how to tighten timing belt tensioner pulley?
does anyone have a method to tighten the timing belt tensioner pulley WITHOUT the mitsubishi special tool that fits in the two holes on the pulley?
help from someone with experiance would be greatly appreciated, thanks in advance.
heres a refernece
sorry for whoevers engine picture i stole, hope you dont mind
heres a refernece
You should unbolt the tensioner and compress it in a vice and put a pin of some sort in the hole to keep it down. Then push the pulley inwards to tighten the belt and then tighten the bolt. After that is all done bolt the tensioner back in and make sure the timing is set and then pull the pin out and there you go. It is a self tensioner so it will be tight and good to go. If any more help just send me a pm
thanks, yeah i have a new tensioner and its already compressed.
the manual says to turn the tensioner pulley with their special tool to 31 in/lbs which i dont have, i just wanted to make sure it was ok to twist by hand.
fsm-
15.Loosen the tensioner pulley lock bolt.
16.Turn the torque wrench attached to the special tool
MD998767 counterclockwise until the slack in the timing belt
is taken up.
17.Turn the torque wrench clockwise from the position of step
16. until the torque wrench reading becomes 3.5 N⋅m (31 inlb),
then tighten the tensioner pulley lock bolt.
fsm-
is taken up.
I got my tool from Jay Racing.
Also: forget about the torque spec you're supposed to put on the pulley. Tighten the pulley until the belt is tight, Then let everything set for a few seconds. I usually wait about 30. Check to see that the pin in the hydraulic tensioner slides in and out easily. If not, readjust the tensioner pulley. It takes very small adjustments to get the pin where you want it.
If the pin does not move, you can usually look at it to figure out which way it needs to go. If it's rubbing the top of the tensioner hole, then you know you need to tighten the tensioner pulley. If it's rubbing the bottom of the hole, then obviously you would loosen it.
When I say small adjustments on the pulley, I mean just a few degrees. It doesn't take much.
Good luck! It's not that hard, just takes time to get it right.
Getting the hydraulic tensioner just right allows it to have the proper range of movement each way.
P.S. Don't forget to rotate the engine around a few times and recheck tension.
Apex Hunter (Jul 4, 2019)
Any time I mess with the tensioner without the cams locked so they can't move (another special tool) the belt jumps at the crank sprocket. Before starting, with the timing marks lined up, mark the crank sprocket and belt. Then if it jumps you can see that the marks no longer align and know to reset the belt..
Yup, great idea. marking the belt helps ensure everything stays lined up.
i put a wrench on the exhaust cam gear and turn it to where it needs to be and used a wire to tie the wrench down so it doesn't move, then i just have to deal with the intake cam with one hand and use other hand to slip timing belt over tensioner pulley
or just put the belt where it needs to be on the cam gear and zip tie it so it doesn't jump. just did my timing belt last night.
SLVRNBLK
Mar 21, 2016 05:51 PM
S1MPSONS
Oct 29, 2015 12:24 PM
2skys1imit3
For Sale - Part Outs
Aug 24, 2008 06:42 PM
