Jun 26, 2009, 11:13 AM
Personal Sales Rating: ( 1)
Drives: 2006 EVO IXMR
???Does the new HTA Green hold boost like the RED???
The title says it all. I want the green but need some more questions answered. I want to hold the 28+PSI at redline that a RED can hold. Is this Possible on the HTA Green?
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Jun 26, 2009, 02:01 PM
Drives: 2004 RS
You want no taper, right? I am not sure that we have the relevant empirical data as of yet.
__________________
Vishnu XEDE & camgears-Greddy 720's-ported Green-HKS 280/272-Forge WGA-AMS LICP-DC DP-Magnaflow Ti-Ralliart TS-Tomei Thermokiller - SSAC O2 - BR8ES-Nissei IC--SS clutch line-Endless(f) /Hawk(r) - WALBRO 255-ITG filter-Motul-KOYO radiator-SAMCO intake hose-UEGO-Autometer-Kartboys-Authority SS-MR DV.
DLL: 389WHP/25PSI on 93( non-corrected@3300' altitude). (No dynos in the jungle! Fortunately, there are carnivorous toads that feed on bats).
Offline
Jun 26, 2009, 02:24 PM
Personal Sales Rating: ( 40)
Drives: '05 apex silver evo 8
Call FP...
__________________
Ported IX Turbo/Buddy Club 272/280/Magnus Street SMIM/Muse exhaust manifold/ETS Short Route UICP/LICP/4" MAFless intake/ETS 3.5" Exhaust/ETS 3" widetank fmic/Walbro 255/ACT HD/GM 3 port BCS/Speed Density on stock ECU
MidgetSpec&English Racing
ETS
EDRCrew
Offline
Jun 26, 2009, 04:08 PM
Personal Sales Rating: ( 4)
Drives: 03 evo
I wouldn't be too concerned on what it can hold to redline. I would focus more on the gains and trap speeds the turbo will deliver. Turbos can still make power with taper.
Offline
Jun 26, 2009, 08:15 PM
Personal Sales Rating: ( 2)
Drives: 2003 Mitsubishi Lancer Evolution
I was of the impression taper could be managed other ways, too.
__________________
Apex Silver '03 VIII
Buschur Racing Intake, Deluxe FMIC, IC piping, TB & IM, 880s, ported exhaust, SS O2
FP's WR8 Turbo, 10.5 Hotside, HKS 264i/272e, DLI II Ignition Amp
RnR Racing 3"TBE, Works HF Cat, APS BOV, Hallman Pro RX MBC
Shep Trans; TRE Rear Diff, Stage 4 TC
ROBISPEC ///
Mellon Tuned
... she likes bein' forced ...
Offline
Jun 26, 2009, 11:19 PM
Personal Sales Rating: ( 6)
Drives: Honda/Evo VIII
I would like to see some dyno graphs
__________________
658whp 447wtq
11.21@134- Rsx type s
Offline
Jun 28, 2009, 08:43 AM
Personal Sales Rating: ( 47)
Drives: 2003 Evo VIII
Taper is a function of max flow compared to RPMs. In general, the higher the RPM, the more air the motor can ingest. The MASS of air the engine uses goes UP, but the boost pressure (air backed up waiting to go into the motor) goes DOWN. In general, smaller compressor wheels provide lower air mass delivery (measured in lbs/min.) than larger compressor wheels, so I would not expect that the new GREEN HTA would match the larger RED HTA's output. The amount it would taper, if at all, would depend somewhat on the capabilities of the motor that it's mounted on to flow air...
Offline
Jun 28, 2009, 08:57 AM
Personal Sales Rating: ( 0)
Quote:
Right, on a built motor I wouldn't hesistate for a second to but a .82 or 1.06 HS on it. I heard subie guys have a lot of problems with FP, I am surprised you guys don't say the same, especially with all the FP Threads I read. If it were me Id go with a GT42 Turbo with a 1.06 HS, but thats just me. If he's looking for moderate levels Id go with a 30R or 35R.
Offline
Jun 28, 2009, 01:27 PM
Quote:
The point of the post you quoted was to explain that boost does not equal mass, which is what really counts. Larger turbos with turbine housings with larger A/Rs have the capability to move more mass, but come with a trade off of greater "lag" compared to a smaller turbo on the same motor. For a large number of Evo owners, the characteristics of a HTA Green or a Red are exactly what they want, and have the advantages of near stock spool, substantially more power, stock appearance, and no need for T3 or T4 manifolds and supporting parts. That's why they are in high demand.
In contrast, a GT42 is HUGE, and would not satisfy 99% of the people considering a Green or a Red. Not remotely in the same ballpark...
As far as your comments about FP, it sounds like you've had no experience yourself. There are thousands of very happy FP customers here, myself included, who would be pleased to give you the benefit of our experience. FP makes great products, and stands behind them. What more could you ask?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
