Jul 24, 2009, 08:04 PM
Personal Sales Rating: ( 6)
Drives: 05 EB evo
Whining noise after belts/cam install
I just finished installing some S1's and new Greddy timing belt, balance shaft belts along with a Dayco serpentine belt and pullies.
When revvng the car a little it sounds like a blower almost. Kinda of slight whine and increases with RPM
I took off the top cover and it seems to maybe come from the upper timing belt area
My friend says is sounds like a 1G DSM. I remember this from one of mine too, almost like an electronic type whine if that makes sesne.
Dunno if the belt is too tight? feels like it should to me. Or maybe the kevlar belts, or cams making the whine?
Suggestions?
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
345WHP/322TQ on 23PSi on the "HeartBreaker" Mustang Dyno (old numbers)
Offline
Jul 24, 2009, 10:39 PM
Personal Sales Rating: ( 0)
Drives: 2003 Evolution
That's the sound of the turbo spooling up - it's normal.
Offline
Jul 25, 2009, 04:32 AM
Drives: 2005 Evo VIII
Suggestions?
I just put on a new serpentine belt tensioner and a gates serpentine kevlar belt. It makes a slight whine like you describe. it might just be the nature of the kevlar belts. Their stiffer so maybe that makes them louder is what I can think, idk. High rpm in 2nd gear is when I notice it most for me.
Offline
Jul 25, 2009, 04:38 AM
Personal Sales Rating: ( 34)
Drives: 04 RS and 08 GSR
I had a noise like that after my last cam install with the stock belts. It went away.
Offline
Jul 25, 2009, 08:30 AM
Drives: 05 EB evo
Quote:
cmon dude. are you being serious?
I know what a turbo and even more what my turbo sounds like at spool.
this almost sounds like a belt tension thing or a pulley whine or something
so you guys think I should just try and get some mileage on it and see what happens?
I never ran kevlar belts before. Also I didnt test deflection to be honest. Im not gonna lie when I say its pretty taught
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
Offline
Jul 25, 2009, 08:54 AM
Drives: RealSweet, JDM ITR
If you get the Tbelt to tight it will sound like that.
Offline
Jul 25, 2009, 09:03 AM
Personal Sales Rating: ( 2)
Drives: 06 EVAlution IX; 93 EVO I; 06 ES (DD)
I have the Gates Racing belts... the nylon coated teeth on the belt engaging with the sprockets make that whine. Not sure if your belts have the nylon coating on them or not. Was really irritating at first, but now I couldn't go back to the silence of OEM.
__________________
XBL Gamertag: LancerEVA06
Quote:
Originally Posted by LancerEVA06
Me: looks like a shopping cart with that wing.
Him: o jeez
Me: We have Shopping Carts for balls
Me: HAHAHAHAHAHAHAa;sdf
Me: I mean cars
Him: u smoke something there dude? lmao
Offline
Jul 25, 2009, 12:12 PM
Drives: 05 EB evo
how long you been driving on it like that?
Any ill affects of having the belt a little too tight? To me it feels fine and on the tighter side, but its kevlar too, so it wont flex and deflect like the stock Im thinking
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
Offline
Jul 25, 2009, 08:17 PM
Drives: Lancer evolution V RS
I had the same sound when i replaced my oem timing belt for a HKS one. Sounds like an over tensionned belt (check and recheck my work  ), the sound is now gone ( 1000 mls after).
Offline
Jul 25, 2009, 08:44 PM
Personal Sales Rating: ( 28)
Drives: 05 evo VIII,03 evo STREET WHORE
i would recheck the tightness for sure,it might be too tight from what it sounds like.i ran a kevlar belt once,like you said it doesnt deflect like the stockers,what it did on my car was pull up on the oil pump gear and wear into the oil pump housing causing a massive oil leak.needless to say i replaced the oil pump along with an oem belt.was golden after that.
Offline
Jul 26, 2009, 10:10 AM
Offline
Jul 26, 2009, 11:58 AM
Personal Sales Rating: ( 14)
Drives: 2003 RR Evo
Definitely check the tension. You can lose the oil pump if you run the timing belt too tight.
Offline
Aug 4, 2009, 05:30 AM
Drives: 05 EB evo
well I pulled the covers yesterday and checked the tension and the tension seems a bit looser then before. I didnt touch anything though, so it prob stretched a litle from driving.
It still makes the noise though.
When rotating the crank by hand it makes a funny noise kinda too.
So Im thinking its just the attributes of a kevlar belt.
I dunno what else to think?
Any other suggestions?
Can I start it without the accessory belt on to see if its that belt maybe making the noise?
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
Offline
Aug 4, 2009, 09:42 AM
Drives: Evo
You can start it with the accessory belt off.
Online
Aug 4, 2009, 09:48 AM
Drives: 05 EB evo
i guess Ill try this tonight to see if its even the Timing belt whining.
i wasnt sure if it would be a good idea with the water pump not running and the alt not running.
I guess anything is possible at this point.
I dunno what else to check. When I rotate by hand though it make a slight noise like sticky sneakers on a surface, so it sounds to me like its just because of the material of the belt?
I know I have great analogies. lol
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
Offline
Tags
belt, belts, car, engine, evo, increases, noise, noisse, replaced, rpm, serpentine, sound, timing, whine, whines, whining  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
