Cat-Delete 02 Sensor
Old Aug 15, 2022, 01:46 AM
Adam Visconti's Avatar
Looking at getting a de-cat for my evo 8, I currently have a high flow cat and an 02 sensor already before the cat hooked up to a AFR Gauge, now im wondering with the new de-cat test pipe this has a 02 sensor hole in it already as seen in the picture below. would I get a CEL light if i just capped it off with a threaded bolt.
[img]data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAE AAAICTAEAOw==[/img][img]data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAE AAAICTAEAOw==[/img]
Old Aug 15, 2022, 05:27 AM
Received 1,384 Likes on 1,317 Posts
Looks like you are already set w/the down stream o2 sensor & your wide band guage hooked up. Yes, get a standard plug for the test pipe & get that installed
One thing that comes to mind is that the engine tune is likely setup w/the HF CAT & removing the CAT will change your exhaust flow. Consider a re-tune?
Old Aug 15, 2022, 06:26 AM
Biggiesacks's Avatar
If you had already deleted the downstream narrowband 02 sensor, then you will be fine.
Like MinusPrevious said, you will need to tune for a test pipe.
Old Aug 15, 2022, 01:56 PM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Not today EPA.
Wapoosh
Oct 1, 2016 02:34 PM
elmark44
Sep 28, 2010 10:22 AM
widge
15
May 4, 2010 07:52 PM
Evolution8Blue
Jun 6, 2006 08:52 PM
gb_junkie
Oct 21, 2005 10:08 AM
Quick Reply: Cat-Delete 02 Sensor
