Jul 1, 2009, 08:18 PM
Personal Sales Rating: ( 20)
Drives: BBK powered EVO 8
Need Help
Hey guys,
I've been having this issue with my evo lately. The car threw a P0172 (system too rich) code. Oridinally fixed by CBRD which was a TB leak, well we thought it was fixed. The IM was replaced with a BR ported stocker and the TB replaced with a Mil spec 65mm unit. The code didn't come back and CBRD did a new tune for the car.
I picked up the car and the next day, the code returned. The car was taken back to CBRD about a week later and has been there for about a month now. No matter what we do to the car, the ecu changes the fuel trims. From what Chad was telling me, the only time it doesn't is at WOT.
Things we have changed with no luck:
02 sensors
MAF sensor
BOV
injectors
walbro fuel pump
battery
changed the TB to a stocker
compression 170-175 accross all cylinders
changed all the solenoids on the IM
retuned
temperature sensors checked.
Fuel pressure regulator, evap sole and check valve, throttle body, idle stepper, EGR, plug wires, MAF, bov, head gasket, pcv valve
ECU swapped out
It's obvious I can't tune cars, sorry if my lingo isn't correct
I'm sure there are other things that Chad and Mark have done, but we are kind of stuck at this point.
I was wondering if anyone has had this issue with the stock ECU changing the fuel no matter what?
Any help would be great.
Thanks
Jason H.
Offline
Jul 1, 2009, 08:56 PM
Personal Sales Rating: ( 14)
2005 Mitsubishi Lancer Evolution
Drives: 2005 Evolution 8, DD 92 Camry
I wonder if tuning the ECU too much can cause this problem. I think I'm going to stop tuning the ECU after I finish tuning my new turbo. Hope you'll get your problem fixed.
__________________
Tomei ARMS/HKS 272s/HKS SMF Intake/ARP HStud/Mil.Spec/PTE880/Megan O2/Buschur Mani/3"TBE/Walbro/Hallman/Injen Intake Pipe/3"FMIC/Synchronic BOV/WORKS XC8
EvolNinja
Tuned by 4WS Tuning
Online
Jul 1, 2009, 09:34 PM
Quote:
I highly doubt it's from "tuning the system too much". My car has only been tuned by CBRD and Chris@AMS. Maybe 4-5 times.
Hope it gets fixed as well. Thanks
Offline
Jul 2, 2009, 04:48 AM
Personal Sales Rating: ( 7)
Drives: 06 gg mr
I talked to Chad about your problem when i was down there..... its a wierd one for sure. CAn you post anything more one what happened when the problem occured. Does the car run and dive fine but the CEL comes on, did it have an issue and happen all at once o get worse over time. the ore details the better
__________________
Quote:
Originally Posted by HobieKopek
Technicallly it's French.
It's "douche".
GARAGE / EBAY turbo kit 428whp,350wtq. .......My EVO has a drinking problem
442whp CBRD Mustang Dynp 376 wtq
NEW NUMBERS 480whp 370 wtq Thanks to BLOUCH TURBO and CBRD!!!!
Next setup is in the works .....stay tuned
11.6 @ 120 mph....... IN A 6 SPEED
Offline
Jul 2, 2009, 04:51 AM
Drives: 06 gg mr
maybe Chad can chime in with more info on what the fuel trims are doing.
__________________
It's "douche".
Offline
Jul 2, 2009, 06:52 AM
Chad can explain a lot more than i can. He has been great keeping the car for me & squeezing the car in every second they have.
Car never had any issues besides this happening besides some spark plug issues after the BBK instAll. The car didnt feel right after getting it back this last time & then it would idle badly almost stalling frequently.
Im up for any suggestions.
Offline
Jul 2, 2009, 07:38 AM
Drives: 06 gg mr
What did you have done when you say *the last time*. scheduled maintenance, tune....??
__________________
It's "douche".
Offline
Jul 2, 2009, 08:19 AM
Silver Sponsor
Personal Sales Rating: ( 46)
Drives: LOT's'O'EVO's
the following have been replaced:
Fuel pressure regulator, evap sole and check valve, throttle body, idle stepper, EGR, plug wires, MAF, bov, head gasket, pcv valve, almost everything i can think of...
we did a compression test... 170-175 all across....
as soon as the primary is warm, the trims go full negative, then trickle back positive, then negative.... we have the stock injectors back in, another fuel pump, everything...
hmmmmm
cb
__________________
www.cbrdspeedfactory.com
Immaculately prepared facility... State of the Art equipment..
Proven Motorsports Background.. ALMS, Grand-Am, Open wheel...
www.ChadBlock.com
CBRD Radiators, BBK Turbos, Intercoolers, EVO X parts, and CBRD Time Attack EVO backed by Advan
The standard just became standard. Meeting expectations is now not acceptable... we must always exceed them.
Offline
Jul 2, 2009, 08:32 AM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
What intake is on the car? It sounds like there is a vacuum leak somewhere; but man you've replaced almost everything.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Jul 2, 2009, 08:44 AM
Drives: 06 gg mr
GOT IT!!! change the oil Chad! LMAO......inside joke
On a serious note Maybe the wires at the maf connector are loose. With how much stuff has been replaced it seams as tho the issue might be in the harness somewhere.
This could be way out there but In fuel injection class we had to diagnose a fualt within the ecu that caused improper refrence voltages out of the ecu. Just trying to come up with some stuff you haven't already listed checking.
__________________
It's "douche".
Offline
Jul 2, 2009, 11:08 AM
Personal Sales Rating: ( 91)
Drives: 9.50 @ 148 (no nos)
hmmmmm
cb
Try loading in a totally different stock rom image
I have seen roms pick up corupted data
Also - maybe I overlooked this but what kind of BOV is on the car ? - Re-circulating I hope
Al
Offline
Jul 2, 2009, 11:34 AM
Silver Sponsor
Al
Al,
thanks for the input.
i used an entirely different ecu with the immob copied over... same thing...
stock evo ix bov recirc'd
cb
__________________
www.ChadBlock.com
Offline
Jul 2, 2009, 11:53 AM
Thanks everyone for taking a look @ my problem. Im sure its going to be something so small. I totally owe the crew up @ CBRD lunch. Well, maybe not Caleb. Jk buddy ; )
Offline
Jul 2, 2009, 01:52 PM
Which intake tube is on there?
__________________
Build Thread
Offline
Jul 2, 2009, 02:25 PM
Silver Sponsor
Personal Sales Rating: ( 9)
Drives: 2006 WW IX
Quote:
whoa whoa whoa... watch it pal
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
