Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 22, 2009, 06:36 AM   #61
Personal Sales Rating: (0)
Drives: EVO 8
oo one note, it use to rattle only from 3000 to 2450rpm in 3er and 4 and 5 gear only, now than i have removed my WR Engine Torque Stiffener cause the metal bracket has been broke is making more noise even in 2 gear from 3000 to 1900rpm, so i will install the WR Engine Torque Stiffener, installing back my oem harmonic balancer and change my motor mounts for Avid billet motor mount after all that it my help!
Offline
Old Oct 22, 2009, 05:57 PM   #62
Personal Sales Rating: (14)
vmrevo9's Avatar
Drives: 06 Evo RS
thats wierd. i'm at the point were i want to take out the clutch and TOB and replace it all lol.
my buddy just went with a comp clutch and ACT streetlite flywheel (same flywheel i have) and he has no rattles or noises. it has me thinking lol
__________________
Mods:
JunB.L - Espelir - Perrin HFC - K&N - Forge MBC - Walbro 255 FP - Advans
Prosport Amber/WhiteBoost gauge - GTWorx Springs - 17" Rota Boost - LICP
LC-1 o2 - ETS air filter kit - ACT HD clutch/Flywheel - SpoolinUp COP kit - Tuned by Mellon
12.541 @110.20 and 2nd place in show LOL
312 whp - 312wtq DLL
306 whp - 320wtq DynoDynamics AWD dyno
Offline
Old Oct 22, 2009, 08:27 PM   #63
Drives: EVO 8
Do you have oem harmonic balancer? RRE they tell me to better use the oem for noise reduction
Offline
Old Oct 22, 2009, 09:19 PM   #64
vmrevo9's Avatar
Drives: 06 Evo RS
my car is pretty much stock other than regular boltons. the noise only came about after the clutch change.
__________________
Mods:
Offline
Old Oct 23, 2009, 06:17 AM   #65
Drives: EVO 8
that's weird, my car with stock engine (only 272hks cams) and a lot more external mods with the exedy twin clutch wasn't make any noise
Offline
Old Oct 23, 2009, 08:20 PM   #66
vmrevo9's Avatar
Drives: 06 Evo RS
yeah i"ll probably change the clutch out before it needs to be and see what happens then. just dont want to spend another 700 on a clutch setup. not to mention having to change it out lol
i forgot to mention that i do have a Buschur front motor mount installed. did this along with the clutch change
__________________
Mods:
Offline
Old Nov 3, 2009, 05:58 PM   #67
Personal Sales Rating: (1)
RapedApe's Avatar
Drives: 04 BBY SSL - 2.3L
Same sh|t here. Only 4th and 5th decel. Jacks me off so bad, I'm about to sell the Evo and build another 1g.
Offline
Old Nov 6, 2009, 10:33 PM   #68
vmrevo9's Avatar
Drives: 06 Evo RS
i might have to try Revvin9k's suggestion. anything before taken out the clutch again. lol
__________________
Mods:
Offline
Old Nov 8, 2009, 08:29 AM   #69
Personal Sales Rating: (5)
ch47god's Avatar
Drives: 03' EVO Lightning Yellow
Send a message via MSN to ch47god
Have the same thing, same rpms, same gears for the most part. Had it on the stock setup as well, became more noticeable with an Amsoil fluid change (not a dig, awesome fluid). Went to a single organic Exedy installed at CBRD, double checked with Chad, same noise as always just amplified. Gear selection only effects it because of the speed of the gear sets changes the specific frequency, and the vibration gets worse. Don't sweat it bud, just one of the many nuances of Evo ownership lmao.
Offline
Old Nov 8, 2009, 10:35 AM   #70
vmrevo9's Avatar
Drives: 06 Evo RS
we'll have to try the fuel tank heat shields like kracka did.
__________________
Mods:
Offline
Old Nov 12, 2009, 05:05 PM   #71
Drives: 2003 Evo8
Quote:
Originally Posted by TS8 View Post
Anyone else with similar issues?
I have the exact setup (clutch and flywheel) that you have, and also that ******* rattle when I let off the gas. Still trying to figure it out, only things I can come up with are either the clutch or the flywheel. At least I know it's not just my car, I thought we F'ed somthieng up during the install.
Offline
Old Nov 13, 2009, 12:59 AM   #72
bsh
bsh's Avatar
Drives: Lancer Evo II
I have the same problems with my Evo 2. Have tried both QM twin and Carbonetic Carbon tripple and they both make the tranny sound really bad on deacellaration. It did not make this noise on standard clutch. I believe the reason for this sound are that these clutches dont have a sprung/dampened center. I have also tried to shim up the tranny a little tighter, but still alot of noises.
I believe the only thing to remedy this, is to change to a clutch with sprung/dampened center. That is my personal opinion, not the fact
I have only found one twin plate clutch that have a aprung center, and that are this OS Giken clutch: http://www.osgiken.co.jp/pro_clutch/clutch/r2cd.html
Anyone know about someone that have this clutch and how it performs?
__________________
bsh
http://www.halandtuning.no
Dynapack 4 wd 1500hp dyno
http://www.vi-pec.com
Offline
Tags
5th, bearing, clutch, competition, deceleration, evo, evolution, forum, gear, high, motor, mount, noise, rattle, rattling, rpms, throw
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
