Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 12, 2009, 07:58 PM   #16
Personal Sales Rating: (7)
2005 Mitsubishi Lancer Evolution
kaymin's Avatar
Drives: 05' Burnt Orange Evo 8
Send a message via AIM to kaymin
a rod bearing sounds more like a clunking noise then a tick I believe hahah
I could be wrong though. So wait for someone to confirm.
__________________
ARC is Rice
Offline
Old Aug 13, 2009, 06:31 AM   #17
Personal Sales Rating: (1)
RapedApe's Avatar
Drives: 04 BBY SSL - 2.3L
Quote:
Originally Posted by bbyevo8u View Post
i dont have an oil pressure gauge how else could i know if it was the rod bearings, what does it sound like when they go back?
thanks for the help
Start the car with the spark plug out of the cylinder you suspect. Without compression beating down on it, the noise will go away if it's a rod bearing.
Offline
Old Aug 13, 2009, 06:47 AM   #18
Personal Sales Rating: (0)
Drives: 03
Quote:
Originally Posted by evozoom View Post
like loose heat sheilds on the exhaust?
For sure check the easy stuff under the hood.
My heat shield on my cat rusted at some of the seam welds and made the classic POS car noise (rattle) at idle and under light acceleration.
Crawl under it and give the exhaust a shove if you get a rattle go from there. However probly unlikely in your case I have an 03' that has seen lots of NE. winter and salt.
The DP./ crank case is always good to check, the rubber hangers tend to slide around a bit when wet.
Drive shaft carrier bearing or mounts? But again usually only in older or abused cars.
Goodluck
__________________
Offline
Old Aug 13, 2009, 09:08 PM   #19
Personal Sales Rating: (2)
bbyevo8u's Avatar
Drives: *9 MR SE* ivey tuned.........sold: k7 gixxer 600, 03 350z stock, 04 evo8 cbe, 05 evo8 cbe, 06 sti cobb stg2 300whp
Quote:
awesome, is this safe to do?
i dont have an exhaust manifold heat shield and i have a test pipe so it cant be that!
thanks for all the help guys i cant wait to check out the car this weekend
__________________
PERRIN TBE W/TEST >< BUSCHUR CONE FILTER >< ETS INTERCOOLER KIT >< HALLMAN PRO MBC >< WALBRO 255 PUMP >< KELFORD 272's >< BEEHIVE SPRINGS >< INVIDIA EXHAUST MANIFOLD >< INVIDIA 02 HOUSING >< HDSS W/ACT STREETLITE FLYWHEEL >< FLUIDAMPR CRANK PULLEY >< ARP HEAD STUDS >< STIFF SHIFTER BUSHINGS >< SS CLUTCH LINE >< DUNLOP TIRES >< AEM WIDEBAND >< AUTOMETER BOOST GAUGE >< KOYO RAD >< KEVLAR BELTS >< ///IVEY TUNED - 350whp 352whq///
Offline
Old Aug 14, 2009, 07:48 AM   #20
Personal Sales Rating: (21)
05blue8's Avatar
Drives: 2005 VIII
Send a message via AIM to 05blue8 Send a message via MSN to 05blue8
After hearing a car running with a spun rod bearing it's a very noticeable clunk, not a tick. Lifter tick is one thing, a spun rod bearing is much much louder and it's consistent and doesn't go away. Does the noise ever go away?
__________________
2005 EB VIII with everything except injectors and a bigger turbo!
Thanks to Evolution Dynamics for the great work!
Offline
Old Aug 16, 2009, 12:49 AM   #21
bbyevo8u's Avatar
Quote:
yes, when the the car i hot it shows up?
__________________
Offline
Old Aug 16, 2009, 11:09 AM   #22
barneyb's Avatar
Drives: '03 Evo 8, '04 WRX
If it sounds like a kid riding a bicycle with a card in the spokes and only does it when the engine is hot and you are getting onto the throttle then it may be a balance shaft bearing.
Offline
Tags
bearing, compression, engine, rattle, rod, show, spun, sti, test, tickrattle, wrx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
