Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 11, 2009, 04:29 AM   #31
Personal Sales Rating: (9)
wevo1985's Avatar
Drives: '03 white evo 8, '93 black eagle talon tsi awd (dd)
Send a message via AIM to wevo1985
does anyone else make the shaft like the ams one or are they the only company?
__________________
br hta37r, br stage 4 boltons, kelford 280 cams,jam lifters, supertech duel valve springs, ti retainers, nit valves, ported and polished runners by me, ported and polished intake and exhaust mani by me, br ported throttle body, , ross custom banodized pistons, manley i-beam rods, 100mm crank
568hp 460tq at 30psi on the stock ecu tuned by ivey!!!
Online
Old Jul 11, 2009, 05:49 AM   #32
Personal Sales Rating: (4)
kickin wing's Avatar
Drives: 03 TB Evo, Titleist
I have had this happen on 2 separate occasions. You will notice the oil pressure slowly start to go to crap and then a whining noise.
If you take the pump apart you will have the gear cutting into the housing
Online
Old Jul 11, 2009, 12:30 PM   #33
Yamahar1's Avatar
Could you not put some type of bearing on the front side in place of the rubber seal?
Offline
Old Jul 11, 2009, 02:48 PM   #34
wevo1985's Avatar
how many miles apart did this happen? also what changes did you make?
__________________
Online
Old Jul 11, 2009, 03:29 PM   #35
This happened on two totally separate motors both had new oil pumps and the "OEM stub shaft"
The timing belt was not to tight because I have the correct tools to do it
if I ever removed them again I would get the balance shaft machined
Online
Old Jul 11, 2009, 04:22 PM   #36
wevo1985's Avatar
ok, so you put the shafts back in? i have a good machine shop here so im going to look into having them make a copy of the ams shaft and if they can do it i can have that back sooner.
__________________
Online
Old Jul 12, 2009, 01:43 PM   #37
Yamahar1's Avatar
Could you not put a roller bearing in place of the rubber seal? Something like this or just some kind of spacer, like what is used on the balance shaft.
I would think that would hold it in place and give it the support it needs.....Yes? No? Maybe?
Offline
Old Jul 13, 2009, 04:44 AM   #38
wevo1985's Avatar
i dont think that would work. the gear goes into the area and with out a proper seal it would leak. but the big concern is the gear fits on the flat part of the shaft.
__________________
Online
Old Jul 13, 2009, 07:07 AM   #39
Personal Sales Rating: (47)
CO_VR4's Avatar
Drives: 2003 Evo VIII
There have been roller bearing setups made for DSMs in the past. Any capable machine shop can turn down a balance shaft as AMS does, and there are other less well known shops in the DSM world that have been doing that for more than a decade. Kudos to AMS, though, for offering this mod readily available to those who don't have access to it elsewhere.
Another thing that should be done to all oil pumps for Evos or DSMs when installing them is to relieve the edge of the gears very slightly on the side where they rub on the front cover so that they don't wear into the case when they have side pressure.
Offline
Old Jul 13, 2009, 07:15 AM   #40
With the time and money to put a bearing in there you would be better ahead to just machine the shaft down.
With the shaft in there you will have better leverage on that pump shaft and oil fed bearings at both ends.
I have also noticed that leaving the shaft in helps with oil pressure its not as ungodly high as it would be with removing both of them
Online
Old Jul 13, 2009, 11:47 AM   #41
Yamahar1's Avatar
So....go with AMS race shaft and oil pressure will be a bit higher.....or go with the stub shaft and get the Kiggly oil pressure regulator http://www.shop.kigglyracing.com/pro...=1&productId=8
Offline
Old Jul 13, 2009, 12:17 PM   #42
CO_VR4's Avatar
The Kiggley oil pressure regulator actually increases the oil pressure in the bottom of the motor by restricting the flow up to the head components...
Offline
Old Jul 14, 2009, 06:40 AM   #43
Gold Sponsor
Jackson Machine's Avatar
Quote:
Right....then he'll be complaining of noisy HLA's
To the OP, if the stub shaft was to blame then every single engine with one would experience pump failures. The fact that there are tens of thousands of 4G63's in DSM's and Evo's with stub shafts not eating pumps leads me to believe there was another problem. I'd look into proper belt tension or a faulty oil pump. Remanufactured and some aftermarket pumps have a poor track record.
__________________
Jackson Auto Machine Racing Engines
A full service, In-House, machine shop in Hanover, Maryland. Over 25 years of experience designing and building high performance turbocharged engines. Building Evolution series engines for over 10 years, specialized in 4G63's for over 14 years, including the worlds FIRST 8 second 2.0 4g63 DSM-JAM designed/built engine. Visit our website to view JAM-Spec Custom engine components and precision machine services we provide. www.jacksonautomachine.com
Offline
Old Jul 14, 2009, 10:21 AM   #44
Personal Sales Rating: (0)
Quote:
Actually, the lifters behave better with lower pressure to them and tend to clatter less often.
People also seem to forget, or maybe just not know, that the stub shaft is OEM mitsu production stuff. The 1.6L's got this setup.
Kevin
__________________
Mitsu Gas Record
Any-car FWD Gas Record
8.358 at 164.90mph
FWD/AUTO
Offline
Old Jul 14, 2009, 11:15 AM   #45
TalonTuner4G63's Avatar
Drives: 1990 Eagle Talon TSi AWD
Send a message via AIM to TalonTuner4G63
As said earlier, the stub shaft should not be to blame in the case of an oil pump failure, unless you are using the aftermarket job without the oil groove and feed hole (TopLine). The Mitsu stub shaft is a factory piece, and is used in vehicles that had to stay alive for thousands of miles under warranty.
However, I would blame the person who installed the stub shaft if they did not assemble the pump back together properly. Or if you use thin ass oil (aghemmobil110w30aghem), rev the piss out of it, and change the oil infrequently/run trash through it, blame yourself. These pumps can live up to 200k miles if taken care of, they usualy fail due to some other cause besides the pump itself.
__________________
Mitsubishi Parts Desk
Offline
Tags
06, 2003, change, dsm, evo, evo8, gasket, install, installation, long, oil, pump, removal, replacement, works
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
