Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 2, 2009, 09:00 PM   #91
Personal Sales Rating: (2)
Drives: volvo 740 turbo
Send a message via AIM to linuxman51
Quote:
Originally Posted by E85evo8 View Post
right now I have a beater, but eventually the evo will be my primary car. I will be daily driving it, but I will try and avoid traffic as the QM is ON/OFF engagement
nice. I do too much DD-stuff in mine to have an on/off type of clutch-even though the p-trim was a bit more biased that way than what I thought it would be. Good luck with yours.
__________________
03 TB EvoVIII, ams 35r, fmic, cams, etc. 440whp
90 Volvo 740 16v, t67, blah blah blah 512whp
Offline
Old Nov 2, 2009, 09:09 PM   #92
Personal Sales Rating: (12)
WickedWhtMR's Avatar
Drives: 05 EVO MR
I receive my Super Twin a couple of weeks ago. I bought it through MAP. I asked for a SS-Trim but it turns out that Spec doesnt make the the SS_Trim anymore for the Evo 8/9 since they arent offering them for the X. So they sent me the P-Trim instead. I originally was not ok with this but SPEC-01 assures me its drivability is just as good as the SS-Trim. Im almost done with the install. I installed SS-lines and new master. Ill let you guys know how it goes. I did drop the cross member to make the install easier. I will be sooooo pissed if I have these issues. Im installing a TRE trans as well. Again... I will be sooooooooo pissed if this trans/clutch doesnt shift like a plasma cuter through butter!!!!!!!!!!!!!!!!
__________________
HKS:Rs Intake/Hi Power Exhaust/272 Cams/Gears
4WS Engineering:Exhaust CutOut
4WS Tuning:Re-Flash
RevMotto:Mani Port/Exhaust housing port
Jegs:Electric CutOut Valve
Blitz:SUS Filter
Greddy:Informeter/TT
Hallman:RX Pro
MeGan:Dp
AWD Motorsports:Motor Mount kit
ACT:Pressure Plate/Flywheel/6 Puck
EBay:FMIC/O2 Housing
Zeitronix:Wideband/Egt/Boost/Meth Failsafe
SpoolinUp:Coil on Plug
Labonte: Meth Injection
Synapse:BOV
JDM Evo 9:Rear Bumper/Turbo
MUSE:LICP/UICP
Mitsu:5 Speed Conv.
Offline
Old Nov 2, 2009, 09:15 PM   #93
EvoM Super Moderator
Silver Vendor
Personal Sales Rating: (65)
Zeus's Avatar
Drives: Old Man with a 03' EVO VIII, 05' Subaru 2.5GT Limited, 06' Kawa Z1000, 02' Kawa ZR-7s, 07' GSXR 1000 (babysitting lil' brother's ride while he's in the sand box), 00' Integra Type R SOLD
Send a message via AIM to Zeus
I wanted to have the clutch out the door on it's way to Spec to see if something did get warped. I hope it is something obvious....I didn't launch my car once with the Spec twin in the car. I haven't launched my car since I bought it.....
Did the friction surfaces look at all "cooked". If not, your problems may be elsewhere. If it does look like it's had some heat in it...
__________________
Contact me for parts -n- installs!
Best deals on All Megan products!! Megan Evo X turbobacks and O2 housings!!! OE TYPE replacement rotors-n-pads DEAL. I'm only available 8am-12pm Central Tues-Sat, available all day Sun/Mon. Currently only accepting PayPal, all sales final, customer warranty claims processed directly through the original manufacturer. All shipping quoted for the contiguous 48 states.
Offline
Old Nov 2, 2009, 09:15 PM   #94
Personal Sales Rating: (17)
Drives: 2005 Evolution VIII
even the people who are using the spec supertwins with success say that they are a heavier unit and don't shift as fast as the light 7.25" twin disc clutches that are available do. Spec does make 3 different types of "mini" twins which are the same size as the QM/Tilton/PTT etc..
__________________
05 EVO VIII. 565whp/422 tq @ 33psi (new #'s soon)on E85...Powered by Headgames, Buschur, ETS, and MMS Performance!
Offline
Old Nov 2, 2009, 09:30 PM   #95
Silver Vendor
Zeus's Avatar
Yes, but shifting fast and dragging into first and reverse are a whole other enchilada.
__________________
Offline
Old Nov 3, 2009, 08:09 AM   #96
Quote:
I dunno.. if you're dragging going into gear in neutral, I would think that it would be dragging at 8000 rpms when you're trying to grab the next gear.
