May 26, 2009, 02:59 PM
Personal Sales Rating: ( 1)
AMS turbo kit problem with hta 86...
Soo my car is in the process of having a 2.3l stroker put in it. Everything was going great until i get a call from the shop about the turbo. I bought the fp hta 86 and they said it needs to have a five bolt exhaust housing to work with the ams kit. Right now it has a 4 bolt but i looked on fp site it doesn't even look like they make a 5 bolt? i never even heard of a 5 bolt housing either  . Anyone running a HTA turbo on with their ams kit?
Iam kinda at a loss honestly.. My hta 86 has a precision housing i don't know if that makes a difference or not.
Offline
May 26, 2009, 03:02 PM
Personal Sales Rating: ( 48)
2005 Mitsubishi Lancer Evolution My Garage
Drives: GG Voltex 8 / 05 Duc 999S / 08 Ford F150 5.4 / Mazda 323 GTX
Did AMS sell you the turbo ?
If not it sounds more like a problem of buying a turbo that does'nt fit...Which I don't think you can blame on AMS.
AMS uses different hotsides than other turbo kits, nothing new.
__________________
572HP@34PSI C16
506HP@29PSI 93/Alky
BR2.3/BR HTA35R
Tuned By Matt Koestner @ DSG W/Autronic Management on a Dyno Dynamics
Dressed in Voltex
DSG....
Offline
May 26, 2009, 03:04 PM
soo how would i go about getting the right housing for the hta 86? should i call ams? or should i have the shop just fab up a different o2 dump. I don't know what would be cheaper or quicker at this point. I mean on FP site they dont even have 5 bolt housing as an option.
Offline
May 26, 2009, 03:05 PM
Personal Sales Rating: ( 128)
Drives: MR
All you have to do is a buy a 5 bolt Precision .63 AR Ford Housing.. and bolt it on.. it works great!! You have a 4 bolt housing right now.. just swap to the 5 bolt and you are good to go!
Online
May 26, 2009, 03:06 PM
Drives: MR
FP doesn't have it as an option because they dont like the turbo to be used on anything smaller than an .82 AR.. but the .63 is fine and has been proven to make good power with great spool.
Online
May 26, 2009, 03:08 PM
Quote:
thanks alot man  ! you know of a good site i could order one of those housings from  .
Offline
May 26, 2009, 03:12 PM
Personal Sales Rating: ( 15)
Drives: 03 Evo VIII
I never realized AMS used something besides the 5 bolt turbine housing??
If you had a 35r AMS Kit and are having the turbo upgraded to an HTA86. Then you have nothing to worry it about. Just use the housing that you have, it will bolt right up.
Honestly, dont use the .63 (5 bolt of 4 bolt) with the HTA86.. you are gonna choke it. If you are gonna use the 5 .63 housing get the HTA82 if you want all that trq.
__________________
804 whp/650 wtrq (dyno dynamics 1.2 correction)
FP HTA86, Driven Innovative Intake, Turbo Trix long Block, APS Exhaust, BF FMIC, AEM w/1600cc inj
Old setup 487 hp/ 510 trq FP Evo Green
TheShopCT.com Built
Offline
May 26, 2009, 03:14 PM
Personal Sales Rating: ( 6)
Drives: 03 Lancer Evo 8
why can't you just get your own 4 bolt o2 housing? I'm pretty sure they can work around that.
__________________
----------____
------t_ /---l---Y ----p {
------L (@)_]__(@)_j [ ] <---- guard rail
Online
May 26, 2009, 03:15 PM
I wish it was that easy man i had the 50trim on it befor this  . So they don't make a .82 housing in a 5 bolt?
How hard would it be for the shop to just fab up something to work with the 4 bolt anyway?
Offline
May 26, 2009, 03:19 PM
Quote:
they were saying something about how the external wast gate is setup. Like the housing needs to be a 5 bolt because of where the external waste gate is.
Offline
May 26, 2009, 03:21 PM
If I'm not mistaken all they have to do is attach the external waste gate to the 02 housing if is resurculated. May be the problem is attaching their down pipe if not, I really don't see the problem with just going with a 4 bolt 02 housing, what are they including with their KIT?
__________________
----------____
Online
May 26, 2009, 03:26 PM
I think befor i go all crazy trying to find this housing ill see if they can fab something up hopefully. When i was talking to him i was saying could you cut the 5 bolt flange off of the 02 housing and put a 4 bolt. But then he kept saying the exhaust housing of the turbo needs to be setup for a external wastegate. And that it wasn't as easy as that.
Offline
May 26, 2009, 04:24 PM
Personal Sales Rating: ( 29)
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
If you still have the 50-trim then you can re-use the hotside from that turbo on the HTA86.
__________________
Shearer HTA3582 / Magnus V5 / GSC S2 Cams / PPI 65mm TB / Dejon 4" Intake / AMSoil 4090 Filter
FIC 1450cc Injectors / Perrin Fuel Rail / BR Dual Pumps / TiAL Q BOV / APS Catback
ETS UICP / Nisei FMIC / HKS DLI2 / Hallman MBC / E85
Speed Density via EcuFlash
Next: Wiseco 1400HD Pistons / Howards Rods / MAP Stage 4 Head / A1 L19 Studs / ACT 6-Puck
Offline
May 26, 2009, 04:28 PM
Quote:
what size exhaust housing is that considered though? .63ar?
Offline
May 26, 2009, 04:40 PM
this is the best news so far though if it does fit on the hta 86. If the 50 trims exhaust housing is a .63ar that would be so awsome.
Offline
Tags
6262, 86, ams, amsturbocom, evo, evom, hta, hta86, is, iv, kit, pte, t31, turbine, turbo, turbokit, turbos  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
