Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 20, 2009, 02:45 PM   #1
Personal Sales Rating: (8)
NsinEvo8's Avatar
Drives: EVO\\\, 4g64 Mighty max, Gmc Acadia, Yota Tundra
Boost leak locations..?
Im doing boost leak test thru turbo inlet, and found a couple obvious leaks. one at ic pipe and other at breather tubing.. I compress air to about 15psi and i hear this faint noise aroun manifold. The others where hissing, but this one is quiet and i cant find it! pressure drops about 1psi every 4-5sec. Sounds like its under many, ive check tps, and other vaccum tubes. Any other method i can use, or other locations i havent checked? Thanks guys
__________________
380whp/340wtq Mustang dyno
Stock 8 turbo @25psi
E85 clean air vehicle (:
GST Motorsports tune
Offline
Old Jun 20, 2009, 02:49 PM   #2
Personal Sales Rating: (1)
LOVEBOOOST's Avatar
Drives: 03 evo8
It could be your seals in your throttle body
Offline
Old Jun 20, 2009, 03:04 PM   #3
Personal Sales Rating: (5)
DBallz's Avatar
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Drives: 05 Apex Silver Version 8, 2001 GSX-R 1000
Send a message via AIM to DBallz
Quote:
__________________
Stock Block and Head
FP Red 80mm
Kelford 272's
Beehive Springs
Precision 1k injectors
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
PPI Extreme Ported Hotside, Exhaust Mani, Intake Mani, and TB
469@28psi on 93
Junior Tuned
THE SHOP CT built
Old setup
Stock Evo 8 Turbo
322.7 whp 320tq 21.5 psi on 93 oct
355.8 whp 430tq 25 psi on c16
Offline
Old Jun 20, 2009, 03:04 PM   #4
NsinEvo8's Avatar
^ i looked around there but, i have a new boomba tb. had adjustable cam gears installed recently, possibly the valve cover gasket? how about dip stick? lol man so many places.. back to square 1.. ikd, ill check it again later
__________________
Offline
Old Jun 20, 2009, 03:09 PM   #5
LOVEBOOOST's Avatar
Drives: 03 evo8
AHH.. if you have a new throttle body it probably aint coming from there and u said its coming from around the intake manifold
Offline
Old Jun 20, 2009, 03:19 PM   #6
Personal Sales Rating: (15)
kanyonkid's Avatar
Drives: evo8MR + subi RS +08 Lancer
its gotta be coming from one of the 150 vaccum lines in the manifold... goodluck as i have the same issue.. how faint is the "hissing" sound? mine is extremely faint and i dont have a boost tapering problem when WOT
__________________
Lots o' bolt on's... suspension, brakes, motor
327awhp/304awtq est. DLL @ roughly 23psi
New time:
12.13@113_____stock block, head, turbo... 6speed
Offline
Old Jun 20, 2009, 03:22 PM   #7
1NastyMR's Avatar
Drives: 2006 Evo IX MR SE
Send a message via AIM to 1NastyMR
Check all your EGR vacuum hoses behind your intake manifold
__________________
<!>APM RACING<!>
Offline
Old Jun 20, 2009, 03:27 PM   #8
Personal Sales Rating: (55)
fugiwara's Avatar
Drives: corolla
Send a message via AIM to fugiwara Send a message via MSN to fugiwara
If the new throttle body still uses factory throttle body seal then it's gonna leak no matter what. factory seal just ain't seal well. That's why the aftermarket seal are harder to put in b/c they are tighter. if you have replaced your throttle shaft seal you'll know.
__________________
4WHEELSLIDE TUNED
ROBISPEC TUNED///
Offline
Old Jun 20, 2009, 04:57 PM   #9
NsinEvo8's Avatar
^ Its a whole new throttle body. No leaks in that area, ive squirted green soap all around exposed areas, injector seals, tb/manny gaskets, some vaccum lines & boost gauge tube, which is where there is another tiny leak, but i capped that off so..
