Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 28, 2009, 03:17 PM   #106
Personal Sales Rating: (0)
Murf's Avatar
Drives: 03 evo 8/ 06 R6
I have seen the sutuby shaft cause a failure 2 times in a row on a guys car..he did not listen twice..he did the 3rd time.
__________________
The measure of a good car is how well it reacts in all road situations, NOT just how fast it goes straight.
Offline
Old Oct 29, 2009, 12:31 PM   #107
Personal Sales Rating: (1)
Drives: 96 plymouth neon
Send a message via AIM to ModenaTwinTurbo Send a message via Yahoo to ModenaTwinTurbo
I'm turning down the balancer from now on
__________________
sold
Eddie Rosado
203 673 9029
Offline
Old Oct 31, 2009, 02:54 AM   #108
Drives: many mitsu's
Quote:
Originally Posted by jimib View Post
Something I forgot. Here is a pics of an oil pump failure. The driven gear area that has the stubby shaft is fine.
I just had to replace my second front case. Both of mine looked like this pic. I had a new Kevlar belt. I would drive the car and put about 1000miles on it and finally start t beat on it. After a highspeed pull or two the pump would die. The first time the belt was tight. So I replaced it again set it loose drove it about 1200miles and then did a highspeed pull. Killed another one. This was on a JDM motor. I am hoping that my fatal flaw was that we reused a tensioner. This time we did a oem belt and a brand new tensioner. So far I have 300miles on it.
I did notice that when we were pushing back the old tensioner this time (before I found my new tensioner) that while compressing it that it popped it the vice like it was stuck.
What I was thinking is that when I would do a highspeed pull that the tensioner would let out to keep the slack out and then not return fast enough or stick or whatever and then kill the pump?
Does this make sense??
If no what else could do this??
thanks.
Offline
Old Nov 5, 2009, 08:47 AM   #109
PPM
PPM's Avatar
Drives: 2003 Mitsubishi Evo VIII Yellow 12.9@112, 2003 Mitsubishi Evo Black, 1997 Eagle Talon TSI AWD 10.6@136
Send a message via AIM to PPM
I will have mine apart this weekend so I can post some pics to see if it looks the same. I will also check my tensioner it is new, but I also still have my old one from the timing belt change.
Offline
Tags
06, 2003, change, dsm, evo, evo8, gasket, install, installation, long, oil, pump, removal, replacement, works
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
