Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine / Turbo / Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Sponsored by: World Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old May 13, 2009, 04:29 PM   #1
Personal Sales Rating: (10)
Garage is empty, add now
EVOllie's Avatar
Drives: 03 Evolution
Send a message via AIM to EVOllie
Wheres the fuel pump relay?
Im guessing that my problem...my car totally died yesterday. When trying to restart i realized i didnt hear the fuel pump. so i checked the fuel pump fuse...it was fine. Then i pulled the pump and threw 12v to it, and it kicked on fine. Then i checked for voltage at the harness to the fuel pump....nothing.
Looked in manual, did a search and i cant figure out where the relay is.
Its an 03 btw.
__________________
[SIZE="1"]Custom hard pipes and intake pipe
made by tempest racing
Mini battery kit
Stock ECU and MAF tuned by house of power
Buschur intercooler pipes
Halman MBC
Walbro fuel pump
1200cc injectors
Pruven FMIC
HKS ssq bov
HKS 272 cams
3" tbe & cat delete
ARP head studs
Exedy Twin disk clutch
Shep trans
Shep stage 3 t-case
EBaY Tubular manifold
Tial 38mm waste gate
Turbo: T3 Borg warner S362
472 on 93 oct
555 on C-16
Offline
Old May 13, 2009, 09:59 PM   #2
Personal Sales Rating: (1)
MRCole's Avatar
Drives: 2009 BMW 328i xDrive, 2006 Evo MR, 2001 Integra Type R, 1995 Honda Passport, 2002 Honda CBR 954 RR
Send a message via Skype™ to MRCole
underneath the hood
Offline
Old May 13, 2009, 10:16 PM   #3
EVOllie's Avatar
i think that narrows it down to 3. Ill call the dealer tomorrow.
__________________
Mini battery kit
Halman MBC
Walbro fuel pump
1200cc injectors
Pruven FMIC
HKS ssq bov
HKS 272 cams
3" tbe & cat delete
ARP head studs
Shep trans
Shep stage 3 t-case
472 on 93 oct
555 on C-16
Offline
Old May 14, 2009, 08:48 PM   #4
Personal Sales Rating: (3)
Drives: 2006 ランエボ RS
Sorry to see no one responded........Maybe "General" wasnt the best place to post..........Hey Im no Guru but when I throw pwr to the ignition I sometimes dont hear the pump (Walbro 255).........Curious as to what the issue is.......Maybe the relay is at the lower left interior fuse panel??..........Peace
__________________
Wheels /Tires: "If it rubs, it doesn't work & doesn't count !!!"
Note: Wheel /Tire fitment advice is my opinion only
Best EVO Build Here: http://www.lancerregister.com/showthread.php?t=268523
Pro Jesus / John 9:25 Though I was blind, Now I See
Offline
Old May 15, 2009, 06:37 AM   #5
redline7's Avatar
Drives: Evolution 7
Mine is against the firewall to the right when facing the front of the car. Rather large IIRC
__________________
Power FC | Defi Boost & Oil & AEM Wideband | DNP Manifold | Invidia02, Down & Test Pipe | HKS CatBack | Blitz BOV | Samco Intake | AMS LICP | Perrin I'cooler | AEM Meth Inj. | 255Walbro | Greddy 720s | Ralliart Wires | B&M Shifter | Poly Bushings | 17X9 Advan Rims | JDM Coilovers | APR, Cusco Carbon Braces & H Brace | AGP F. Mount | KSport 8pot 13" Brake Kit | Greddy Cam Gears | HKS 264/272ex Cams | MBC21psi | JVTR Radiator | ACT Clutch & Flywheel
Offline
Old May 18, 2009, 08:52 PM   #6
EVOllie's Avatar
Ok when i called the dealer, they had no idea where there located. But he did tell me two relays came up.
When i researched more, i came across a site that said i had 3 relays.
Either way 2 or 3, i still have no idea which relays are the fuel pump.
__________________
Mini battery kit
Halman MBC
Walbro fuel pump
1200cc injectors
Pruven FMIC
HKS ssq bov
HKS 272 cams
3" tbe & cat delete
ARP head studs
Shep trans
Shep stage 3 t-case
472 on 93 oct
555 on C-16
Offline
Old May 19, 2009, 05:34 AM   #7
Personal Sales Rating: (35)
JakeTheVIII's Avatar
Drives: 05 Silver Evo 8.5, 03 TB Evo 8 Project, 08 R6, and Sievers' 2.3L 37R Evo 8 @ 40+ psi
Under the hood nex to the ABS unit, they say Denso on them.
