have the upgraded oil feed line and I haven't put it in yet but no failures to speak of. I think you worry too much. Really stop and think about it. You don't want to run meth so your not going to run extreme amount of boost pressure. So for you 25psi will be fine for you especially since you only want to run pump gas.
I had a question to you Chad. What type of bearing does the BBK use? If it uses the same style bearing wouldn't the BBK benefit from the FP oil feed from the filter? I know FP sugggest if running more then 25psi to use this oil feed. But don't you think if a customer was to run 30psi all day everyday that the BBK would experience the same bearing failure assuming your turbo uses the same style of bearing.
the BBK uses the stock ix internals
you have to consider larger wheels at higher boost are going to change the amount of load/thrust/etc that the catridge takes.... The bbk isnt a massively large turbo... and 30psi on a 40lbs/min turbo isnt the same as 30 psi on a 60lbs/min turbo!!
Cheers
cb
__________________
www.cbrdspeedfactory.com
Immaculately prepared facility... State of the Art equipment..
Proven Motorsports Background.. ALMS, Grand-Am, Open wheel...
www.ChadBlock.com
CBRD Radiators, BBK Turbos, Intercoolers, EVO X parts, and CBRD Time Attack EVO backed by Advan
The standard just became standard. Meeting expectations is now not acceptable... we must always exceed them.
Offline
Oct 1, 2009, 01:01 PM
#77
Personal Sales Rating: ( 2)
Drives: 2006 Evo IX, 2000 Impreza RST
If he was only going to run 25 psi wouldn't he be better off with something other then a red. From what I've read the red doesn't really come alive until 30 psi. So he might be better off with something like the HTA green or BBK full
Offline
Oct 1, 2009, 01:18 PM
#78
Personal Sales Rating: ( 5)
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Drives: 05 Apex Silver Version 8, 2001 GSX-R 1000
Quote:
I have been telling him from way back when that a BBK Full or HTA Green would better suit him. But I don't really know about the 25psi wouldn't be good for him. For example when my car was being tuned and the tuner was trying to dial in the boost controller he set a goal of 20psi which it held till redline. 20 psi I made 400 or 420. I like to go to the drag strip so I know this turbo is better for me. Plus my over all goal was 500-550 hp on stock engine and for me the Red was the perfect choice. The good thing about the BBK and HTA Green is spool up time is like lightning fast.
You know in all of this I feel bad for MAP and Tomei......no room left for those guys FP and CBRD has locked the stock appearing turbo market down. Great job Chad and Rob
__________________
Stock Block and Head
FP Red 80mm
Kelford 272's
Beehive Springs
Precision 1k injectors
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
PPI Extreme Ported Hotside, Exhaust Mani, Intake Mani, and TB
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
322.7 whp 320tq 21.5 psi on 93 oct
355.8 whp 430tq 25 psi on c16
Offline
Nov 2, 2009, 11:19 PM
#79
Personal Sales Rating: ( 33)
Drives: Evo IX MR
Quote:
Originally Posted by EVOEMS
2005 MR with full bolt ons, an in the process of aquiring a BBK full and FP Green HTA, Will be doing a 1/4 mile test and road course comparison test with the same driver, tuner and the closest conditions possible, to evaluate objective results. I have no preferance as to manufacturer, only looking fo input, as to varibles to consider. This will take some time to compile as FP has a 4-5 week delivery delay due to demand. Please give me some time, as I use the car as a dd as much as possible. Tests wil be done at Gateway International Raceway, in Illinois.I am an Old school, hot rodder,50 year old, no flame fests please, Much more fun smoking V8's.
Is this still on?
__________________
Works drop-in :: AMS LICP :: English Racing ported EM and HS :: Titek v2 O2 :: Helix v2 DP :: MIL.SPEC 100 cps cat :: RRE Stealth Stainless :: Walbro :: FIC 1050s :: E85 :: self-tuned :: 26.5 psi :: 340wtq/375whp VDR 5.71 EvoM mode, 77°F
Offline
Nov 3, 2009, 09:28 AM
#80
Silver Sponsor
Very nice to hear from someone that doesnt try to pit CBRD and FP as enemies.. we are simply two different companies with two different sets of goals in a similar market place...
apparently we both know how to find the needs for our respective clients.
cb
__________________
www.ChadBlock.com
Offline
Tags
14, bbk, block, cbrd, evo, evolutionm, failure, feed, fp, green, hta, line, mile, oil, stock, turbo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
