May 25, 2009, 12:57 PM
Personal Sales Rating: ( 3)
Drives: 06 GG IX SE
DIY: 35r kit, wisdom from those who've done it
So, a friend of mine and myself are planning on building a 35r kit, and completely fabricate it ourselves. He's a Wyotech grad, and is constantly reading/learning and trying to get as much fabrication experience as possible while trying to land the best job possible(which is very hard to do in today's world obviously).
So, we're going to just build everthing ourselves, being the manifold, 02, re-route anything necessary.
I'll buy the fittings, SS lines, injectors, and the turbo.
My question is that what do you reccomend I for sure purchase, what might be un foreseen challenges, what size injectors would be optimal for a 35r, and most importantly, where to buy the 35r from?
Do you custom make the new flange for the manifold? Or is it just a modified flange from a stock manifold?
I'd rather not buy used since he personally had such bad experience when he bought a used gt28r for his GTI.
This will probably take place this summer after I graduate in a few weeks, but I just want to start planning, get metal ordered, etc.
__________________
Hallman MBC, Perrin TBE, Tein coilovers, ETS lower and upper ICP & ETS Intake, AMS FMIC, Perrin Overflow can..... SNOW MONSTER
tuned by AMS
Offline
May 25, 2009, 01:01 PM
Personal Sales Rating: ( 22)
Drives: Evo VIII
normally 880cc on the injectors will be sufficient for a 35r
Offline
May 25, 2009, 01:03 PM
Personal Sales Rating: ( 13)
Drives: A lil' blue skittle
you can get the flanges from vibrant
Offline
May 25, 2009, 01:07 PM
Personal Sales Rating: ( 2)
extremepsi.com has alot of fab parts too!
If you dont mind me asking what type of welder are yall using?
Offline
May 25, 2009, 01:29 PM
Personal Sales Rating: ( 0)
Drives: WWevo9rs
I got my headflange from SLS, and all the other flanges/fittings/gaskets/v-bands etc I needed from ATP turbo. If you want a full 3" o2 housing get a 120deg bend also. I got the metal to actually make the manifold from ace stainless.
Check out some of the threads in the fab section for more ideas.
Fathouse
__________________
2006 Evo9 RS
Stock Engine/head/ecu/maf
Magnus v5, Shep racing, QM clutch, FP cams, Fatfab 35r turbo kit, BFF Racing, Snake Tunning, and CORN Fed
Best times to date.
6.757/10.362
108.55/136.94
http://www.youtube.com/watch?v=0qh0DPNNlJw
Offline
May 25, 2009, 02:57 PM
Personal Sales Rating: ( 1)
You can buy the flanges and most the parts from Vibrant or ATP turbo. Injector size depends on the boost level you run.
__________________
Quote:
Originally Posted by dridge11
I would let her mouth-punch me in the junk
Offline
May 25, 2009, 03:41 PM
Drives: 06 GG IX SE
Fathouse
yeah I've been reading up on your threads man, chances are I'll be pm'ing you through this process!
he wants to start producing manifolds for a few different platforms since he's having double knee surgery (again), and won't be able to work for a while.
__________________
tuned by AMS
Offline
May 25, 2009, 04:02 PM
Drives: 06 GG IX SE
Do you think the FMIC Cores on Vibrant are worth getting?
I'm thinking of getting the largest core on Vibrant's site and buy the end tanks, and just weld that up as well.
__________________
tuned by AMS
Offline
May 25, 2009, 04:07 PM
Drives: 03 evolution 8, 03 gsxr 1000
Injector size will vary. What type of fuel are you using? I am running the hta35r from F.P., and i really enjoy the hta version of the 35r.
Like i said above im using the F.P. turbo(forced performance) with no problems at all.
__________________
2003 evo 8. 280 cams, hta 35r, turboback exh., catch can, vishnu cam gears,walbro 255, precision 1000cc injectors, ams fuel rail,cat delete,arp head studs, buschur FMIC, buschur mini batt., buschur ICP, fidanza 3.2, fidanza flywheel, crower springs, retainers, valves, uh i think thats it..
Offline
May 25, 2009, 05:05 PM
Drives: 06 GG IX SE
I'll be on 93 pump, and how much more is the F.P. version?
__________________
tuned by AMS
Offline
May 25, 2009, 06:25 PM
No sense in buying the largest core that Vibrant has, bigger isnt always better. The bigger the core the worse the throttle response but you gain efficiency. A core should be sized for the power level. Not sure of the quality they use, because they are pretty inexpensive.
__________________
Offline
May 25, 2009, 07:33 PM
Personal Sales Rating: ( 17)
Drives: K20 EJ1 68mm turbo, 03 EVO8
I wouldnt use things from vibrant as their prices are phenominally high. For an intercooler core just talk to the guys at AFI they can get you a garrett core which is way better than anything a vibrant will come up with. Again like fat house said, ace stainless for the manifold metal. There are alot of places to get flanges from, you can get them from AFI as well or SLS. All v bands that your going to use I would get from racepartssolutions.com they are far cheaper than other vband places that I have found.
Offline
May 25, 2009, 09:15 PM
Drives: 06 GG IX SE
Quote:
thanks, this is very helpful!
__________________
tuned by AMS
Offline
May 25, 2009, 09:52 PM
Personal Sales Rating: ( 63)
Drives: Evo 8
Offline
May 25, 2009, 10:01 PM
I am not sure on the price diff. I bought the kit from buschur. I am running 1000cc inj. On 93oct you should be just fine with 1000's if your staying on the stock bottom end.
Quote:
Originally Posted by evovin
Very nice!
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
