Evo Engine / Turbo / DrivetrainEverything from engine management to the best clutch and flywheel.
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Just curious and wanting to know what is the difference between the HKS camshaft and Kelford camshaft? I heard that the Kelford make more power is that true?
THANKS IN ADVANCE
I was thinking to upgrade from my HKS 272 to kelford, but my tuner tell me to stay with my HKS 272, he said he likes HKS 272 is b/c the all around performance.
HKS cams are design with reliability in mind, to work with stock valve, valve springs. The car drives just like stock and produce with fast turbo response.
I'm not a particularly big fan of the 264/272 combo I have in my car right now, and based on the specs I can't see 272/272's being much better-they're almost identical. I will be getting rid of my hks cams before long and going with either kelford 272's or GSC S2's (depending on whether or not I feel like replacing the springs, etc).
__________________
03 TB EvoVIII, ams 35r, fmic, cams, etc. 440whp 11.63@123 sold
04 Volvo V70R 6mt. Stock (I think)
90 Volvo 740 16v, hx52, th400. 10.4@129
94 Volvo 940 Turbo Wagon. Evo 8 turbo, 16v head, ms3 "Turvo" 13.7 1/4
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Drives: 05 Apex Silver Version 8, 2001 GSX-R 1000
Points: 4,112, Level: 40
Daily Activity: 0%
Quote:
THANKS IN ADVANCE
Before this is locked and Search is posted. It all depends on what kind of turbo your using or plan to upgrade to. HKS 272's or GSC S1's are perfect for stock turbo. I would say with a FP Red or higher Kelfords are perfect
__________________
"When pistons melt tuners call that fat fingers"
Stock Block and Head
FP Red 80mm
Kelford 272's
Beehive Springs
Precision 1k injectors
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
PPI Extreme Ported Hotside, Exhaust Mani, Intake Mani, and TB 469@28psi on 93
Old setup
Stock Evo 8 Turbo
322.7 whp 320tq 21.5 psi on 93 oct
355.8 whp 430tq 25 psi on c16
The Kelford 272 is different from the HKS 272 in almost all aspects - read Martin Musial's Evo cam test in Modified magazine for the full details. The bottom line is that the Kelfords will not work with the stock valvetrain. You will need to upgrade the valvetrain to make use of these cams, since they are higher lift cams than the HKS cams. The Kelfords will make more power than the HKS 272s; how much depends on a lot of different factors, such as turbo size, fuel, tune, etc.
l8r)
__________________
"Learning is the beginning of knowledge ...
knowledge is the beginning of understanding ...
understanding is the beginning of wisdom."
Any society that would give up a little bit of liberty to gain a little bit of security will deserve neither and lose both.
- Ben Franklin, Thomas Jefferson -
every one keep saying to read the AMS cams test but didn't mention that it was done on a different turbo and motor than stock. For stock turbo, 272 hks has been proving for decent gain, not too laggy, very reliable, minimal change of the engine throwing a code, easy idle and tuning... and now good price especially with all the used ones out there. My 2c.
In that case make sure that the combination of parts you get for your car will work. The HKS272 is a good cam on a stockish setup, I used to run them. If you end up with something like an FP red, and you want to maximize it's potential, you'll probably want a bigger cam, like the Kelford 272 or beyond.
Please read the AMS cam test (find the magazine if you can, the articles are extremely informative), and read any cam comments posted on this board by Ted_B. Just because both the HKS and Kelford cams have a duration of 272 DOES NOT MEAN THEY ARE THE SAME or even comparable. The HKS cams are designed to work with the stock head. Higher lift cams, like the Kelford, will need an upgraded valvetrain ... they would destroy the stock head in no time.
l8r)
__________________
l8r)
when you say it wont work with stock valvetrain, what do you have to do to the valvetrain? just get spring or something else??
__________________
Daily Activity: 0%
I'm looking at the FP RED Turbo
Perfect get the Kelfords do it right the first time. Check the sig
__________________
FP Red 80mm
Kelford 272's
Beehive Springs
EPM 02 Dump
ETS 3.5" IC Kit
APS BOV
Old setup
Stock Evo 8 Turbo
im runnin kelford on stock valvetrain.... i pull to 7800rpms in 4th when runnin the 1/4... i feel that is dangerouse but my buddy on comp280's revs to 8k on stock valvetrain all day for 2 years now... i have the springs/retainers just waiting to put in... def go kelford
