Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 15, 2009, 12:11 PM   #1
Personal Sales Rating: (14)
NewEvolutionIX's Avatar
Drives: 2006 Evo MR,1968 Nova(Sold), 2004 Mazda 6(Sold), 1991 GSX Eclipse (Sold), 1990 CRX Si (sold)
Send a message via AIM to NewEvolutionIX
tcase fluid change help
I was told at the mitsu dealership that I need to use a scan tool to change the fluid in my tcase due to the ACD. Is this true?? Or can I just change the fluid and go on my way. I have drained it but have the DIAqueen to put back in.
__________________
Stock IX parts
http://forums.evolutionm.net/showthr...77#post6406677
2006 Wicked White Evo IX MR
Mods:
HTA 35R kit, AMS FMIC w/ LICP, Supertech Dual valve springs/valves/Titanium retainers/seats, S1 cams, K&N drop in filter, DC DP w/ cat delete, JUN BL exhaust, 1050cc injectors, Walbro 255, Exedy Twin Disc
Nitrous is like a hot girl with an STD...
You wanna hit it, but your afraid of the consequences
Real men whistle, they don't whine
Offline
Old Jul 15, 2009, 12:37 PM   #2
Personal Sales Rating: (5)
Drives: 2006, WW IX
Send a message via AIM to srtboostin22
noooo, i just got done doing this on my 9 ... just drain it, put the drain plug back in..
Crack the bleed screw open, turn the key on but dont start the car,
push the gas pedal to the floor for a few seconds. You will hear the
acd cycle or whatever it does. Turn key off.... You may have to do
it a few times.
^taken from the how to section
Offline
Old Jul 15, 2009, 12:55 PM   #3
Personal Sales Rating: (1)
PATRICK B.'s Avatar
Drives: 2006 EVO RS & 2003 F150 SCREW
Only need to bleed acd if the line was removed.
__________________
Sponsored by :
FULL FUNCTION TECHNOLOGY
www.FFTEC.com
SPARKTECH IGNITION SYSTEMS
www.SparkTechIgnitions.net
* 10.14 @ 141.8mph 1.52 60ft 7/18/09
* 1st place CMI Summer Nationals 09 (T4 class)
http://www.youtube.com/watch?v=gngE9rruXoQ
http://www.youtube.com/watch?v=cEVSA...eature=related
Quickest ET = 10.08
Fastest MPH = 142.93
http://www.youtube.com/watch?v=n_--AejWmzQ
Offline
Old Jul 15, 2009, 06:55 PM   #4
Yeah I did remove the line on the top of the tcase. so im guessing I do have to bleed it
__________________
Stock IX parts
Mods:
Offline
Old Jul 16, 2009, 11:15 AM   #5
PATRICK B.'s Avatar
Quote:
In that case yes you do
__________________
Sponsored by :
www.FFTEC.com
Quickest ET = 10.08
Offline
Old Jul 16, 2009, 01:54 PM   #6
Personal Sales Rating: (15)
Kracka's Avatar
Drives: Wicked White Evo IX GSR
Send a message via AIM to Kracka
ACD and transfer case fluid are two totally seperate things. Transfer case fluid change is as simple as draining and refilling just like the transmission and rear differential. You should be using a GL-5 in the transfer case such as Mitsu DiaQueen 90W LSD (same fluid that goes in the rear diff). The ACD systems uses a Mitsu ATF fluid and must be properly bled and not just drained and refilled. ACD fluid is not considered to be a routine maintenance item though so unless you're having a problem with it or drain it during a clutch swap there is no need to perform this.
Online
Tags
case, evo, evom, fluid, tcase
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