Quote:
^lol. it probably is. Its really not a hiss, more like verrry light vent noise?, and pressure drops real slow? I can barly hear it,, if it wasnt for guage dropping psi, i wouldnt even know about it...
So you dont have any taper huh? even though you got that small leak?
__________________
Offline
Old Jun 20, 2009, 11:42 PM   #10
Personal Sales Rating: (6)
dxbevo9's Avatar
Drives: Black IX MR(Sold); White IX RS
believe it or not i found a boost leak in the seal of one of the injectors on the intake manifold once..
hope that helps
__________________
><((((º>`·.¸¸.·´¯`·.¸.·´¯`·..><((((º>¸.
. .·´¯`·.. ><((((º>`·.>((((º>
·.¸¸.·´¯`·.¸.·´¯`·..·´¯`·.¸.·´¯`·..><((((º>
·´¯`·.. ><((((º>
*WW Evo IX RS 4xxwhp (numbers coming soon)
*TB IX MR 528whp/387trq 29psi 4WS TuNe(click)
Offline
Old Jun 21, 2009, 02:34 PM   #11
NsinEvo8's Avatar
So, i did some more boostleaktesting, and found its an internal leak
I opened valvecover oil cap, an could hear the leak.. gurgling also. I even turn the crank to make sure its atdc.. Damm, What could be causing the leak..? what do i have to do now??
__________________
Offline
Old Jun 21, 2009, 03:05 PM   #12
Personal Sales Rating: (2)
bbyevo8u's Avatar
Drives: *9 MR SE* ivey tuned.........sold: k7 gixxer 600, 03 350z stock, 04 evo8 cbe, 05 evo8 cbe, 06 sti cobb stg2 300whp
internal leak??
__________________
PERRIN TBE W/TEST >< BUSCHUR CONE FILTER >< ETS INTERCOOLER KIT >< HALLMAN PRO MBC >< WALBRO 255 PUMP >< KELFORD 272's >< BEEHIVE SPRINGS >< INVIDIA EXHAUST MANIFOLD >< INVIDIA 02 HOUSING >< HDSS W/ACT STREETLITE FLYWHEEL >< FLUIDAMPR CRANK PULLEY >< ARP HEAD STUDS >< STIFF SHIFTER BUSHINGS >< SS CLUTCH LINE >< DUNLOP TIRES >< AEM WIDEBAND >< AUTOMETER BOOST GAUGE >< KOYO RAD >< KEVLAR BELTS >< ///IVEY TUNED - 350whp 352whq///
Offline
Old Jun 22, 2009, 10:36 PM   #13
NsinEvo8's Avatar
does this happen to anyone else? ive searched around and seems to be normal, air will leak out engine, either out exhaust, or crankcase. not %100 airtight. can someone confirm this?
__________________
Offline
Old Jun 23, 2009, 01:18 AM   #14
Personal Sales Rating: (10)
2003 Mitsubishi Lancer Evolution
huevosrancheros's Avatar
Drives: 03 Banana EVO VIII
that is some weird shiet.
__________________
PS3 ID: Kinikuchunks, Add ME for some Call of Duty Modernwarfare2.
KUNiiiZZZEEE Dial-IN
Offline
Old Jun 23, 2009, 07:10 AM   #15
Personal Sales Rating: (7)
20gmr's Avatar
Drives: 06 gg mr
Its natural that air is going get passed the piston rings. If you are really concerned do a compression test followed by a wet Compression test.
__________________
Quote:
Originally Posted by HobieKopek View Post
Technicallly it's French.
It's "douche".
GARAGE / EBAY turbo kit 428whp,350wtq. .......My EVO has a drinking problem
442whp CBRD Mustang Dynp 376 wtq
NEW NUMBERS 480whp 370 wtq Thanks to BLOUCH TURBO and CBRD!!!!
Next setup is in the works .....stay tuned
11.6 @ 120 mph....... IN A 6 SPEED
Offline
Tags
06, boost, egr, evo, evom, gurgling, injectors, ix, leak, leaks, like, mustang, sound, sti, supercharger, taper, test
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
