May 6, 2009, 01:32 PM
Personal Sales Rating: ( 2)
Drives: AS 06 EVO IX
life expectancy of evo IX battery?
I was just curious, how long/many miles before you needed a new battery for your evo IX's???
Im @ 13,500 and ~ 3 years old. Reason I ask, is cause Im sitting here waiting for some1 to come give me a jump, or take a look at my car, cause it wont start at the moment.
__________________
330whp / 340tq @ 26 psi (Reese Dynojet)
305whp / 300tq @ 24 psi (Reese MD)
350whp / 345tq @ 25 psi (Evoscan)
325whp / 315tq @ 24 psi VDR 5.71 (EvoM Mode)
Self Tuned
GM BCS / JDM / EVO X Map Sensor / Ets 3 1/2" intercooler / Injen intake w/ UICP & LICP / Works DP (jetcoated) / JUN B.L. cat back / Mil.Spec 100 cell / Walbro 255 /
Recently added 65mm TB w/ Int. Mani. port match, and ported my stock IX turbo
Advan RS 18 x 9 +29 in SBC wrapped in Falken RT-615's
245/40/18
Offline
May 6, 2009, 01:33 PM
Personal Sales Rating: ( 20)
Drives: 500whp DA9 03 evo 8 370whp 2002 s2000
i just replaced my 03 evo 8 stock battery about 6 months ago. my car has 50k miles
__________________
03 blue by you evo
392 whp@22psi 91 octane full-race t4 twin scroll 1.06ar HTA gt3582rr, 65mmtb, buschur ported stock intake manifold, hks 272's, 3' cuctom magnaflow exhaust, ETS 3.5" thick intercooler, ebay uicp, forged diverter valve, walbro 255lph & denso 720cc injectors.
Offline
May 6, 2009, 01:41 PM
Personal Sales Rating: ( 6)
Drives: 00 Eclipse GT SDS Stg. 3 & 08 RR EVO X GSR
Wrong section
__________________
List:
-Clipse3GT Tune -COBB UICP, LICP, BOV HP, SF Intake, Turbo Inlet Pipe, Sway Bars -ETS 4" FMIC -AMS DP, Fuel Rail, Rollerstop -T1R Exhaust -MXP TP -FORGE WGA -APS TV BOV -xMR Catch Cans -GM 3 Port -Deatschwerks 800cc -Techna-Fit SS Lines -TWM Short Shifter -WORKS Bushings -SWIFT Sport-Mach's -Whiteline Kit -AEM UEGO -STRI PSI Gauge -Rally Armor Mudflaps -PERRIN 3" Ant. -Advan RS 18x10
Future:
FP Green Turbo (to install)
XXX Exhaust Manifold
Offline
May 6, 2009, 01:56 PM
Personal Sales Rating: ( 3)
2002 Ford Focus
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Moved. Still on OE battery (since 12/04).
Offline
May 6, 2009, 05:19 PM
Personal Sales Rating: ( 8)
I have a 2003 evo 8 with 16,300 miles on it... stock battery, never done anything to keep a charge in it over the winters (ie: battery tender).
No problems yet....
While 3 years is on the lower side, its not uncommon for a battery to take a dive in that amount of time/use.
Offline
May 6, 2009, 06:16 PM
Personal Sales Rating: ( 46)
Drives: << 04 Spec313 EvoGSR >>
Mine lasted over 60K miles even though it died twice and I revive it twice. It was still good till last winter.  I had to revive it one last time to go buy a replacement.
Offline
May 7, 2009, 01:59 AM
Personal Sales Rating: ( 0)
Drives: IX
Not in the Desert
I got less than 36 months out of the stocker - the 120+ temps in the summers here simply toast the living s**t out of batteries. Those temps are air temps in the shade so when you throw on direct sunlight, asphalt temps near 150, and heat soak from the engine, you might be looking at a battery surface temp near 160. Then you drive in traffic, with little or no airflow, so yeah.
Most people here & in Phoenix I've talked to replace a battery every couple of summers; it just won't hold cold cranking amps anymore, even if the voltage is up to par.
This is pretty much a consumable expense (like tires or brake pads) out here.
Offline
May 7, 2009, 02:17 AM
Drives: 06 SE
I'm at 36k and mine has died on me twice now. First time was about a month ago. The last time was just this last Sunday at the drag strip.
We charged it but it's not wanting to hold very well.
Time for a new one.
__________________
a.k.a. Madman
Offline
May 7, 2009, 04:09 AM
Drives: 2005 EVO VIII SSL
Got 4 years on mine @ 43000 miles. Just replaced it.
Offline
May 7, 2009, 06:22 AM
Drives: Evo IX MR
27k mi still on original battery. Never any prob. But if I park it for a while I pull that little tab in the ECU box to disable clock and radio. Small drain but still a drain. You prolly left yer lights on.
Offline
May 7, 2009, 11:59 AM
Drives: a stock EVO, a rarity amongst all
i'm at 65k and on the OEM one!!
But, it's a daily driver, highway miles, and garaged, so that usually helps. . ..
__________________
Current = 2010 Acura RDX. . .still AWD and turbo charged 4 cylinders, just more family friendly :-)
"SOLD! Sleeper Tarmac Black". IVEY tuned September 2007:325awhp/345awtq-Dynojet
"If you haven't driven an Evo, it's hard to explain why this car evokes feelings of utter lust; the driving experience is simply that pure" Road and Track, Feb 2005 Long term test
Offline
May 7, 2009, 12:00 PM
Drives: 2006 Evo IX MR, 1979 Chevy C10, 2002 R6
Same battery since May of 06
__________________
♠I would rather be a smartass than a dumbass♠
♠Up on one♠
♠I was part of the AMS website crash of 2008♠
Offline
May 7, 2009, 12:17 PM
Drives: Mitsu. Evolution IX MR
mine went after one year, or 18K miles. Honestly, the best way to tell how good of a condition the battery might be in both externally in appearance, and internally, in its ability to charge and HOLD that charge, is to drain the battery slightly. I have no recommended way of doing this besides turning on your lights, or stereo and letting the battery supply the power. Take measurement reading of the battery charge level before you do this. Then once your done listening to tunes or blinding yourself from the constantly staring into the high beams, check the battery charge level again. It should be lower. Now what you want to do is start to charge - recharge- the battery using a battery charger, NOT YOUR CAR's ALT. What you want to look for is a lag in the battery's ability to charge up, and hold that charge. If the battery takes a LONG time to charge on an average battery charger that is not set to trickle charge, but fast or rapid charge, and/or the battery is never able to reach a full charge before the charger shuts down or stops, then this is a sign that the battery's useful life is nearing an end. If a battery charges slow, or can't ever reach its full battery charge potential, its likely a cell is dead, or that the acidic mixture within the battery has gone bye bye. In either case, a cell dying, or the mixture disappearing, all these are signs your battery needs to be replaced.
Always keep in mind that electrical issues can be solved through the replacing of a faulty battery, as it was in my case. In which the car would consitently stall when pushing in the clutch, this stopped after replacing the battery and has not rear its head since.
Offline
May 7, 2009, 05:26 PM
Drives: '03 Evo 8, '04 WRX
I'd suggest you already have the answer to your question.
Offline
May 7, 2009, 05:32 PM
Drives: Apex Silver IX
My factory battery died at around 10k.
__________________
- Jaime
Offline
Tags
06705, amps, battery, cold, cranking, died, evo, evo9, evolution, expectency, ix, lancer, life, mitsubishi, stock, voltage  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
