Jul 1, 2009, 11:28 AM
#31
Personal Sales Rating: ( 0)
good info, hope it all works out for you
Offline
Jul 1, 2009, 01:48 PM
#32
Personal Sales Rating: ( 21)
Drives: Evo IX Gsr
dammit BBK it is lol I kindve wanted to be a test guinea pig for the HTA green but I can't wait that damn long
__________________
Mil.Spec/Ai Racing/Massimo Power
380whp/353wtq @ 28psi stock IX turbo Gst Mustang Dyno
431whp/408wtq @ 28psi RRE's Dynapack
Tooned by Bryan @ Gst
Offline
Jul 1, 2009, 02:37 PM
#33
Personal Sales Rating: ( 1)
Drives: 2004 RS
I gather from reading the opinions on this and other threads that of the two turbos(HTA Green vs. BBK-Full), the BBK-Full is the better spooling choice. But, there are no comparative boost logs out there, or are there?
__________________
Vishnu XEDE & camgears-Greddy 720's-ported Green-HKS 280/272-Forge WGA-AMS LICP-DC DP-Magnaflow Ti-Ralliart TS-Tomei Thermokiller - SSAC O2 - BR8ES-Nissei IC--SS clutch line-Endless(f) /Hawk(r) - WALBRO 255-ITG filter-Motul-KOYO radiator-SAMCO intake hose-UEGO-Autometer-Kartboys-Authority SS-MR DV.
DLL: 389WHP/25PSI on 93( non-corrected@3300' altitude). (No dynos in the jungle! Fortunately, there are carnivorous toads that feed on bats).
Offline
Jul 1, 2009, 03:31 PM
#34
Personal Sales Rating: ( 29)
Drives: evo VII evo VII
bbk info step up to the plate please
Offline
Jul 1, 2009, 03:49 PM
#35
Personal Sales Rating: ( 2)
Drives: 03 EVO TB
Quote:
Originally Posted by shuttlegoose
im a big advocate on the bbk because of the cbrd customer service, R&D time spent, quick turn around time, and great pump results. BUT can we PLEASE see a time slip for someone running a BBK. I know its not a turbo for drag racing but 1/4 mile times are 1/4 mile times, numbers are just numbers
I've got a BBK lite on a stock VIII engine with HKS 280s. First time out I ran a 12.5 @ 112.5 at 23psi on 92 octane. AFRs and timing were pretty conservative. Being the first time I'd ever driven an EVO at the track I was pretty conservative on the launches - I think my best 60' was high 1.7s (I'm used to pulling mid-low 1.6s in the Talon). This was also through a high flow cat and the air inlet temps were hitting 126F.
Since then I've put on a testpipe and fabbed a cold air shield which dropped temps to a few degrees over ambient, this allowed me to raise the boost to 26psi on 93 octane with some more timing and slightly leaner AFRs. I'd expect it to see 11s as it sits based on how it pulls compared to before. Bear in mind I didn't build this car to be a drag car, I've been down the road of fast DSMs and big laggy turbos got old, I just wanted something that spooled like stock with a little more kick up top and this setup is PERFECT!
Offline
Jul 1, 2009, 03:55 PM
#36
Silver Sponsor
Personal Sales Rating: ( 46)
Drives: LOT's'O'EVO's
keep in mind, the LITE is JUST the compressor upgrade..... not the upgraded turbine also
it spools almost ridiculously fast hee he, i actually prefer the FULL because the lite is hard to modulate at part throttle!!
cheers
cb
__________________
www.cbrdspeedfactory.com
Immaculately prepared facility... State of the Art equipment..
Proven Motorsports Background.. ALMS, Grand-Am, Open wheel...
www.ChadBlock.com
CBRD Radiators, BBK Turbos, Intercoolers, EVO X parts, and CBRD Time Attack EVO backed by Advan
The standard just became standard. Meeting expectations is now not acceptable... we must always exceed them.
Offline
Jul 1, 2009, 07:55 PM
#37
Personal Sales Rating: ( 4)
Drives: 2006 EVO 9 SE
I've been reading all the threads and I still think the BBK is the hot ticket. For one, FP has a very hard time delivering their product. For two, there have been far too many reported green and red failures. For three, the newer green and red are no longer stock appearing turbos .. the intakes are huge. For four, the standard green isn't much better than a stock 9 turbo and the stock appearing red has compressor surge like no tomorrow. Lastly I fee anything bigger than the BBK should require a built motor.
Offline
Jul 31, 2009, 08:32 AM
#38
hta green , any info on this ???
Offline
Jul 31, 2009, 08:51 AM
#39
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
Here's why you should buy a BBK. This thread was created 1 month ago, and we still have seen only ONE HTA-Green dyno graph. Where are all the others? In the meantime, BBK's are available and the performance in the real world is going to be damn near identical, yet the BBK will cost less.
Offline
Jul 31, 2009, 08:54 AM
#40
flow rate on bbk full ???
hta green flow rate ???
Offline
Jul 31, 2009, 08:57 AM
#41
This standard of performance is now improved into the "perfect pump gas turbo" with an increased power capability, greater efficiency, less turbine back pressure, more options for wastegate opening pressure, and all of this with FP to back up the unit for the length of the warranty.
This unit features the 54lb/min 73mm HTA compressor wheel and a new 65mm revision of the high efficiency 67mm turbine wheel used in the FP Red™ for the perfect combination of power and rapid spool.
this is info i found on fp web page ...
im not against the bbk , or against fp hta green , i would just like to see some results on these turbos
i have no intention in offending any bbk owners ,
Offline
Jul 31, 2009, 09:03 AM
#42
Silver Sponsor
Personal Sales Rating: ( 9)
Drives: 2006 WW IX
http://forums.evolutionm.net/evo-dyn...bbk-ftmfw.html
Little. Blue. Different. CBRD BBK + MAP Port/coat
CBRD BBK dyno results thread
There's plenty of "results" in those threads. I would maybe also reccommend shooting some PMs to BBK owners for their opinions (if they're not posted) and also speaking with Chad. The BBK might not be the turbo for you... it just depends on what your goals are. We don't allow clients to purchase directly through our website as we want to make sure the BBK, and CBRD for that matter, are a fit for our clients.
__________________
Offline
Jul 31, 2009, 12:01 PM
#43
thanks cbrd
i just can beleive that in the usa , only 1 hta green has been dynoed to show us a chart
Offline
Jul 31, 2009, 12:29 PM
#44
Drives: 2003 TB Evo 8
Like the price.
Waiting for numbers (1/4 mile definitely)
Offline
Jul 31, 2009, 03:41 PM
#45
Personal Sales Rating: ( 5)
Drives: '06 GG MR, '98 S14
A local BBK guy made like 425 or 430 on a Dynojet uncorrected - I would imagine that's enough for 11's
__________________
finally... an evo with no decel noise
340/336 uncorrected Dynojet (Shiv tune) with exhaust
385/336 corrected Dynojet (JohnBradley tune) with BBK
Offline
Tags
14, bbk, big, cbrd, evo, full, green, hta, hta 73, inb4thelock, mile, numbers, quarter, red, times, turbo, turbos  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