__________________
Offline
Old Nov 3, 2009, 04:16 PM   #97
Silver Vendor
Zeus's Avatar
Quote:
You misunderstood me... You can have a heavy clutch that "shifts slow" (on the top end), or with more effort than a lightweight unit and nothing may be "wrong". However, if you are having vehicle movement shifting into bottom gear from a standstill, something is seriously not right and needs attention. As in you are dragging discs! Follow me now?
__________________
Offline
Old Nov 3, 2009, 08:10 PM   #98
I guess the difference is in what is defined as 'shifts slow'. I smell what you're steppin' in.. and I've heard tell its not entirely uncommon with the supertwins.
__________________
Offline
Old Nov 9, 2009, 11:00 PM   #99
Drives: 05 EVO MR
I finished up my install...
I had the peddle adjusted with 4 threads left.. I pulled out of the garage to check and see if the car moved while in gear and the clutch pushed in... It did... I took a half thread out and it didnt roll again. I took it out and warmed up the clutch prior to to doing the following. I heard that cars where rolling forward on the 2step. So after warming up the clutch. Setup the 2step up on a nice flat surface. The car did creep. I took another half thread out and viola.. no more movement. I did install a TRE trans with this clutch. Seems like everything is cool. The only thing Ive got going on out of the ordinary is:
A) When off of the clutch peddle.. the car makes a high pitched whining sound. It does it anytime im off the clutch... in gear.. out of gear, stopped or driving.. it whines. As soon as a put any kind of pressure on the peddle.. it stops.. cant figure it out. I adjust the clutch further in.. no change.. adjusted it further in.. no change. It didnt start doing this right away either.. it started like 10 minutes into my test drive. My shifting is quite notchy.. but i havent broken this gear box in so I cant blame the clutch for this.
B) My SRS light kicked on after the install... not right away... but like 15 minutes after I started the car and let it warm up.. I cant figure out that one either.
__________________
4WS Tuning:Re-Flash
Blitz:SUS Filter
Hallman:RX Pro
MeGan:Dp
Synapse:BOV
MUSE:LICP/UICP
Mitsu:5 Speed Conv.
Offline
Old Nov 10, 2009, 03:58 PM   #100
I spoke with Jeremy at Spec and he said that my clutch discs were contacting the diapragm and not releasing like they should when the clutch pedal is depressed. He actually rebuilt me a new clutch with new "custom" discs. They are 6 puck UNSPRUNG and much lighter than any discs previously offered with their clutches. He assures me that this clutch should work beautifully!! I will be selling this clutch as I already have a QM twin disc setup in my evo now as I couldn't wait for Spec to finish inspecting and building mine. I will post up pics in this thread and start a for sale thread for the Spec "custom" supertwin
__________________
Offline
Old Nov 10, 2009, 04:24 PM   #101
Drives: 05 EVO MR
Thats cool... wish i knew what was going on with mine..
__________________
4WS Tuning:Re-Flash
Blitz:SUS Filter
Hallman:RX Pro
MeGan:Dp
Synapse:BOV
MUSE:LICP/UICP
Mitsu:5 Speed Conv.
Offline
Old Nov 11, 2009, 12:32 PM   #102
Personal Sales Rating: (4)
Drives: EVO VIII
did you guys get shims for the tob with yours???
Offline
Old Nov 11, 2009, 12:58 PM   #103
EvoM Moderator
MR Turco's Avatar
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
you shouldn't need any shims.
__________________
-Mike
The Rules - love them
TephraMOD V7 - now serving 25x30 fuel and timing maps and Gear Dependent Boost Control
Quote:
Originally Posted by beavis820 View Post
turco is a damn fine mechanic without me
Online
Old Nov 14, 2009, 03:33 PM   #104
here is a link to my for sale thread on the new custom built Spec Super twin. This clutch should be the answer to anyone that wants what a spec clutch "should" be. I really wish I could've waited to install this as the QM is very harsh for a Daily Driven Evo..
FS: Freshly Rebuilt custom SPEC SUPER TWIN disc clutch setup
__________________
Offline
Old Nov 16, 2009, 02:37 PM   #105
Personal Sales Rating: (0)
Drives: 05 evo
so i just ordered the mini twin should i expect the same issues? or were some changes made between the two, terrible thread for sommeone who just made a purchase!!!
Offline
Tags
bleeding, clutch, disc, discs, disk, evo, explode, install, installation, instructions, ix, plate, spec, st, super, supertwin, twin
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
