Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 4, 2009, 07:39 PM   #1
Personal Sales Rating: (1)
Drives: 06 Evo MR
Profec B spec II High Boost
Im trying to run 30 psi on a BBK full turbo on e85. Im going to do a boost leak test tomorrow, but one was done a month ago. At 93% set I am only seeing 28 psi. Going over 94 or 95% I start to surge really bad during spool up, is this normal? How high have you guys ran your profec B to reach 30 psi? Does only 28 psi at 93% seem odd?
Thanks
Offline
Old Jul 4, 2009, 08:07 PM   #2
Personal Sales Rating: (47)
CO_VR4's Avatar
Drives: 2003 Evo VIII
What wastegate spring pressure are you using? Many EBCs will only permit max boost to be a multiplier of the spring pressure you are using. You may have to upgrade your actuator to a higher spring pressure before your EBC will give you the max boost you're looking for...
Offline
Old Jul 4, 2009, 08:10 PM   #3
Drives: 06 Evo MR
Using the stock ix wga that comes with the BBK.
Offline
Old Jul 4, 2009, 08:14 PM   #4
CO_VR4's Avatar
FP has wastegates that have up to 25PSI spring pressure. Try one of those.
Offline
Old Jul 4, 2009, 08:17 PM   #5
Personal Sales Rating: (11)
JordanS4's Avatar
Drives: Audi S4, 2006 TB IX MR
Isn't it a 3 bar sensor?
__________________
JAM Stroked. HeadGames. FP White. DTM Built
Offline
Old Jul 4, 2009, 08:17 PM   #6
Drives: 06 Evo MR
Quote:
I couldnt go to high because I also run pump gas at 22 psi, I would really like to get it to work a little better with just the ebc right now. I know other people with the same turbo or even a stock turbo that can easily hit 30 psi. I will go that route if need be though, thanks for the input.
Offline
Old Jul 4, 2009, 08:19 PM   #7
Drives: 06 Evo MR
Quote:
Not sure actually...
Offline
Old Jul 4, 2009, 08:21 PM   #8
Personal Sales Rating: (27)
2005 Mitsubishi Lancer Evolution
Fast_Freddie's Avatar
Drives: '05 Tarmac Black SSL VIII
I am at 60% for 26 PSI if that helps, and I am on the stock turbo & WGA with the turnbuckle preload at only one turn...
1. 60%
2. 5% (anything above this and mine flutters and surges)
3. 160
__________________
FP Red*Greddy ProfecB Spec II*HKS TT*Nesei Short Route IC Piping*Synapse BOV*COMP 272s*Injen Intercooler*AFE Power Dry Filter*R/TErnie Intake*R/TErnie FULL 3" O2 housing with V-band*R/TErnie Modified DCsports 3" Down/Test/Flexpipe with V-Band*Greddy Ti-C Exhaust*255lph*Tein S-Techs*18" Volk LE-28s*Progress 25mm Rear Sway*Project Mu pads*JDM Tails*Cusco Heat Shield*Mishimoto Radiator hoses/Cap*ARC shift knob*Injector Dynamics 1000cc...
Offline
Old Jul 4, 2009, 08:27 PM   #9
Drives: 06 Evo MR
Quote:
1. 60%
3. 160
I assume you mean one turn in on the nut from the factory setting? Do you know how many threads you have left?
Offline
Old Jul 4, 2009, 09:02 PM   #10
CO_VR4's Avatar
Quote:
For simple comparison, hook up a MBC with your existing setup and see if you hold the higher boost you're looking for. If you can, it's the issue with the EBC setup you're using, in conjunction with the wastegate actuator spring pressure.
Offline
Old Jul 4, 2009, 10:31 PM   #11
mt057's Avatar
Drives: 03 lancer evolution 8
Mine is set to 78 to hit 30.4 if I turn it to 79 its 31. Once on accident I hit 37 with it turned to 90. I was using the stock bov and switched to the syncronic without adjusting the first setting and zoom. I let off when I saw 32+ but it went to 37 before I could get off it.
__________________
3" tbe, GSC S1's, Aquamist hfs-1 100% meth, Greddy cam gears, Injen IC hard pipes & intake, ACT hdss clutch w/ Prolight flywheel, Walbro 255 lph, Greddy Profec B Spec 2 ebc, Fp Red 80mm, Syncronic BPV, ETS 3.5" IC
Offline
Old Jul 5, 2009, 03:18 AM   #12
Correct... I have about 1/4" of threads left or about 2.5 full turns left... On WG pressure I hit 10 psi and creep to 15 with it set like this
__________________
Offline
Old Sep 21, 2009, 07:29 AM   #13
Drives: 06 Evo MR
The general setting people say to use for start boost, or set gain, is 4 psi less than your target boost. I have to have mine set at 10 psi while my target is 22 psi. If I set it to 18 psi I will spike bad. Anyone else noticed this? This is on a BBK Full turbo. I really did not see any slower spool, just checking to see what you guys think.
Thanks
Offline
Tags
boost, evo, ii, max, maximum, pressure, profec, s4, set, setting, setup, spec, surging
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
