Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 26, 2009, 05:02 PM   #16
Personal Sales Rating: (48)
2003 Mitsubishi Lancer Evolution
jid2's Avatar
Drives: 03 EVO VIII White
This is what happens when you think all turbo kits are the same....
A kit - is a "kit". It works as a system. Every manifold, turbo, O2 housing, and downpipe are a little different. A change in one part typically has fall-out in the other parts of the system.
AMS uses 5 bolt turbine housings with the wastegate routed in the O2. The 5 bolt turbine housing has the wastegate port in the housing. The 4 bolt doesn't - it has to be used with a manifold mounted wastegate.
You have three options.
- Put the .63 A/R 5 bolt from your 50 trim on the HTA 86, if it fits the turbine wheel.
- Buy a new manifold, O2, and downpipe.
- Modifify the AMS maniold to add the wastegate, and build a new O2 housing. It's not entry level fabricating and it sounds like your shop isn't too interested.
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Old May 26, 2009, 05:09 PM   #17
Personal Sales Rating: (1)
If its a .63 A/R on the 50 trim wouldn't it have to fit the hta 86? I could of sworn someone on here is running a .63 a/r on the hta 86.
Offline
Old May 26, 2009, 05:32 PM   #18
Personal Sales Rating: (29)
Creamo3's Avatar
Drives: '03 CT9A / '06 MDX / '07 CBR600RR
Quote:
The AMS 50-trim runs a Precision .63 A/R w/ 5-bolt housing. This housing will work on your HTA3586.
__________________
Shearer HTA3582 / Magnus V5 / GSC S2 Cams / PPI 65mm TB / Dejon 4" Intake / AMSoil 4090 Filter
FIC 1450cc Injectors / Perrin Fuel Rail / BR Dual Pumps / TiAL Q BOV / APS Catback
ETS UICP / Nisei FMIC / HKS DLI2 / Hallman MBC / E85
Speed Density via EcuFlash
Next: Wiseco 1400HD Pistons / Howards Rods / MAP Stage 4 Head / A1 L19 Studs / ACT 6-Puck
Offline
Old May 26, 2009, 05:34 PM   #19
Quote:
soo happy right now!!
Offline
Old May 26, 2009, 06:34 PM   #20
whitey4d's Avatar
Drives: 04 white EVO,93 awd TSi
It will ONLY work after the housing from the 50trim(t31 turbine usually) is machined to fit the larger gt35 turbine. Probably better to just buy a turbine housing already machined for that wheel from PTE. Would be quicker and similiarly priced most likely..
__________________
Buschur Built: JE/Crower,stg 3 head, BF272s, 1K PTEs double pumper, tubular 82mm HTA with a.63 housing, newly installed BR Race Core.
480whp unfiltered BR MD Dyno, 544 whp Dynojet STD correction, 3rd gear, 31 psi, Stock ECU and MAF. Straight Shell 93 pump.
Currently running 94170015 V5.10 with SD Patch(Omni 4BAR) 531 whp 406 tq 4th gear, 519 386 3rd, CBRDs MD 33 psi straight pump Shell 93 Self Tuned
Offline
Old May 26, 2009, 06:39 PM   #21
Quote:
The thing is i don't thing they make a 5 bolt 82r housing. So if the ams 50 trim has the precision 62 ar 5bolt housing, isn't that pretty much what i would get anyway? I have been without my car for 7 months if the ams 50 trim housing works im going to use it. I rather not wait another week or longer for something that is the same thing. Are you 1000% sure it will not work unless machined?
Offline
Old May 26, 2009, 06:59 PM   #22
whitey4d's Avatar
What Im trying to say is that it wont. AMS uses a PTE .63 housing with every turbo they sell in there kits. BUT the Housing has to be machined to allow the larger diameter wheel it go inside the volute.
__________________
Offline
Old May 26, 2009, 07:03 PM   #23
Ah that sucks then . I was thinking that the exhaust wheel was the same as the normal 35r's. And just the compressor wheel was bigger on the hta 86. Oh well i guess ill have to see what i can do then. thanks though .
Offline
Old May 26, 2009, 09:58 PM   #24
Personal Sales Rating: (12)
staatz's Avatar
Drives: 00 Civic-Turbo(Traded in), 05 RR 8(RIP), 06 EB IX, 91 Jeep Wrangler, 95 Toyota Avalon
Send a message via AIM to staatz
Call up PTE and get a 5bolt ford style .63 for a 35r or 6262. The solution is very simple to this problem.
Offline
Old May 26, 2009, 10:19 PM   #25
Personal Sales Rating: (47)
CO_VR4's Avatar
Drives: 2003 Evo VIII
Simple. Call FP, tell them what your problem is, and ask them to suggest the best solution. Just because they don't list a certain hot side does not mean that they can't find you one, or maybe machine yours to fit...
Offline
Old May 27, 2009, 03:11 AM   #26
Personal Sales Rating: (15)
1NastyMR's Avatar
Drives: 2006 Evo IX MR SE
Send a message via AIM to 1NastyMR
FP stated on their site using anything under a .82 hotside on a HTA86 will be a total waste and quite stupid. Would of been smarter to get the 3582 with the .63 5 bolt hotside for ams turbo kit or send out your current 35R
__________________
<!>APM RACING<!>
Offline
Tags
6262, 86, ams, amsturbocom, evo, evom, hta, hta86, is, iv, kit, pte, t31, turbine, turbo, turbokit, turbos
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
