Jul 16, 2009, 08:20 PM
#31
Personal Sales Rating: ( 14)
Drives: 2003 RR Evo
Quote:
Originally Posted by BluEVOIX
Thanks!!
I dont know who makes it exactly, but Buschur is who sells it. Contact Jrod@buschur and he will be able to set you up with what you need.
I'd like to know who makes it so I can just buy the muffler and weld it into my test pipe. I'm sure its an off the shelf muffler just like the magnaflow that they sell. I'm gonna guess that it is a relatively inexpensive muffler.
Offline
Jul 16, 2009, 08:24 PM
#32
Personal Sales Rating: ( 0)
Drives: 06 Evo MR, 98 GTi 2.0T
After helping a friend put a boost gauge in his 2001.5 Audi S4 wagon, I was amazed at how much sound deadening material/carpet that car had. Even on the firewall in which our car lacks for sure. I think I might get some of those sound materials and add it in to see if I can block some of the engine bay noises and any extra noises of the exhaust.
hahaha, that my friend is the difference between a luxury brand vehicle and........well mitsubishi
Take a look at the 09 TL, I swear it has 1" of material for sure in some places on the floor... and that is not an exaggeration
Offline
Jul 19, 2009, 09:52 AM
#33
Personal Sales Rating: ( 44)
Great thread, glad the car is finally as quiet as you want it
dsevo, the bullet muffler is NOT an off the shelf muffler that entire muffler was designed/built for us and is not available from anywhere but us. So you'll be stuck buying it direct from us if you want it, sorry. It's also NOT cheap to make. It's pure 304 grade SS including the packing inside.
Offline
Jul 19, 2009, 10:02 AM
#34
Personal Sales Rating: ( 33)
Drives: 04 RS and 08 GSR
I just installed a BR bullet muffler in the test pipe location. I was shocked by how light it was for its size. My straight pipe with a 4" diameter bullet cat welded in was heavier than straight pipe with the BR bullet muffler welded in.
__________________
RichJ
2004 RS - FP Red, stock ECU w/SD, 464 whp on 93 oct (BR dyno)
Redline TA Summit Point track record - Street Class
Many thanks to Buschur Racing, tephra, jcsbanks, mrfred, l2r99gst and my wife!
Offline
Jul 19, 2009, 10:03 AM
#35
Drives: 2003 RR Evo
OK, it was worth asking. Can you PM me the price for just the muffler to 92592, or do I have to buy the whole test pipe? Thanks.
Offline
Sep 20, 2009, 06:23 PM
#36
Personal Sales Rating: ( 9)
Drives: 2003 RR Evo
OP, are there any ground clearance issues with the 6" round muffler? Are you lowered? Do the 4" and 5" round mufflers offer significantly less sound deadening? Would adding more mufflers continue to lower the sound level? Would this hurt performance?
__________________
2004 Apex Evo SOLD
2003 Tarmac Evo SOLD
1993.5 Black Supra TT SOLD
2003 Rally Red Evo - FP Red 509whp/500wtq
Offline
Sep 20, 2009, 06:33 PM
#37
Personal Sales Rating: ( 15)
Drives: 97GSX<GGIXMR
Quote:
^^good questions...+1...
__________________
12.05 @ 116.5mph....93 oct., Stock turbo, Stock motor (Stock cams), Stock Intake Manifold & TB, crappy 6 spd tranny, a bunch of bolt-ons, SPARKTECH nonCDi COP, 25 psi, Tuned by Kasey @ MAP (2009)
For the Fastest/Quickest Stock Appearing Turbo Times of 2009 Click Below
For all your Ignition NEEDS & WANTS, CLICK BELOW!!
Online
Sep 20, 2009, 08:51 PM
#38
Personal Sales Rating: ( 8)
Drives: 2006 GG MR :)
Dave -- Have you tested this Magnaflow (part #13259) muffler http://www.magnaflow.com/02product/s...e=main&id=8184 ? I am considering adding this to my setup to get rid of the drone....I would like to try an offset muffler (intake/exhaust) with internal baffling and this seems to offer both...
__________________
3" Modified Megan Racing TBE & UR Cat.
