Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 8, 2009, 01:59 PM   #1
Personal Sales Rating: (9)
wevo1985's Avatar
Drives: '03 white evo 8, '93 black eagle talon tsi awd (dd)
Send a message via AIM to wevo1985
oil pump walked in housing
hey, i just had a issue where i got a odd noise and a bad oil leak. i tore the covers and tbelt off and found that the oil pump gear had walked toward the crank. has anyone else had this problem and is their any fixes so this wont happen again. i will post more pics as soon as i take it out. sorry for the bad cell phone pics.
the upper left side is where it rolled and the lower right now has a gap that the oil comes out.
__________________
br hta37r, br stage 4 boltons, kelford 280 cams,jam lifters, supertech duel valve springs, ti retainers, nit valves, ported and polished runners by me, ported and polished intake and exhaust mani by me, br ported throttle body, , ross custom banodized pistons, manley i-beam rods, 100mm crank
568hp 460tq at 30psi on the stock ecu tuned by ivey!!!
Offline
Old Jul 8, 2009, 02:22 PM   #2
Personal Sales Rating: (11)
Ev0ikon's Avatar
Drives: Evo803Yello
OMG! I wanna see pics. How tight was your timing belt?
__________________
He who said that there is no replacement for displacement didn't know pkZIP. :p
Offline
Old Jul 8, 2009, 02:54 PM   #3
wevo1985's Avatar
Quote:
it wasnt tight past what it should be. ive done alot of tbelts and ive done them to tight before and you get a bad vibration. car was fine. ive done this belt so many times it only took me 15 mins to take everything off and find the leak.
__________________
Offline
Old Jul 8, 2009, 03:43 PM   #4
Ev0ikon's Avatar
Drives: Evo803Yello
How crazy is that! Doesn't that balance shaft have another bearing on the inside?
How many miles did you have on what oil pump?
__________________
Offline
Old Jul 8, 2009, 04:15 PM   #5
wevo1985's Avatar
about 70k on the pump. and i dont have the balence shafts. i also dont think it would make a difference as the shaft is on the next gear above, that is driven by the one that walked.
__________________
Offline
Old Jul 8, 2009, 08:04 PM   #6
wevo1985's Avatar
bump, any help!!! i could use any info before i put the new parts in and it happens again.
__________________
Offline
Old Jul 8, 2009, 08:12 PM   #7
Personal Sales Rating: (14)
evoix16's Avatar
Drives: Evo IX GSR, 06 RSX Type S
http://http://www.amsperformance.com/ams_balance_shafts.php[/url] read this
Offline
Old Jul 8, 2009, 08:21 PM   #8
Silver Sponsor +1
Personal Sales Rating: (445)
TTP Engineering's Avatar
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
Send a message via AIM to TTP Engineering
So you used a stub shaft and you want to know why it ate through the case?
Because you used a stub shaft, period.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Old Jul 9, 2009, 03:03 PM   #9
Ev0ikon's Avatar
Drives: Evo803Yello
^ How many of this type of failures have you seen? I am not questioning your conviction. This is the first I have seen.
Guess I should keep an eye on my stub shaft too.
__________________
Offline
Old Jul 9, 2009, 03:43 PM   #10
wevo1985's Avatar
if this is true than their would be more cases like this and no one would sell the sub shafts. do you think its possible that maybe the pump went bad?
__________________
Offline
Old Jul 10, 2009, 01:32 PM   #11
Personal Sales Rating: (0)
2003 Mitsubishi Lancer Evolution
Drives: 03 Lightning Evolution VIII
AMS proved stub shafts can do this, check out their balance shaft
"replacing the front balance shaft with a stub shaft will increase the chances of oil pump failures. This is likely caused by eliminating the support provided by the rear bearing journal. A stub shaft allows the oil pump gears to push apart and wear into the aluminum pump. Aluminum that is being worn away will enter the clean oil stream and contaminate the engine bearings. Eventually this can result in the oil pump seizing."
see not stubby
__________________
2003 Mitsu Evo 8 GSR
Ported IX,HKS high power cb, dc sports cat delete downpipe, GT Spec tubular turbo mani, walbro 255, Defi boost guage, Forge MBC , gizzmo two step, Comp Clutch Stage 2 sprung, comp clutch steel flywheel, Brian crower valves, Bc valve springs/ retainers, BC Pistons, eagle Rods, Built Head, ARC radiator, Shep racing TC, Slotted Drilled rotors, Short throw, Polyurethane Underhood bushings, billet rear lower Control arms
Offline
Old Jul 10, 2009, 01:42 PM   #12
Silver Sponsor
Personal Sales Rating: (6)
DG Motors's Avatar
Drives: Drag Evo 8, DG built Evo X, 05 Cadillac Escalade, 07 Ninja zx6r
+1 sorry about your issue...no stubby shafts.
__________________
DG Motors
In-house DYNO DYNAMICS
Tuning specials for evo 8's 9's and X's
Ecuflash Specialists/Aem Certified Tuners
WWW.DGMotorsNY.COM
1-631-957-8464 -Ask for Pete
Internet Flash Packages!
Tuner Of Worlds Highest Whp "Stock Ecu"Stock Block Evo X 629whp!
Tuner Of Worlds Highest Whp Evo X On 93 Octane 629whp!
DG Drag Evo 8: 9.06 @ 164mph!
DG Drag Evo 8 In Action: http://www.youtube.com/watch?v=ASZIiklA0Ow
Offline
Old Jul 10, 2009, 02:04 PM   #13
EVO(boss)'s Avatar
what's the limit for stock oil pump for evo8?
Offline
Old Jul 10, 2009, 02:07 PM   #14
Silver Sponsor +1
Quote:
549.9457whp and 486.947391tq
__________________
763whp/595tq HTA86
Factory ECU Expert
(407) 475-0010
AIM=TTPEngineering
TTP's Myspace page!
Offline
Old Jul 10, 2009, 02:17 PM   #15
Ev0ikon's Avatar
Drives: Evo803Yello
Great! Now I got one more thing to worry about.
__________________
Offline
Tags
06, 2003, change, dsm, evo, evo8, gasket, install, installation, long, oil, pump, removal, replacement, works
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