Offline
Old May 19, 2009, 07:29 AM   #8
Personal Sales Rating: (11)
My Garage
cfdfireman1's Avatar
Drives: EVO IX
There's 3 of them 2 are in the dash mounted junction box. C-221 & C-223
Offline
Old May 19, 2009, 08:03 AM   #9
Silver Sponsor
Personal Sales Rating: (56)
2003 Mitsubishi Lancer Evolution
My Garage
KevinD's Avatar
Drives: '03 evo8 time attack car, '10 tundra tow vehicle, '03 evo daily
i highly doubt the relay is the problem (never ever seen one fail on an evo 8/9). if your not getting power to the fuel pump, you likely have another issue. i would check all the engine fuses first. the ones under the dash and the ones in the engine compartment. if they are all ok, AND you are getting spark (verified by pulling a plug and watching it arc), then you very likely could have a bad relay.
__________________
EVOLUTION DYNAMICS LLC
Tuning, Custom Fabrication, and installs in the DFW area.
www.evodynamics.com
email: evokevin@gmail.com
Phone + Text messages: 817-776-2170
We use My Shop Assist Software so you can follow your build online, with pictures and records available to you anytime, from anywhere.
Online
Old May 19, 2009, 08:45 AM   #10
Personal Sales Rating: (0)
crcain's Avatar
Drives: vi rs
If I recall for an Evo 6 there is one in the engine bay and one behind the dash. The one behind the dash is next to the engine control relay I think. But this is all Evo 6.
__________________
10.7 granny shifting - http://www.youtube.com/watch?v=sOEL7uGJIuc
Autronic, 2.4l, MAD spec piper cams, AMS kit, FP HTA 35R, RC 3" exhaust, AIM Dash, Kansai inlet, q45 TB, Buschur COP
Tuned by Mark Shead
Offline
Old May 19, 2009, 02:38 PM   #11
EVOllie's Avatar
Quote:
just because you havent seen it happen to a 8 or 9 doesnt mean it cant happen. If i recall right it was a problem with old DSMs.
Also i checked every fuse (already said that)
And i havent gone as far as checking for spark because my fuel pump is not kicking on...checked for voltage at the pump....zero (already said that too)
Unless your saying something igntion wise might have gone up and is causing the pump not to get power...?
__________________
Mini battery kit
Halman MBC
Walbro fuel pump
1200cc injectors
Pruven FMIC
HKS ssq bov
HKS 272 cams
3" tbe & cat delete
ARP head studs
Shep trans
Shep stage 3 t-case
472 on 93 oct
555 on C-16
Offline
Old May 19, 2009, 02:41 PM   #12
EVOllie's Avatar
and thanks for the replys guys. Im gonna check when i get home.
__________________
Mini battery kit
Halman MBC
Walbro fuel pump
1200cc injectors
Pruven FMIC
HKS ssq bov
HKS 272 cams
3" tbe & cat delete
ARP head studs
Shep trans
Shep stage 3 t-case
472 on 93 oct
555 on C-16
Offline
Old May 19, 2009, 02:43 PM   #13
Silver Sponsor
My Garage
KevinD's Avatar
if your ecu isn't turning on, then your pump wont get power, and your ignition source wont get spark either. you can narrow it down to being the fule pump relay by simply checking to see if your getting spark. if your getting spark, and fuel pump is not turning around, you know that the ecu is trying, but the relay or pump are bad (and in your case since you said you have no voltage, then it would be the relay).
but check the spark, i bet you don't have any spark, which would mean that the problem is something other then the fuel pump relay. i've been wrong before but i deal with problems a lot and just running through a few simple checks can narrow the problem down quickly.
__________________
www.evodynamics.com
Online
Old May 19, 2009, 07:26 PM   #14
barneyb's Avatar
Drives: '03 Evo 8, '04 WRX
The two in cab fuel pump relays are on the left side of the junction box by the driver's left knee with the relay for the IC sprayer in between. The bottom #1 relay is closed when the ignition is on and powers the #2 relay. The #2 relay is closed by the ECU. The #3 relay by the ABS unit (under hood) is also controlled by the ECU and controls the two speed pump - resistor for low speed, no resistor for high.
Offline
Old Jun 20, 2009, 05:51 PM   #15
EVOllie's Avatar
After replacing all fuel relays one by one. (3 total) Still no luck.
So heres the update:
car gets power
it can turn over
its getting spark
all fuses are good
all fuel pump relays are new
Fuel pump is getting no power.
When the car first died it threw a po335 code. After researching it, it look like the sudden stall to the car while driving it might have thrown that code. I did clear it.
The po335 is back again after a week of trying to start it. does this have anything to do with my problem or is it from cranking it and not starting?
__________________
Mini battery kit
Halman MBC
Walbro fuel pump
1200cc injectors
Pruven FMIC
HKS ssq bov
HKS 272 cams
3" tbe & cat delete
ARP head studs
Shep trans
Shep stage 3 t-case
472 on 93 oct
555 on C-16
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
07, 954, bad, cbr, evo, fuel, fule, fuse, ix, powers, pump, r1, relay, voltage, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