Buschur O2 & Buschur Exhaust Manifold
Nisei LICP
DC2 oil catch can
Walbro Fuel Pump
Injen intake and UICP (w/ Perrin Filter)
ETS 3.5" FMIC
Zeitronix ZT2, ZAVT1, and Boost solenoid Failsafe
SMC Kit (50% Meth / 50% h2o )
GM 3 port BCS (28psi tapering to 22psi)
Enkei 17 x 9.5 NT03M 275/40 Azenis
Offline
Sep 20, 2009, 11:53 PM
#39
Personal Sales Rating: ( 32)
Drives: 06 Blue EVO IX
I am riding on stock height and I have no ground clearing issues with the 6" muffler. But at the same time I did remove the stock catalytic converter underbody heat shield. I dont know if it will clear that shield because I removed that a long time ago.
I do believe that adding more mufflers would further lower the sound level. But the problem is there is not enough space to do that.
As for hurting performace, ask your self does a 3" pipe with tiny holes around the wall hurt any more performance than a 3" pipe with no holes?
The only way an exhaust will get hurt from being quieter is possibly on high horsepower cars 600+. And the logic behind that is those cars are pushing a lot of exhaust pressure. The sound wave helps push the exhaust out and by muffling the wave your taking away some of the pressure waves that help move the exhaust out.
If I'm not mistaken Buschur tested his SD muffler + magnaflow combo and only saw a max 3 hp difference on his 500+whp car.....
__________________
2006 Blue EVO IX
3" Down Pipe & Testpipe w/ Stock Catback
TTP Swain o2 housing & Vibrant Cone filter
Forge WGA & Hallman RX Pro (cabin)
CCI Stage 3 clutch
Blox Motor Mount
ShepTrans
Offline
Sep 21, 2009, 09:03 AM
#40
BlueEvoIX -- Did you ever try an offset and baffled muffler ? I believe that would provide far superior noise cancellation to a straight through design...
__________________
Nisei LICP
DC2 oil catch can
Walbro Fuel Pump
ETS 3.5" FMIC
Offline
Sep 21, 2009, 04:59 PM
#41
Drives: 2003 RR Evo
I am afraid of ground clearance issues since I am lowered. Do you think a 5" round will be significantly less effective than a 6" round?
__________________
2004 Apex Evo SOLD
Offline
Sep 21, 2009, 08:23 PM
#42
Quote:
The point of this was to make a straight flow through that was quiet. If I wanted to make it quiet with no restrictions I would have most definately done the baffled muffler. I think the one your referring to is the Magnaflow one correct?
I dont have an answer to that. It might or might not. As for the clearance, this does clear the floor by a good amount. I'll double check in a couple days on how much clearance it actually has.
__________________
2006 Blue EVO IX
CCI Stage 3 clutch
Blox Motor Mount
ShepTrans
Offline
Sep 21, 2009, 08:44 PM
#43
Yes, I am referring to Magnaflow (part #13259) muffler http://www.magnaflow.com/02product/s...e=main&id=8184 ? I am considering adding this to my setup to get rid of the drone....I would like to try an offset muffler (intake/exhaust) with internal baffling and this seems to offer both...
__________________
Nisei LICP
DC2 oil catch can
Walbro Fuel Pump
ETS 3.5" FMIC
Offline
Oct 6, 2009, 10:54 PM
#44
Personal Sales Rating: ( 2)
Drives: 06 Evo MR
My car is slammed! I'm doing the Magnaflow 14419 4" polished round where the cat would go, Magnaflow 14219 5 X 9 x 14" oval in the rear with a Magnaflow 35206 3.5" Tip.
Parts are ordered and we'll see how it sounds real soon! Currently I'm rocking the Buschur Bullet with the Race Pipe... To LOUD!
Offline
Oct 6, 2009, 11:19 PM
#45
Awesome...thats pretty much exactly my setup...But I am running a HFC now but want to swap it out for the magnaflow muffler...Keep us updated on how it goes!
__________________
Online
Tags
burnt, buschur, catback, evo, exhaust, fit, flow, heat, ix, louder, magna, magnaflow, muffler, quiet, shield, slip  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
