Aug 13, 2009, 10:25 AM
Personal Sales Rating: ( 49)
Drives: '04 Evo VIII
Buschur recommends the ARP's be torqued to 95 ft-lbs. I did that and have no issues.
__________________
BR Forward Facing HTA86
BR BFIC
BR 3" V-Band TBE
BR UICP
Tial Q
AEM EMS
Kelford 272's
PTE 1000 Injectors
Walbro 255
Forge UNOS MBC
PPI Ported Stock Intake Manifold
PPI 65mm Throttle Body
Offline
Aug 13, 2009, 11:29 AM
Personal Sales Rating: ( 0)
Drives: 2004 Evolution GSR
alright, I just saw 70 ft-lbs on another how-to thread. but I'd rather go with Buschur on that one!
Offline
Aug 13, 2009, 11:48 AM
Personal Sales Rating: ( 1)
Drives: 2004 WW Evo / 2003 Camry
Or just remove the tie-bars completely and then you don't have to use the bolts (on the left), spacers and washers.
__________________
BUILT BY BUSCHUR RACING
THE BITTERNESS OF POOR QUALITY REMAINS LONG AFTER THE SWEETNESS OF LOW PRICE IS FORGOTTEN.
553WHP/399WTQ - 93 octane
10.4490 @ 135.07
614WHP/490WTQ - Q16
9.9112 @ 144.62
Offline
Aug 13, 2009, 07:34 PM
So I installed the injectors, arp headstuds and removed the fuel system tonight. When it comes to the injectors, was I suppose to swap anything from the stock one to the new 1200cc injectors before installing? Also are the injectors suppose to be able to twist after the fuel rail gets bolted down over them?
Offline
Aug 13, 2009, 10:46 PM
Unless your injectors came with replacements, you should have had to swap the gasket that goes between the injector and the fuel rail. The one that is kinda sandwiched between the injector and the fuel rail when you tighten the fuel rail down.
There's really nothing to hold the injectors into a fixed position. So, yes, I suppose you would be able to turn the injectors a little.
__________________
BR BFIC
BR 3" V-Band TBE
BR UICP
Tial Q
AEM EMS
Kelford 272's
PTE 1000 Injectors
Walbro 255
Forge UNOS MBC
Offline
Aug 13, 2009, 10:55 PM
ok I think Im good then, the injectors are from BR and they had a slightly thick gasket on top where it meets the fuel rail. I dont know why I'm asking so many questions, just cautious and worried this being the first time I've really modified the car. let's hope this new found power is really all that its held up to me, since before this I had a tbe and ebc with no tune.
Offline
Aug 15, 2009, 06:49 PM
hey does anyone know where I hook these hoses from my AEM tru-boost to the new 35r, the red ended one went to my stock wastegate and the other hooked up the the stock turbo outlet pipe. My question is where does the hose go that went to the turbo outlet? There's no where for it to hook up to on the HTA 3586r???
Offline
Aug 15, 2009, 07:02 PM
Personal Sales Rating: ( 128)
Drives: MR
After reading this entire thread... I think if you honestly have this many simple questions, you should just take it to a shop to install these parts.. I'm scared for you and your car...
As far as the boost controller goes.. Since your FP turbo does not come with a compressor cover nipple.. you can either A) drill and tap a vacuum nipple into the compressor cover or b) obviously "t" into your intake manifold for vacuum pressure...
Online
Aug 15, 2009, 09:35 PM
Personal Sales Rating: ( 47)
Drives: 2003 Evo VIII
As noted above ^^ the preferable option is to drill and tap a source in the compressor cover.
Looks like this: http://forums.evolutionm.net/7399612-post17.html
Offline
Aug 15, 2009, 10:13 PM
I apologize for the simple questions, but I believe we all learn somewhere and sometime, this is the first thing I've ever done on my car. I have done alot of research but I feel better asking you guys questions to make sure I'm doing everything right.
Anyways thanks for the advice, it's really appreciated. I'm a hands on learner; I've learned a ton the last few weeks
Offline
Aug 15, 2009, 10:23 PM
Drives: MR
No problem at all sir, it is "that" time of the month for me, and I'm having problems with my own car lol.  Good luck with everything, if you need any help, don't hesitate to ask!
Online
Aug 15, 2009, 10:34 PM
Personal Sales Rating: ( 2)
Drives: EVO Ocho
Baby Steps.
__________________
Diablo Rojo,AEM,BF272s and Typical BS bolts ons.483whp with 1.0 cr
sponsored By:
Visa
Mastercard
Amex
Offline
Aug 15, 2009, 11:07 PM
Well I'm sorry to hear that about your car.  and thanks for the help and being understanding, these are my baby steps! Lol maybe this would be a good "turbo install for dummies" but in all honesty you guys are helping out alot.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
